    Changing transformation variables
    13 Posts 4 Posters 1.1k Views 4 Watching
    • Chris FullmerC
      I think there are many of us Matrix math newbies around here. But little by little we're comprehending some of this stuff. So don't be bashful.
      The problem you are running into is that a_transformation is NOT an array object. It is a transformation object. Run this:
      t = Geom;;Transformation.new([2, 0, 0, 0, 0, 2, 0, 0, 0, 0, 2, 0, 0, 0, 0, 1])
      arr = [2, 0, 0, 0, 0, 2, 0, 0, 0, 0, 2, 0, 0, 0, 0, 1]
      t_arr = t.to_a
      puts t.class
      puts arr.class
      puts t_arr.class
      "t" is class Geom::Transformation. "arr" is class Array. It just so happens that transformation objects contain data that can be output to look like an array, but they are not actually arrays at all. To retrieve their array, or present their data in array form, use the .to_a as I did in the example. So to change a transformation array element, you have to get the transformation, turn it into an array. Adjust the elements on that array. Then turn that array back into a transformation object. Then apply that transformation to your object. It might look like this:
      ` gc = Sketchup.active_model.selection[0]
      t_exist = gc.transformation.to_a
      t_exist[12] = 0
      t_exist[13] = 0
      t_exist[14] = 0
      t_new = Geom::Transformation.new(t_exist)
      gc.transformation = t_new`
      That code works when you have an group/component selected and then run the code in jim's web console. It will move your component to 0,0,0 and keep it's scale and rotation.
      Hope that gets things sorted out a little,
      • honoluludesktopH
        honoluludesktop
        You guys are too fast for me today. I just made another mistaken post, failed to edit it, and then had to deleted it.
        What I tried, which the SUCF server failed to accomodate was to edit my post, while deleting it on another page. So I could retain a copy. Well "no can do", and both my pages crashed. Hope I didn't cause any confusion.
        Chris, thats neat stuff. Helps me to understand.
          MartinRinehart
          Why is it that you want to poke values into slots in the transformation matrix? This should almost never be necessary.
            It is a quick way to 'drop' stuff to z=0...
            tra=object.transformation.to_a tra[14]=0.0 object.transformation=tra
            Do this inside a loop of all selected groups for example and they are all set onto the 'ground'...
            • Chris FullmerC
              Its a quick way to move to a given point, if you don't want to find the vector to that point from the current point. I think it is also necessary to skew a somponent, since there is no skew command built into the API.
                MartinRinehart
                @chris fullmer said:
                Its a quick way to move to a given point ...
                Quicker than move!()?
                • Chris FullmerC
                  .move! will reset the scale and rotation of a component. So its not useful the way it is implemented. You have to first make a transformation object that includes the components scale and rotation, then replace its x,y,z values by hand. THen apply that transformation object to the group using .move! if you want to use the move method safely.
                  Try it out, if you have an animnation working using the .move! method. Just scale the component first, then run your animation on it and you will see it resets it's scale and rotation.
                  It is possible to workaround, and that is why the transformation matrix must be edited by hand.
                    MartinRinehart
                    You are right. I still want to hear from Hawaii, though. Suspect that he might have overlooked a method.
                    • honoluludesktopH
                      honoluludesktop
                      Hi Martin, I originally posted an application that did some simple transformations, and became interested in the subject. As you know I am a beginner at all of this and while experimenting, I tried to change some values just to see how my components would behaved, failed to do so, and asked for help 😳
                        MartinRinehart
                        Fine. I was afraid you overlooked available ways of getting stuff moved / rotated / scaled. I know I did when I started fiddling.
