Some plugins fail to load when open saved models
For some reasons, My SU can load particular plugins only at fresh start of a new model (plugins like SU physics, and a few more). In another word, upon re-open a saved model, these plugins can no longer be loaded.
My specs: Windows 7 ultimate 64bit, SU7.1, Intel i5, Nvidia 8800GTS, 8GB Ram.
Thanks for you time
Max
That is odd. Try opening SU first by double clicking the SU icon. Then from within SU, open up your saved model. See if that helps. If so, it might have to do with special observers the plugins try to load, and if they are failing on loading a saved model, this might be a bug that should be reported.
