    Select an object based on its attributes
    3 Posts 2 Posters 605 Views 2 Watching
      Pauline01
      Hello,
      In this code i associate an adress and a type for an object.
      If i have 10 objects, 4 objects have as adress "9994" (in the dictionnary "MyDico", ZoneAdr="9994"), i want create a plugin to select all object with "9994" as adress.
      It's possible?
      thx
      def setzone
      prompt = ["Nom de la zone"]
        val = Sketchup.active_model.selection[0].get_attribute("MyDico", "ZoneAdr")
        default = [val]
        result = UI.inputbox prompt, default, "Enter le nom de la zone"
        adrresult = result[0].to_s
          adr = Sketchup.active_model.selection[0].set_attribute("MyDico", "ZoneAdr", adrresult.to_s)
          UI.messagebox ("@ ; " + adr.to_s + " saved")
        adrresult="5"
        adr = Sketchup.active_model.selection[0].set_attribute("MyDico", "ZoneType", adrresult.to_i)
        @pauline01 said:
        Hello,
        In this code I associate an address and a type for an object.
        If I have 10 objects, 4 objects have as address "9994" (in the dictionary "MyDico", ZoneAdr="9994"), I want create a plugin to select all object with "9994" as address.
        It's possible?
        thx
        > def setzone
        >   default = [val]
        >   adrresult="5"
        > end
        You need to iterate through all of the model's entities [or a selection of things] and look for that attribute...
        Here's an example...
        model=Sketchup.active_model
        entities=model.selection.to_a
        ### OR
        entities=model.entities.to_a
        ### THEN
        zoneAdrs=[] ### an array
        entities.each{|e|
          if e.get_attribute("MyDico","ZoneType","")=="9994"
            ### it's a string - could be integer ==
            zoneAdrs << e
          end#if
        ### NOW zoneAdrs is an array of all entities with ZoneType == "9994"
          Pauline01
          thx TIG
