[Plugin Library] LibFredo6 - v14.5b - 24 May 24
downloaded LibFredo6 .Winrar says system cannot find path specified,,c/prog files/google/sketchup7/plugins. what could be the problem here? Would the fact that i have 2 comptrs one xp and one vista be a problem? i.e. while dnlding to vista machine is it trying to accomodate xp machine....please help. And which additional files are actually required to get it working...i successfully extracted files to xp machine, but nothing shows up within sketchup. (these may be dumb questions but i am a bit dumb)
I've dowloaded the LibFredo6 3.4 into the plugins folder and unzipped it.
Everything is there per the instructions (pdf). When I open SU the LibFredo6 doesn't show in the Windows menu.
What am I doing wrong?
Thanks,
-Zook -
Thanks,
-ZookLibFredo6 does not do anything 'alone'. It is only activated when my other scripts are used (like FredoScale, RoundCorner, etc...). Actually, LibFredo6 does not even load if not invoked from my other scripts (so it does preserve memory).
Thanks to confirm that you did (or did not)install any other script along with LibFredo6.
where can i download this fabulous plug in ?
thank you fredo
vive la france -
Thnk you fredo - you have saved me countless hours! I would like to make a paypal donation to your continued efforts - anyone know how?
Thanks for the recognition.
There is a menu for donation in Tools > Fredo6 Collection, and then for the plugin you prefer (LibFredo6 is not really a plugin, but a shared utility used by several of my scripts).Fredo
super !
fredo, I am a mac user, I tried everything...
I downloaded libfredo6 v3.4b, put in in the MacHD...\plugin, following the instructions, I even read through the forum a suggestion to put it in user\application support...\plugin and still it did not work.
what should I do? -
Hi Fredo, I'm also a Mac user - expanded the "Roundcorner" plugin and the "LibFredo6 - v3.4b" files in the HD/Application Support/Google Sketchup 7/Sketchup/Plugins directory with no luck, even after logging out and back in. Tried it in version 6 and 7. Any suggestions?
Did you install one of my plugins (like RoundCorner or FredoScale)? LibFredo6 does not do anything useful by itself and does not load until a plugin starts using it.
Fred
Is it possible to stretch by assigning a new dimension? i.e. i have an object that is 30 inches high. After selecting the fredo stretch and placing the stretch plane i would like to make the new overall height of my object be 28.5 inches high. Can i type in 1.5inches to get this result?
Also, I noticed that when you are stretching a group of components where there are multiple instances present, the other components are not updating to the new size that is being stretched? Can this be made a toggle or something to 'update all instances of components in model?'
Dennis
This is supported. Just move the mouse over the handle corresponding to the stretching direction (you don't even need to click, highlighting is enough). Then press TAB or select "enter new dimension' in the contextual menu. The dialog box shows you the current dimension. You can enter a new one. Note that the dialog box accepts formulas, so you can keep the current number and append -1 1/2'' if you like.
This is intentional, because in most cases you wish to create a new component with different dimensions and may want to keep the original version, but the idea of a toggle is interesting.
I would find the toggle useful because i am designing furniture for cnc production with various components that I need to get out in a flat state. So I have a 3d fully built model but I also have a version with all the components flat on the ground to make it easy to move the geometry into my CNC package.
Thanks for the quick and useful response!
(Are you interested in developing other plugins? I have one that I would like made and am willing to pay for. I don't know if you have seen the SliceForm plugin out there but I would like a version of that with the ability to make slices in a radial direction or to make slices that are perpendicular along a path.)
You can always play with the replacement of components by other components, which is a standard SU capability (in the Component Window).
For slicing, I think there already exists several plugins doing slicing with various features. I don't know what SliceForm does precisely. Anyway, I am busy at the moment with a Loft and Skinning script, but I am sure some script writers could take the challenge.Fredo
ho scaricato la tua libreria, ma non funziona! come faccio, sembra geniale la tua idea
newbie here. this plugin looks great however when i tried to use it my sketchup pro 7 crash and close. is there any way to fix it?
@Manong:
Libfredo is a helper script. Not a procedure plugin as you would see if you were to read previous posts above. You must download some of Fredo6's tools, plugins scripts, such as Fredoscale, or Hoverselect which rely on Libfredo for their functions. Please search the threads for these, and, if you actually did download one of them, and had the trouble you mentioned, then post there. Fredo will try to help you. He is very helpful.
Best regards,
mitcorb -
Great job
This makes a lot easy now
Thank you ferry much
Thank you very much Fredo6!
