    Animation in SketchUp
    58 Posts 10 Posters 12.7k Views 10 Watching
    • chrisglasierC
      chrisglasier
      I think I must be one of few who are interested in animation for analysis. Maybe there are others around here? I think these things need to be aired if we want to really use IT to enhance our performance rather than just titillate.
      So, for example, instead of having a chart for a production flow or building process you run an animation using the same start and duration data. Positioning data could come from any number of sources but I see the main point as separating the movement of objects from the movement of the camera.
      The latter is of course pure Sketchup but the rest I am sure should be via its web dialog so that people who are not modelers can also take advantage of animating models for their own analyses.
      • Chris FullmerC
        There is no need to separate camera animation from object animation though. It should be regarded as any other object, able to be animated and controlled via the same keyframes, key locations, path contraints, etc that should be available to object animation.
        Its just the web dialog UI that is a daunting task.
        • chrisglasierC
          chrisglasier
          I can make objects rotate and move. I put some examples on YouTube some time ago. As you will know now it is blocked here, so I can't provide the links. Tags include Sketchup and nameset.
          No key frames were involved, and I remember I could manually pan, zoom and orbit whilst the animation was continuing; that's why I see them as separate.
          It takes a lot of my time but will get there in the end.
            miikka1978
            I have been following different animation solutions (plugins and extensions) for Sketchup and I think that Sketchers Studio is the most advanced one. Anyway, they seem to have it only for Mac.
            http://sketchersstudio.com/en/
            • Chris FullmerC
              That looks like a program that does animation outside of SU, it just lets you import SU models. We're talking about an actual animation toolset inside of SU.
              @Chris - I remember you already have things animated in the past. I thought it was very cool when I saw it. In that respect, of being able to control the camera while the animation plays in the viewport, I agree. There would need to be a way to choose if the user is in animated camera view mode, or in regular SU view mode. Most modelers handle this by creating an actual camera object (much like the film and stage plugin). You can then animate that physical object. Then you could choose to set the viewport to be looking through that camera, click "play" and you would see the animation through the animated camera lens. Or choose to exit out of that camera into regular SU free cam mode, click "play" and you could watch all animated elements dance around, including the animated camera object, that is not being looked through.
              That is how other programs handle that I am aware of, and it is very succesful. Then you can create multiple cameras and animate them differently, export the rendered movie through various views. Even change the camera in the middle of the animation, so it is like cutting to another view like movies do all the time.
              But all this is dependent on having a way to visualize the animated objects in their animation paths, and alter their paths of animation easily. That is the point of keyframes. You select an object, put the timeline onto frame 1. Record a keyframe for the selected object. Then it knows exactly where it stands at frame 1. Then move the object to where you want it to be at a later frame. Maybe 5 seconds later. Put the frame onto frame 150, record the keyframe for that object and then the animation software interpolates all locations that the object will pass to get from frame 1 to frame 150. To edit the animation, you highlight frame 150, the object jumps to that location, you move the object to where you want it, re-record the keyframe and voi-la, the animation is updated.
              Its just a visualization techinue that makes animation easier to comprehend than pure xyz locations and vectors, which is a very rigid way to animation an object. In the end the software just needs to remember the xyz position and that is all it records, but keyframes help the user enter that data into the software.
              Gee I get excited thinking about it. It would be fairly easy to implement most of this over components and groups by animating their transformation matrix. But animating raw geometry is hard because SU does not keep objectID's across SU sessions. So it is very difficult to keep large amounts of data attached to raw geometry. It requires parsing the entire model and rebuilding that data each time the model is opened. Yeah, wow animating vertices is a monumental task...
              • chrisglasierC
                chrisglasier
                I am just suggesting animation can be another multimedia report machine-generated from the same data or criteria used for locating components and making Gannt and PERT charts ... as opposed to animation created with key frames for a video. So it would need to be restricted to animating components.
                For example, an animation of constructing a building over a year could be examined over different time periods and spans and react to input of data relating to start, completion and suspension. It only becomes fixed when the data is fixed - maybe never, if the model is passed on for use by the building owner.
                  MartinRinehart
                  Its just a visualization techinque that makes animation easier to comprehend than pure xyz locations and vectors, which is a very rigid way to animation an object.
                  Actually, it's a very flexible way to animate (tho maybe not so user friendly). Here's the actual flight.rb that did my first taxi/takeoff. Note the acceleration in the first ten seconds and the climb in the next 30 seconds.
                  # flight.rb
                  n
                  bp = i '/models/biplane'
                  none
                  for i in 1..5
                      m bp, [2*i, 0, 0], 2
                  for i in 6..20
                      m bp, [8, 0, (i/3-2)], 2
                  When I first "flew" my biplane, I stood at the origin and watched it fly away. Later I moved out to just before the end of the flight. A little spec took off from the airport; turned into a biplane as it approached and damn near hit me at speed. Very scary! Think Hitchcock.
                  I'm abandoning my Timer class (UI.timer-based, but Java-like, with start() and stop() methods and a Runnable object) because I want to have several things (including the camera) animated at once. Multiple timers will probably eventually get out of synch. It lived for less than 24 hours after it's first use. Sad.
                  I'm writing a Conductor class. Any object wanting to animate must register (before time 0) with the conductor (pass a reference to a callback) for a specific time interval. During that interval the conductor (again, UI.timer based, but only one timer) will pass frame ticks back to the registered object(s). What the object does is not the conductor's problem. (If your stupid anti-virus program starts a full scan in the middle of your animation, all animatees will be slowed together but will still be in synch.) Will fit very well with a timeline-based keyframe approach.
                  I loved Pixero's detailed UI design. Does anyone else have even a sketch? How about SketchUp as a UI modeling tool? How about a 3d UI? How about 3d camera(s) that you position/move around your model?
                  • chrisglasierC
                    chrisglasier
                    Somewhere amongst Martin's Uncle Holly speak you can find something sensible but contorted like: "During that interval the conductor (again, UI.timer based, but only one timer) will pass frame ticks back to the registered object(s)." This is better explained somewhere I can't find at the moment, but it's important. Will post again when found.
                      Jim
                      Why wouldn't you want to use Scenes to define the keyframes?
                      Our (vaporous) dialog would allow defining what happens to objects between the keyframes (scenes): sets the number of frames (or seconds), easings, etc.
                      But there is more types of animation than moving - what about rotation? color? model time (shadows)? focal length?, etc.
                      You do not want to just move objects, you want to animate the properties of objects (meant in a Ruby context.)
                      Properties include things such as .transformation of Groups, colors (.blend) can be animated, Page properties (i.e. fog). Any property in the SketchUp app for which setter and getter methods can be created can also be animated using the same framework; if the framework is written in a general way.
                      So if a Group has a .transformation (and matching .transformation=) property - you want to animate it's transformation as opposed to it's position. So an object needs setter and getter methods for the property to be animated. If they do not exists, they can be added to the object; as in the Camera; which for whatever reason lacks direct manipulation via a Transformation.
                      I posted a couple code snippets that are the beginnings of such a system: http://forums.sketchucation.com/viewtopic.php?f=180&t=25119
                        Jim
                        But please don't use timers - use the Animation class. Renderers already support it for rendering animations - I'm not sure they can hook into timer-based anims. My snippet in the previous post uses the Animation class.
                          For my usage - animation would only be relevant if it would be possible to render it.
                          • Chris FullmerC
                            How exactly do renderers work with object animation - like in Sketchyphysics? How can they capture that movement?
                            In my camera recorder script I ended up making a scene for each frame of the animation so that a renderer would be able to process scenes. But how can they use animation information? Is it something most of them have built in and it just a matter of writing the code according to their standards? Or do they have to implement object animation for each plugin that comes along and offers its own animation solution?
                            chris
                              Jim
                              I don't kow the answer to that. SketchyPhysics does use the Animation class, and I assume uses the physics engine to do the heavy calculations needed.
                              They must be able to hook into that animation from the c/c++ code, since there can only be a single animation active at a time.
                              • PixeroP
                                Pixero
                                I see two different ways to do animation in SU. Both good in their own way:
                                1. Fly around in realtime with something like LightUp's Tourtool mixed with Chris Fullmers Record camera. Then enhanced with a way of manually adjusting curves to reposition camera/object.
                                2. Keyframe based animation with a timeline. Maybe a tool to drag and rotate the camera to the right position. A bit like the walktool but dragging instead of pushing the camera for better control. Maybe even adjustable curves in the UI like most animation software have. (I know you can draw curves like that with javascript.)
                                • chrisglasierC
                                  chrisglasier
                                  Looping: Single vs. Multiple vs. Fixed Timelines, amongst other things.
                                  Also the demo - Click and drag to create more.
                                  • chrisglasierC
                                    chrisglasier
                                    Sorry I missed this probably because of the vapor pouring from my brow.
                                    The dialog basically deeply nests components and scenes in multiple collections, and records what components appear in what scenes, purchase orders and so on. All of this I am sure could be helpful in creating a conventional animation, but what I am more interested in is using it to create "living" 3D reports. Imagine a project manager having an automatically updating AR model sitting on his desk instead of huge piles of drawings, site reports, change orders and so forth.
                                    So I shy away from keyframes - not because I think they are wrong but because I want to see how far I can get towards what I described.
                                      MartinRinehart
                                      I've got my Conductor running. He's Timer based. I'll see if I can switch him to Animation.
                                      He calls the run() method of objects that register during an interval they request. What your object's run() does is up to your object: move, rotate, scale, fly, explode ...
                                      I've had nothing but issues with materials. Do simple colors work w/o Bug Splats?
                                      • Chris FullmerC
                                        Yup. I use colors in many scripts and I've never plsatted from them. Though I've never had a texture splat on me either, so it might just be a workflow thing?
                                          MartinRinehart
                                          Thanks. We're off topic. I'll reraise this as Wood Cherry Original.
                                            I remember from another thread that you demonstrated that you used entity.material = 'materialname', correct? Have you tried instead doing entity.material = model.materials['materialname']
                                            I've also never had problems working with materials, textured or not, in SU ruby.
                                            • 2 / 3
