    Vue 7 Infinite
    extensions
    77 Posts 17 Posters 19.4k Views 17 Watching
    • H Offline
      hombre
      @solo said:
      I see you use 3DS MAX and SU Podium as well.
      Yup, I use a few other apps too like Z-brush, C4D, Hexagon, Maya, Shade, Bryce, Silo, (learning Modo), etc.
      Solo, ...what would you use Bryce for that Vue cannot do?
      • soloS Offline
        Bryce was my stepping stone to Vue, unfortunately Bryce has not been updated and advanced at the same rate as Vue, I blame DAZ for that, same way as they let Poser advance beyond them.
        But every now and again it's fun to play with, it is fast and easy, that's about all.
        • Horseman04H Offline
          Horseman04
          Well, this seems to be the place to ask questions about Vue so...
          I've browsed these forums for some time, but this is my first Post here. I work as an Architect and have been using Artlantis for about 2 years now. I recently got Vue and have used it to make various scenes and interesting backdrops, but as far as anything architectural I have done nothing, mainly due my fondness of Artlantis. I have dabled in 3DS Max and found it to be overwhelming, but I do love the vast array of Shaders that can be used in it. I'm growing increasingly aware of my program's shortcomings, the inability to do complex landscapes, and am looking to bridge the gap with VUE...
          So my Questions to the more experienced people
          What Format are VUE Shaders in?
          Can I Use .max Textures from 3DS?
          If so, how and where do I install them to?
          • pugz1983P Offline
            pugz1983
            Hi Everybody,
            I'm looking into Vue because i've always loved the way Vue renders. I was wondering if there are any tutorials of Vue in combination with sketchup? Is it possible to use ecosystem on a specific part of a plane. For example only ecosystem on grass patches of the plane?
            Greetz from Holland.
            • H Offline
              hombre
              Thanks Solo!
              I saw that Bryce was on sale over the holidays but I didn't see anything there that I didn't already have with Vue.
              I see that you also use Podium. Have you used IRender or Twilight yet? If so, how would you compare them with Podium?
              • soloS Offline
                I have indeed got Twilight, Irender, Podium, and a bunch of others too. It's difficult to make comparisons, firstly as a moderator it would show a bias and secondly they all have their strong and weak points.
                It depends on what you are looking for in a render solution, being a Vue user I would assume you are in need of a good interior render solution right?
                I suppose the best way and the only way one can make comparisons is by features, ease of use, etc. But this alone is only academical which will give you facts but not answer the question, so I will maintain what I have always said, try before you buy, they all have demo/trial versions so play and see which one works best with your workflow and your needs.
                Sorry I cannot give a definitve answer.
                • H Offline
                  hombre
                  A NEW question:
                  Is it possible to make a texture/bump map for use in Vue from one of the Sketchup textures, brick for example?
                  ...so that one could simply color in Sketchup, and apply the appropriate bump map in Vue without making a complete change of materials once the object file is in Vue?
                    And to go along this line - save these tweaked materials in Vue (gradually build up a material library there)?
                    • H Offline
                      hombre
                      Done figgered this one out....
                      When you export a SKP file as an OBJ file, it also makes a .jpg image of each texture. You can then take the jpg texture into Photoshop and make a high contrast bump map out of it that fits like a glove.
                      My biggest issue is with exporting/importing. I've tried at least 6 methods by others I've read about, but all have had their own serious drawbacks with issues of scaling, leaving out information, or creating a zillion different meshes that are impossible to sift through in order to alter their materials...within a lifetime that is. A Chipp Walters method looked really good with a rubyscript plug in exporter, but it consistently lost information in the process. Maybe all this stuff works better on a PC and I'm a MAC guy...but I saw Solo complaining about the million mesh issue somewhere here too. The scaling issue is also compounded by the fact that there is no internal measuring tool within VUE to actually scale things by: it's this eyeballing game, and when all of the various types of models are imported into Vue, each one comes in differently. It's like this constant game of resizing HO trains onto a Lionel track, or vice versa. I'm kinda surprised that such a simple concept has not been taken into consideration when the program is really stellar. BTW: what size are those grid squares supposed to be in Vue anyway? That MIGHT help if I knew what those are, but a search of the manual and google turned up zilch.
                      • Chris FullmerC Offline
                        THey are in 10m grids by default I think. Go to File > Preference > Units and then change your settings there. I took a while to play around with settings and finally once I got it right, many things in VUE worked better.
                        • pugz1983P Offline
                          pugz1983
                          Hi Everybody,
                          I recently started to take a look at Vue. I think the workflow from SU to Vue is realy easy. First use plugin called View to Vue, then export model as OBJ. In Vue import model -> edit object-> weld and split ( then you get a list of materials by name. Then load the exported camera view as a Phyton script.
                          Al materials you make in Vue can be saved to make your own collection. I you're interested in Vue, check outy the tutorials at Geek at Play.
                          • H Offline
                            hombre
                            Thanks everyone for your interest and help!
                            @pugz1983 said:
                            ..... I think the workflow from SU to Vue is realy easy. First use plugin called View to Vue, then export model as OBJ. In Vue import model -> edit object-> weld and split ( then you get a list of materials by name.
                            Where is the plug in: 'View to Vue?, I have searched and not found it.
                            I am not sure of what they are. According to my default preferences, they are supposed to be 1 meter, but I am on a MAC..whatever. Changing those defaults for the grid doesn't really do anything to the grid for me: everything I import in, still stays the same scale relative to the grid. I'm using Vue 7.5 infinite.
                            ..but forget the scale for a moment and take a look at these examples:
                            I downloaded a random car from the 3D warehouse, and exported it using the same scale settings in Sketchup, and imported using the same scale settings in Vue.
                            In the first pic, the native Sketchup exporters ( Collada and Obj ) worked flawlessly, however each exported in a different scale. The issue with both of these Sketchup exporters is that they break down the model into 'meshes' instead of 'materials', which means that on this particular model, I end up with 114 meshes for the Obj export and 135 meshes for the Collada. From theer one has to go searching through to find whatever 'part' one needs to alter the attributes of, so then if one simply wants to alter the reflectivity of the body color, one ends up having to sift through all of these 'meshes' to find the appropriate ones and alter a dozen or more different 'meshes' to make that change. Dittos for any other material. So that method while being an accurate translation from the Sketchup model, becomes incredibly burdensome to deal with. I have found however, that in native Sketchup models that I produce, if I explode all components before exporting, I end up with a 'color/material' set, instead of 'meshes'. I wonder if the models ( like cars etc. ) at the 3D warehouse, were produced in other programs and exported into Sketchup and this is what is creating the problem.
                            In the second pic, I have used the objexporter.rb plug in from Chipp Walters site, which has consistently produced random and bizarre occurrences, though it splits the model into materials instead of 'meshes' which ends up being great for finding things, but the aberrations are unacceptable. I have watched his video a dozen times and it works for him..but then again, maybe it's the whole PC/MAC issue.....I don't know.
                            If anyone has a clue as to dealing with these issues......please help: I need something with the accuracy of the native Sketchup exporters, yet the simplicity of the ruby exporter.
                            • soloS Offline
                              Can you give link to the model in warehouse. I will give it a go on my side.
                              • soloS Offline
                                Nevermind I typed 'car' and it was the third in line.
                                The model was a little screwed up, I used the 'cleanup' ruby to fix it.
                                http://img37.imageshack.us/img37/9793/pancakes1.jpg
                                I then used straight up .3ds export from SU and opened it up with vue.
                                I welded in Vue and split by materials.
                                http://img691.imageshack.us/img691/2092/suvueimage.jpg
                                Then a quick render with basic mats.
                                http://img39.imageshack.us/img39/6688/whcarinvue.jpg
                                  Look like it worked "ok" then 😄
                                  • H Offline
                                    hombre
                                    Thanks Solo: YOU DA MAN!
                                    That is AWESOME!
                                    I thought that perhaps the model was suspect in that case, but I've had problems with the objexporter.rb with a VERY simplistic model that I made for playing with textures of a brick wall, and others as well.
                                    How did you know WHERE it was messed up, when it looked clean in Sketchup?
                                    ~ and:
                                    Where do I find the 'cleanup' ruby that you're talking about?
                                    Thanks for your help and answering what are probably stupid questions, but someone else besides me will read these too...and I won't feel like such a lonely klutz.
                                    • soloS Offline
                                      Here is the cleanup ruby.
                                      404 Not Found
                                      (forums.sketchucation.com)
                                      I use this ruby for every model I import (unless I made it and it's already clean)
                                      • H Offline
                                        hombre
                                        Thanks again...you're a great asset to this forum.
                                        • H Offline
                                          hombre
                                          Question 3,010.
                                          ...related to the last issue that you solved poste haste, I have a question that is similar but more detailed.
                                          Here is a model I got from the 3D warehouse.
                                          Error 404 (Not Found)!!1
                                          (sketchup.google.com)
                                          It is a very nice model. I renamed few colors for my own simplicity, used the cleaner you recommended and brought it into Vue.
                                          http://i39.photobucket.com/albums/e175/dubelu/OpelZafira.jpg
                                          Once I got it into Vue, I welded and split it and found that I had a problem with the tires becoming one material with the wheels, though each were separate components in the model, with separate colors and names.
                                          http://i39.photobucket.com/albums/e175/dubelu/OpelZafira2.jpg
                                          I went back to the Sketchup model, and opened up the components to check them and found that they were OK. Then I decided to see if anything was inside out. SURPRISE! Almost the whole model was inside out. I thought that I'd just forget about it and dump it, but it's a nicely done minivan model, and I thought I'd bite and go back and laboriously reverse each material, recolor and rename. Well, I started on one of the evil wheels, reversed it, but the 'good side' wouldn't take color. HUH?
                                          http://i39.photobucket.com/albums/e175/dubelu/OpelZafira3.jpg
                                          So I dunno. What would you do to make this model right?
                                          Will the cleanup ruby work magic on this in a way I don't know, or is it a lost cause?
                                          • soloS Offline
                                            There is a reverse face ruby available someplace, I never use it as I normally model with faces the right way round or I use Deep exploration (an expensive 3rd party app) to clean and reverse normals of imported models.
                                            • 4 / 4
