    How to remove lines?
    3 Posts 3 Posters 2.5k Views 3 Watching
      Sigitas
      In modėl style line is off but i see them in exported picture.
      • Chris FullmerC Offline
        That is a known bug unfortunately. It was fixed in version 7.1 (which I did not know until right now when I went to test it). Or at least, I can not reproduce it in 7.1, but I was able to reproduce it in 7.0 just fine.
        The problem is that you have selected hidden line mode, which turns all faces white. Thne you turned off lines. In SU it displays properly, but it exports with lines still on. Which is what you are seeing. The fix is to use the rendering mode "Display Shaded All Same". Then change your front and back face colors both to pure white. Then turn off your edges. And make that a new style. Then it will export correctly. For some reason using hidden line mode will always always export the edges on. But the workaround does work just fine. Hope that helps,
        • juan974J Offline
          juan974
          hello,
          did you try to turn edges quite white (1 or 2 on rbg scale) ?
          juan974 (Réunion island)
          website : http://sketchucation.com/click.php?url=http://www.tarn.us
