Wrong export to PDF
Hi all
I'm a student architect
I'm new in this community, but I learn a lot from
you all, just from reading the "topic"
I have a proplem, when I export leyout to PDF file
all the text shows mirror, I'm writing in Hebrew
this problem was also on My Autocad but i fix it
with special font,
do any of you know any Heberw font to fix this problem?thanks a loot
itzko
Hi Itzko,
Are you typing your text into LayOut or importing it from an external file?
(You can "insert" rtf files into LO just like SU models or images).What happens if you use this method?
thanks gaieus
I'm typing the text direct to LO
I'll try to insert rtf file to LO
& will see if it's OKthanks
itzko -
I'm seeing it, too, using Arabic or Hebrew. Inserting an RTF doesn't change it. PC only, Mac is OK. Filing a bug. Thanks. The not-very-good workaround would be to output to output a page to a png file, then insert the png image into PDF. Or get a Mac.
b
To add to Bjanzen's list of possible workarounds, you could try printing to PDF with Adobe Acrobat or another PDF printer driver (even free or low-cost ones can be found). Cheaper than a Mac...
Anssi
Thank you Ansi. BullZip and the import text as curves worked well.
