    Slow moving programme
    14 Posts 2 Posters 817 Views 2 Watching
      shamrocknumber1
      I have been using sketch up for a few years now but am having problems with my current model. I have an autcad map with extruded buildings and some components which i have downloaded but grouped them to keep the file size smaller and run faster. Unfortunatly this hasnt been the case, Im regularly getting a non responsive programme and things take a long time to do in the model. What can I do to make the programme run smoother and quicker?
      • GaieusG
        Hello and welcome!
        There are quite a few component in the warehouse that are very heavy and slow SU down considerably. What components did you insert into your file?
        • GaieusG
          Well, I don't know (this doesn't sound to be too complex). What are the stats of your model? See Window > Model info > Statistics and make sure nested components is checked.
          Also, are there too heavy images among your textures?
            shamrocknumber1
            Thanks for your reply!
            It was a construction I beam from the online 3d warehouse...?
            What can I do to make it move quicker?
              shamrocknumber1
              Stas: edges 280351... so I presume thats my problem...too many edges in the components which Ive duplicated in the model?
              • GaieusG
                Well, that's not a small number but I have models with edges exceeding a million.
                Can you put your parts you don't currently work on onto layers that you can hide? Also turn off shadows.
                  shamrocknumber1
                  yeah ive cleared as many layers as possible or combined them,I actually only have 9 layers now. But it seems to be that the layer with the grouped components kills the model
                  • GaieusG
                    And what is the file size?
                    Also, are these components nested in several levels deep?
                      shamrocknumber1
                      the file size is 3.21 MB. I think I may have copied the component out several times then grouped them. I suppose the best thing to do is explode the whole lot of them and remake them 1 large component? as opposed to a component of any components?
                      • GaieusG
                        No, keep the components components. Maybe you do not need them grouped (you can explode that group) but that should not really cause this either.
                        Have a look at this hardware spped test:
                        http://forums.sketchucation.com/viewtopic.php?f=72&t=20076
                        what results do you get?
                          shamrocknumber1
                          Results are:
                          72 frames displayed in 6.061 seconds
                          average frame 0.084 seconds
                          11.9 frames a second....?
                          • GaieusG
                            Well, those were kind of average results until SU 7.1 came out. Then this started to be the case:
                            http://forums.sketchucation.com/viewtopic.php?p=186396#p186396
                            What are your computer specs? Mainly processor and video card?
                              shamrocknumber1
                              i think the video card is 1gb and the system is 283 gb, 64 bit windows vista and 4gb of ram as far as I can remember. It wont allow me download that file, i dont have enough privilages apparently?
                              • GaieusG
                                You should be able to download it. What is the card brand and the processor speed?
