    All Ancient Rome models from 3DWarehouse together
    167 Posts 26 Posters 54.9k Views 27 Watching
    • michaliszissiouM Offline
      michaliszissiou
      This is a great thread, a ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ to all of you.
        L.VII.C
        I made in my models the total update, hard work, took a few days ๐Ÿ˜„
        I have changed everything textures. Many thanks to rev3rse again for the texture link ๐Ÿ‘
        I ask all, download my models again
        Error 404 (Not Found)!!1
        (sketchup.google.com)
        • Z Offline
          Z-Akh69
          Hello,
          I'm French and i studiying roman architecture since several months.
          First, i congratulate you for your wonderful models !
          I am fascinated by old architecture and I have already made a model of architectural complex of Pharaoh Sahure to Abusir. I also started to model Persepolis since winter 2008 but never finish.
          Here are some pictures of my work :
          http://img683.imageshack.us/img683/7697/complexedesahour.jpg
          http://img3.imageshack.us/img3/5766/complexedesahour33.jpg
          http://img693.imageshack.us/img693/4672/perspolis4.jpg
          Your models are very interesting but do not have the right proportions. I have studied many texts and also Vitruvius. His formulas do not work for all but we can get some interesting values such as intercolumniation or height of columns depending on the type of building.
          I set some rules for obtain a building with harmonious proportions. This one tries with the Temple of Vespasian :
          http://img3.imageshack.us/img3/6557/templedevespasien5.jpg
          You must first determine the proportions of columns and entablature.
          The entablature of Vitruvius is not appropriate for a Roman temple. However, you can follow his instructions for the Corinthian column.
          For the entablature, I advise you to refer to the Corinthian order of Vignola.
          I do not find attractive method for determining the angle of the pediment or values stylobate and stairs.
          Next, you must consider the values between the columns proposed by Vitruvius and height of columns that refers to each of them.
          ๐Ÿ˜Ž
            Hi Z-Akh and welcome with these nice models!
            As for Vitruvius, I find that his proportions are often just an idealised "average" of what should be built but individual buildings (especially in the provinces) are only more or less following those "ideas" rather tan strictly following them as true canons (and then there is also the time span of several hundred years during which many things changed).
            Nevertheless, theoretically speaking, SketchUp is indeed an ideal tool to study these canons and see how they would work in practice.
            • E Offline
              ELYSIUM
              I agree with Gaieus.
              Forget about Vitruvius!! lolol the ten books are greatly overrated. ๐Ÿ˜†
              Its a great source for understanding ideal roman architecture, but it has a lot of trouble when applied to real life and real buildings
              The books are really poorly written, Greek mixed with Latin, invented words, missing parts, no mention of engaged columns and orders..... some buildings described are impossible to build because he sets contradictory rules and proportions, the list of mistakes goes on and on...,
              And like Gaieus pointed out the books were written in the start of Augustus reign, the empire lasted for 400 years after that!
              Its really hard to find a roman building that fits in Vitruvius understanding of rules and proportions. Like for example the Panteon! does it fit Vitruvius? no way...
              The Ten Books are just a set of principles for ideal architecture, donยดt try and fit everything in it. ๐Ÿ˜„
              Post Scriptum: Great images, can you show us more???
              • Z Offline
                Z-Akh69
                I agree with you. Vitruvius should be used to understand some basic principles.
                For example, for values of intercolumniation: Vitruvius gives us values such as 1.5 d (diameter) for Pycnostyle or 2 d for Systyle.
                The architect is free to choose the value which is more harmonious. It can also make an average. This applies to the "square house" of the city of Nimes in France : The values of intercolumniation is an average between Pycnostyle and Systyle.
                For column, I am guided by Vitruvius because Vignola's corinthian column seems disproportionate.
                The capital is too high and the base too narrow. The height proposed by Vignola is also too high. (Vitruvius also said that for Pycnostyle the height of the column should be 10 d, it is also impossible).
                I'll post more images later. ๐Ÿ˜‰
                • Z Offline
                  Z-Akh69
                  I tried to render L.VII.C's model with Twilight render.
                  Even without good proportions, is already beautiful!
                  http://img705.imageshack.us/img705/3725/97032611.jpg
                  http://img696.imageshack.us/img696/4551/64398806.jpg
                  http://img706.imageshack.us/img706/9383/98337712.jpg
                  ๐Ÿ˜„
                    L.VII.C
                    Hi Z-Akh69
                    Your models are great ๐Ÿ‘ . It would be interesting to examine them in 3D mode.
                    Thank you very much for rendering my forum. So it looks better than it is really ๐Ÿ˜„
                      Aerilius
                      great render!
                      (@L.VII.C:) The light blots on the base of the column and below the statue on the left could be caused by either totally white (rgb=255,255,255) or untextured faces. Also make sure that the faces show the frontface (in monochrome face style, the blueish color means the backface and white means frontface). I also struggled with this in one of my monastery renders but I'm sure it can be solved ๐Ÿ˜‰ .
                      I keep my eyes open, because the last thing we need are people. Plebeians and patricians, Cicero and senators... Maybe there are some good movies in tv these days, where I can catch some people...
                        L.VII.C
                        Aerilius
                        great render!
                        (@L.VII.C:) The light blots on the base of the column and below the statue on the left could be caused by either totally white (rgb=255,255,255) or untextured faces. Also make sure that the faces show the frontface (in monochrome face style, the blueish color means the backface and white means frontface). I also struggled with this in one of my monastery renders but I'm sure it can be solved .
                        About the right locations of white faces in monochrome mode, earlier to me has specified pichuneke. Since then I try to avoid mistakes. But unfortunately, in my models a lot of blue faces ๐Ÿ˜ž In this respect completely correctly made only 4 models: tabularium, mausoleums of Augustus and Hadrian and Severus arch. While working on the model of Forum Romanum, I turned the vast majority of blue faces, but surely they still have ๐Ÿ˜ž
                        • Z Offline
                          Z-Akh69
                          Hi everyone,
                          I'm rendering with the demo of Twilight:
                          http://www.twilightrender.com/
                          Today I worked on the proportions of the Corinthian columns but I am not satisfied with the result.
                          I finally chose Vignola base while keeping the height prescribed by Vitruvius for the capital.
                          I removed the bulge and I try to get the right height for the entire column.
                          I already posted my work here:
                          http://www.escargot-archi.eu/forum/viewtopic.php?f=30&t=3410
                          ๐Ÿ˜Ž
                          • DanikD Offline
                            Danik
                            Hi to all!
                            I've finished my new model - baths of Caracalla.
                            The general view:
                            http://www.picatom.com/17/1-3857-th.JPG
                            http://www.picatom.com/17/2-2511-th.JPG
                            http://www.picatom.com/17/3-1483-th.JPG
                            http://www.picatom.com/17/4-1024-th.JPG
                            http://www.picatom.com/17/5-742-th.JPG
                            http://www.picatom.com/17/6-564-th.JPG
                            The great hall:
                            http://www.picatom.com/17/1-3858-th.JPG
                            http://www.picatom.com/17/2-2512-th.JPG
                            http://www.picatom.com/17/3-1484-th.JPG
                            http://www.picatom.com/17/4-1025-th.JPG
                            http://www.picatom.com/17/5-743-th.JPG
                            http://www.picatom.com/17/6-565-th.JPG
                            Frigidarium:
                            http://www.picatom.com/17/1-3859-th.JPG
                            http://www.picatom.com/17/2-2513-th.JPG
                            http://www.picatom.com/17/3-1485-th.JPG
                            [url=http://www.picatom.com/17/4-1026.html:13o7zaq4][img:13o7zaq4]http://www.picatom.com/17/4-1026-th.JPG[/img:13o7zaq4][/url:13o7zaq4]
                            Tepidarium:
                            [url=http://www.picatom.com/17/1-3860.html:13o7zaq4][img:13o7zaq4]http://www.picatom.com/17/1-3860-th.JPG[/img:13o7zaq4][/url:13o7zaq4] [url=http://www.picatom.com/17/2-2514.html:13o7zaq4][img:13o7zaq4]http://www.picatom.com/17/2-2514-th.JPG[/img:13o7zaq4][/url:13o7zaq4] [url=http://www.picatom.com/17/3-1486.html:13o7zaq4][img:13o7zaq4]http://www.picatom.com/17/3-1486-th.JPG[/img:13o7zaq4][/url:13o7zaq4] [url=http://www.picatom.com/17/4-1027.html:13o7zaq4][img:13o7zaq4]http://www.picatom.com/17/4-1027-th.JPG[/img:13o7zaq4][/url:13o7zaq4]
                            Caldarium
                            [url=http://www.picatom.com/17/1-3861.html:13o7zaq4][img:13o7zaq4]http://www.picatom.com/17/1-3861-th.JPG[/img:13o7zaq4][/url:13o7zaq4] [url=http://www.picatom.com/17/2-2515.html:13o7zaq4][img:13o7zaq4]http://www.picatom.com/17/2-2515-th.JPG[/img:13o7zaq4][/url:13o7zaq4] [url=http://www.picatom.com/17/3-1487.html:13o7zaq4][img:13o7zaq4]http://www.picatom.com/17/3-1487-th.JPG[/img:13o7zaq4][/url:13o7zaq4] [url=http://www.picatom.com/17/4-1028.html:13o7zaq4][img:13o7zaq4]http://www.picatom.com/17/4-1028-th.JPG[/img:13o7zaq4][/url:13o7zaq4]
                            Palestra
                            [url=http://www.picatom.com/17/1-3862.html:13o7zaq4][img:13o7zaq4]http://www.picatom.com/17/1-3862-th.JPG[/img:13o7zaq4][/url:13o7zaq4] [url=http://www.picatom.com/17/2-2516.html:13o7zaq4][img:13o7zaq4]http://www.picatom.com/17/2-2516-th.JPG[/img:13o7zaq4][/url:13o7zaq4] [url=http://www.picatom.com/17/3-1488.html:13o7zaq4][img:13o7zaq4]http://www.picatom.com/17/3-1488-th.JPG[/img:13o7zaq4][/url:13o7zaq4] [url=http://www.picatom.com/17/4-1029.html:13o7zaq4][img:13o7zaq4]http://www.picatom.com/17/4-1029-th.JPG[/img:13o7zaq4][/url:13o7zaq4]
                            Other interiors were also made and textured
                            Download link: [url:13o7zaq4]http://www.filefront.com/15236645/BATHS OF CARACALLA.skp[/url:13o7zaq4]
                              Hi Danila,
                              Downloading...
                              From the images, it seems to be an amazing model. ๐Ÿ‘
                                Aerilius
                                fantastic!!!
                                I always wonder from where you get info about the interior design...
                                By the way (don't take it amiss! it is already more than perfect), if you want to avoid repetition, you can randomly rotate the column components around 90ยฐ or flip them.
                                • Z Offline
                                  Z-Akh69
                                  ๐Ÿ˜ฎ
                                  • DanikD Offline
                                    Danik
                                    Some screens of other interiors:
                                    http://www.picatom.com/17/1-3863-th.JPG
                                    http://www.picatom.com/17/2-2517-th.JPG
                                    http://www.picatom.com/17/3-1489-th.JPG
                                    http://www.picatom.com/17/4-1030-th.JPG
                                    http://www.picatom.com/17/5-744-th.JPG
                                    http://www.picatom.com/17/6-566-th.JPG
                                    http://www.picatom.com/17/7-443-th.JPG
                                    http://www.picatom.com/17/8-390-th.JPG
                                    http://www.picatom.com/17/9-315-th.JPG
                                    http://www.picatom.com/17/10-288-th.JPG
                                    http://www.picatom.com/17/11-546-th.JPG
                                    http://www.picatom.com/17/12-448-th.JPG
                                    http://www.picatom.com/17/13-248-th.JPG
                                    http://www.picatom.com/17/14-201-th.JPG
                                    http://www.picatom.com/17/15-186-th.JPG
                                    [url=http://www.picatom.com/17/16-159.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/16-159-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/17-139.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/17-139-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/18-118.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/18-118-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/19-111.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/19-111-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/20-133.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/20-133-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/21-169.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/21-169-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/22-214.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/22-214-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/23-133.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/23-133-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/24-85.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/24-85-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/25-87.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/25-87-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/26-77.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/26-77-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/27-77.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/27-77-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/28-79.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/28-79-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/29-65.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/29-65-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/30-71.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/30-71-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/31-74.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/31-74-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/32-79.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/32-79-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/33-112.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/33-112-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/34-64.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/34-64-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/35-62.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/35-62-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/36-55.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/36-55-th.JPG[/img:2ygf9ust][/url:2ygf9ust] [url=http://www.picatom.com/17/37-51.html:2ygf9ust][img:2ygf9ust]http://www.picatom.com/17/37-51-th.JPG[/img:2ygf9ust][/url:2ygf9ust]
                                    Also the model is presented in 3D Warehouse ๐Ÿ˜„
                                    [url:2ygf9ust]http://sketchup.google.com/3dwarehouse/details?mid=4aeaf6da14d9c5a1288ed9bca759b0ad[/url:2ygf9ust]
                                      pichuneke
                                      ยกยกยกDios mio!!!
                                      Forgive my spanglish...
                                      • DanikD Offline
                                        Danik
                                        Some renders of the baths made in Kerkythea:
                                        http://www.picatom.com/18/3-1496-th.jpg
                                        http://www.picatom.com/18/5-750-th.jpg
                                        http://www.picatom.com/18/6-571-th.jpg
                                        http://www.picatom.com/18/7-448-th.jpg
                                        http://www.picatom.com/18/9-316-th.jpg
                                        http://www.picatom.com/18/10-290-th.jpg
                                        http://www.picatom.com/18/11-551-th.jpg
                                        http://www.picatom.com/18/12-449-th.jpg
                                        • Z Offline
                                          Z-Akh69
                                          Marvelous ! ๐Ÿ‘
                                            sketchup_fan
                                            Beautiful, the only thing that is missing is the parking lot for the horses and the carriages. ๐Ÿ˜†
                                            • 4 / 9
