    Rounded quality...
    21 Posts 7 Posters 2.7k Views 7 Watching
    • GaieusG
      Hi Venedesign (or dddd ๐Ÿ˜‰ )
      As for Profile Builder - well, indeed, it does what Follow me does - just a very advanced and "professional" way (like you can always edit the path as well as the profile, its position etc. afterwards...). So you can also use the Follow me tool.
      As for the default segment count...
      Above, you learnt how to increase it. I would suggest to use multiple numbers of the default 24 (like 48 or 72 or 96...) because that will come handy when you need to divide it or align objects to the segments.
      You will also notice that once you change the segment count in the Measurement box (by typing "say" 48s for a circle), it will remain the 2default" for that modelling session (until you close/restart SU - or change the segment count again).
      So although you cannot change it in Preferences or such for every session, at least you need not keep changing it for every circle while modelling.
      And as Simon also said. cool models!
      ๐Ÿ‘
      • V
        venedesign
        Thank you all for your little explanations and comments on my first reports, it's nice of you!
        I had never done 3D modeling in my life and I'm set there is only 1 month, and I can do without now ๐Ÿ˜„
        For my profile, I do not like to reveal too much information about me on the web ...
        To continue our little conversation, you know a topic that contains all the little tricks to know for Sketchup? Or do you have any important tips for me?
        Finally, I work with HyperShot rendering software is really user friendly, the only complaint and it does not yet support the light management and ies file ... ๐Ÿ˜’
        I tried to put myself in Vray, but this software is a nuclear power plant by itself! Yuck!
        • GaieusG
          There is a "beginners tips" sticky post in the newbie forum:
          http://forums.sketchucation.com/viewtopic.php?f=79&t=12706
          It's a useful reading I guess.
          • V
            venedesign
            Yeah, that's exactly what I was looking for!
            I still ask myself some questions,
            How to apply correctly a texture on SketchUp with complex shapes?
            Why have the pro version of sketchup rather than the free version?
            • C
              chrisjk
              Your circles may be rough but I like your rendering - what did you use?
              Just one word of warning re using many segments for circles. Depending how you use them, I have found it all too easy to make a very heavy model when using a number like 96 segments. For example I used such a circle to cut a multitude of holes in a component and all those faces added up to over a 1MB in no time.
              • V
                venedesign
                Thank you for your warning, in fact I think we should find a good compromise and increase the quality of rounded edges on the most important side
                For the record I said above, I use HyperShot ๐Ÿ‘
                • GaieusG
                  Could you attach your example file?
                  So I mean would it be something like this in your case?
                  Projected.skp
                  • V
                    venedesign
                    I just want to know today the best way apply correctly a material on a complex shape ?
                    Has you know Sketchup dont like the complex shape and do anything with my texture ! ๐Ÿคฃ
                    exemple :
                    So please Sketchucation, give me my christmas gift, tell me the solution ๐Ÿ˜†
                    See you
                    • V
                      venedesign
                      My test file are too big... I do not know why because I have purged ... and it's take 9.82 mb ๐Ÿ˜ฎ
                      So I attach another exemple
                      exemple uv mapping2.skp
                      Ps: I've made the shape with soap skin bubble plugin
                      • GaieusG
                        This is done by Projecting the texture on the surface:
                        Watch this vido for ideas
                        [flash=425,344:20hld5r8]http://www.youtube.com/v/HHsRRLCAOm8&hl=en_US&fs=1&[/flash:20hld5r8]
                        If you go to Edit > Unhide > All in your model attached below, you can see the simple, flat face I used to apply the texture on and then turned it into projected, sampled and applied on your mesh.
                        Note that you need to explode yyour group OR edit it because it only works on pure (sur)faces, not groups/components.
                        • V
                          venedesign
                          Ohh yes that work really good !
                          I know again a new technique today with sketchucation , thannnkkkssss !! ๐Ÿ‘ ๐Ÿ˜„
                          • GaieusG
                            Note however that this is really like "projection" - so if the curved shape curves too much (towards the sides like a cylinder for instance), you will have distorted images. It is best when most of your surface is more or less perpendicular to the direction this projection is coming from.
