๐Ÿค‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[REQ] Mix plugins to make windows better
11 Posts 4 Posters 2.1k Views
    bagatelo
    I would like to mix the functionalities of a plugin with the ones of other, both make similar tasks. If possible, to increase some functions.
    I like the window that plugin make: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/windows.rb
    I adapted him, and I made some alterations, me leaning that this makes a better window.
    However I find a little boring to have to be measuring the wall for then to fill out in field with data of dimensions of the window that I want.
    In that aspect, I find very interesting the possibility to supply the dimensions of the window for simply to click in three points, as that plugin: http://forums.sketchucation.com/viewtopic.php?f=180&t=14394
    Could anybody alter plugin of the @ last to catch dimensions of the window for three clicks how the plugin of doing windows of TOMOT?
    If it was possible to increase the possibility already to create the glasses and the number of the leaves of the window, this would be interesting.
    Please notice the differences in the window that produces the plugin that I altered, and the original. Try!!!
      toxicvoxel
      What could be useful is if there was a generic lib for a series of GET functions (getPt, getPts, GetAngle (with protractor), getDistance, getpath etc.) that could be used by all developers in a consistent way to return select input to functions and dialogs.
        bagatelo
        I trying to do make myself what I want for this situation, and Sketchup has show me crazy behavior. When I write, for exemplo, 2 * 200, sketchup does not show me 400 as result, but 508. I think Sketchup thinks "2" is inches, not units. What is happening?
          Sketchup's internal units are inches. Always. But 2 * 200.mm ๐Ÿ˜‰
            You seem to use a lot of global variables? Any reason for that? could potentially cause conflict.
            But globals aside:
            Sketchup uses inches internally. It assumes that all numbers given is in inches.
            If you type 200 - then SU assumes 200 inches. If you want it to be in mm - then you must type 200.mm
            The numeric class has several methods to convert to and from different units: http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/numeric.html
            When you type 200.mm - then you get a variable of the Length class: http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/length.html
            ` x = 200.mm
            7.8740157480315
            x.to_mm
            200.0`
            So you must ensure that at any point, all variables that refer to a measurement unit - that it's made into a Length class so that the unit is represented in SU in inches.
              ` wglass = (200.mm - ((8.mm) + ( 1.mm) + (6.mm))) / 3
              2.42782152230971
              wglass.to_mm
              61.6666666666667`
                bagatelo
                I make some improvements in the plugin. Now this is more usefull.
                WindowTools.zip
                  bagatelo
                  Thank you for the answer
                  If I have :
                  $larguraVIDRO = ($larguraJANELA - (( 2 * $larguraFORRA) + ( 2 * $afastaFOLHAS) + ( $larPERFIL * ( $numePORTAS - 1 )))) / $numePORTAS
                  UI.messagebox $larguraVIDRO
                  what means:
                  wglass = (200 - (( 2 * 4) + ( 2 * 0,5) + ( 3 * ( 3 - 1 )))) / 3
                  wglass = (200 - ((8) + ( 1) + (6)) / 3
                  wglass = 61,6666 >>>> this is result that I want, but the Script show me 24.75....
                  How can I correct this expression so that it presents me the correct result?
                  Thanks anyway...
                    DIEGO-RODRIGUEZ
                    hi. thanks for your plugins.
                    But the first two tools do not work.
                    could repair it?
                    Error: #<NameError: uninitialized constant WindowTools::Jaluminio>
                    C:/Archivos de programa/Google/Google SketchUp 6/Plugins/WindowTools.rb:24
                    Error: #<NameError: uninitialized constant WindowTools::FOLHAALUMINIO>
                    C:/Archivos de programa/Google/Google SketchUp 6/Plugins/WindowTools.rb:31
                    C:/Archivos de programa/Google/Google SketchUp 6/Plugins/WindowTools.rb:24:in `call'
                      bagatelo
                      could repair it?
                      C:/Archivos de programa/Google/**Google SketchUp 6/**Plugins/WindowTools.rb:24:in `call'
                      Is the very first two tools that I have made. Is strange this situation, because this is working fine for me, but I have Sketchup 7.1, and seems that you have the same version that me. Have you extract de zip file in the right place?
                      I don't understand nothing about RUBY, and yet, I make this improvements...
                        DIEGO-RODRIGUEZ
                        if. is right.
                        in sketchup 7.1 Functions well.
                        I had only tested on sketchup 6.
                        thanks for answering
