    WxWindows for SketchUp Dialogs
    45 Posts 17 Posters 8.3k Views 17 Watching
      Jim
      Is it stable? If so, it's a go.
        tomasz
        I have done some progress using WxSU. Thank you Peter!
        Is there a way to hide a WxSU Frame when SU program is minimized?
        I cannot achieve it (Vista). I thought it should work when SU frame is specified as a parent window (WxSU.app.sketchup_frame).
        I have checked that even all examples always stay visible when SU is being minimized.
        Tomasz
          tomasz
          @billw said:
          ... Personally, I would much rather use WxSU than Webdialogs, much more flexible and entirely in Ruby and cross platform.
          Have you used the WxFormBuilder? It would be nice to have a straight output compatible with WxSU! There is a beta which works with Python.
          Tomasz
            tomasz
            I have found that WxSU won't close a Dialog on SU exit. It closes Frames without a problem.
            I haven't figured it out how to fix it yet.
            Tomasz
              tomasz
              I would appreciate any help with solving this strange bugsplat which appears instead of a simple ruby error message in the console.
              It happens after triggering an 'evt_button'.
              require("wxSU/lib/Startup")
              module Test
              	class MainMenu < Wx;;Frame
              		def initialize()
              			super(WxSU.app.sketchup_frame, -1, "Test", Wx;;DEFAULT_POSITION, Wx;;Size.new(440,260), WxSU;;CHILD_FRAME_STYLE | Wx;;FRAME_FLOAT_ON_PARENT | Wx;;FRAME_NO_TASKBAR )
              			main_panel = Wx;;Panel.new(self, -1)
              			button = Wx;;Button.new(main_panel, -1, "Action!", Wx;;DEFAULT_POSITION, Wx;;DEFAULT_SIZE)
              			evt_button(button.get_id) {|event| button_click(event) }
              		def button_click(event)
              			xx44 ## HERE COMES INNOCENT RUBY ERROR
              	main_menu=MainMenu.new
              	main_menu.show
              event_bugsplat.rb
                tomasz
                Has someone succeed to run wxSU on MAC SnowLeopard? I have received a report that wxSU 3.0 failed to start on that system.
                It looks like it has to be compiled for SmowL in a special way.
                EDIT: PC version from the ZIP file doesn't run well on MAC 👊 😳
                I would love to see more people involved in moving this library into a decent stage of development, because I find that it is very easy to build even complicated interfaces and WxWidgets can be used when writing programs in C++, so the lessons learned in Ruby can be used in programming SU C++ extensions.
                Tomasz
                  tomasz
                  PROBLEM:
                  Windows: The SketchUp main window is not recognised correctly when an SKP file is being opened by double-click.
                  FIX:
                  MsWindowsFrame.rb
                  line 60 should read:
                  model_name=File.basename(model_path,".skp")
                  was model_name=File.basename(model_path) which was including extension of a SU file.
                  BTW. Why Sketchup.active_model.name returns always an empty string. Shouldn't it refer to the file name??
                  The rb file with the fix
                    No - form the manual: http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/model.html#name
                    The name method retrieves the string name of the model.
                    Does not refer to filename. But I think it's similar to definition.name. When you import one model into another it comes in as a component - and I think this property refers to what the definition name will be.
                    But you have model.path instead:
                    http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/model.html#path
                    • Dan RathbunD Offline
                      Dan Rathbun
                      The Model.title method returns the basename (ie filename,) minus the file extension.
                      Note comparison:
                      Sketchup.active_model.title == model_name
                      # would return true
                      I'm not here much anymore.
                        Uh? is that something SU implements? don't see it in the manual...
                          Dan Rathbun
                          Woops.. sorry omitted the link. Here is is:
                          http://code.google.com/apis/sketchup/docs/ourdoc/model.html#title
                            I'm going crosseyed. didn't see that. think I looked at Sketchup class when I looked... 😳
                              tomasz
                              Thanks. I wasn't aware of the method.
                                Dan Rathbun
                                ANSWER: It doesn't ALWAYS return an empty String, it always returns the value of the name attribute (which is class String.)
                                But IF you never set the value of the name attribute, then of course it will 'seem' to always be an empty value, because it is.
                                The value can be set easily using the Model.name= method.
                                Example Code:
                                n = Sketchup.active_model.name
                                n.inspect
                                Sketchup.active_model.name="A newly set name for my model."
                                n.inspect
                                #>> "A newly set name for my model."
                                IF you are writing plugins for other users, you should not expect the name attribute to always be empty, and should (in your code,) allow for those times when the model has been assigned a name value (by the user or another plugin.)
                                ALSO, in the Outliner Window, the model will be listed by .title value, NOT by the .name attribute.
                                P.S.: I can't find a edit control, anywhere in the UI that allows setting the .name (or the .tags) attribute. They SHOULD be on the 'File' page of the Model Info ToolDialog, but are not. (This forces us to use the Console to set the name or write a lil' script to make an inputbox.)
                                Edited: meant to say ' .tags' attribute instead of '.note'; a note is just a Text class object, and not a attribute of the Model.
                                  Malkomitch
                                  Tomasz
                                  or you can export your design to a xrc file (xml style) and load it with xml methods from the Wx module.
                                  xml = Wx::XmlResource.get
                                  xml.load(your_file.xrc)
                                  (google for "xrcise", this utility write for you the code needed to load your xrc)
                                    Malkomitch
                                    It looks like WxSU doesn't handle errors communication between WxRuby and Sketchup.
                                    The best way to get rid of bugsplats is to handle exceptions by yourself, at the end of each method that uses WxSU:
                                    That way, you display the call stack, letting you know where the bug is.
                                    rescue => detail
                                       puts detail.message
                                       puts detail.backtrace.join("\n")
                                      tomasz
                                      Thanks a lot for your help.
                                      I get a bugsplat when closing SU, but it is definitely better this way.
                                      I though that begin ... rescue ... end is required, but I am glad to hear that rescue alone is sufficient.
                                      Writing about xml loading I must say that I prefer to write my own Ruby code based on 'initial' FormBuilder layout, as it helps me better understand WxRuby. Thanks for hint anyway!
                                      Tomasz
                                        Dan Rathbun
                                        I thought that begin ... rescue ... end is required, but I am glad to hear that rescue alone is sufficient.
                                        That is because in module definitions, the module statement is a block statement so the word module works the same as begin (after all, the module does need an end.)
                                        module My_Module
                                          # method defs
                                          # code goes here
                                        rescue
                                          # error handling code
                                        else
                                          # only do code if no exceptions
                                        ensure
                                          # always do this code on exit
                                        end # the end of the method def
                                        The same is true for method definitions, where the def keyword 'begins' the block.
                                        def my_method
                                          # code goes here
                                        rescue
                                        else
                                        ensure
                                        end # the end of the module
                                          tomasz
                                          Thanks for the explanation.
                                          • 2 / 3
