    WxWindows for SketchUp Dialogs
    45 Posts 17 Posters 11.0k Views 17 Watching
    • T
      tomot
      Then why are you 'going GAGA' over Modo?
      I'm not going "GAGA over ArchiCad nor Modo", I'm simply mentioning these programs have had more success in how to integrate addon language components into their main program. Its my hope that SU will improve, and perhaps someone on their staff will look at those examples. ....That's ALL!
      I'm quite sure anyone that has ever written a Ruby program, would love to see a standardized Ruby GUI interface, becoming part of the next major release of SU.
      my plugins
      tomot
      • T
        tomasz
        @jim said:
        The controls example does work for me under XP. But it also does crash frequently.
        Jim, you probably have Ruby installed, have you? I don't have. Will see if it helps.
        I hope this solution will be developed, as I hate playing with HTML and JavaS (I have already tied and have some 'success'). I would love to use Wx without bugsplats.
        Tomasz
        • P
          peter3443
          I've just posted version 0.2 of the wxSU plugin.
          You can download it here: http://wxsu.sourceforge.net/
          The new release fixes several bugs, updates to wxRuby 1.9.9, and has a few other improvements.
            Jim
            Welcome to the forums Peter; thanks for the update.
            • I
              ilay7k
              Peter, thank you!
              • T
                tomasz
                Peter, Thank you! Now it works! I hope I will soon make use of your gift.
                Tomasz
                • P
                  peter3443
                  Just reviving this thread briefly to let everyone know I've just posted version 0.3.0 of the wxSU plugin.
                  You can download it here: http://sourceforge.net/project/showfiles.php?group_id=240585&package_id=292646
                  Version 0.3.0 Release Notes
                  • Update of wxRuby engine and documentation to version 2.0.0.
                  • Bug fix to prevent the creation of multiple instances of the wxSU::App class. Multiple instances can cause crashes and conflicts.
                  • Bug fix for conflict with V-Ray plugin that prevented SketchUp from shutting down completely after exiting.
                  • Better error message and checking for the DLL libraries "msvcp71.dll" and "msvcr71.dll" required by wxRuby on Windows with SketchUp 7.
                  • Required DLL libraries ("gdiplus.dll", "msvcp71.dll", and "msvcr71.dll") are now installed automatically if missing.
                  • T
                    tomasz
                    Thanks Peter for the update. I give it a try. Is this extension also free to use in commercial scripts?
                    Tomasz
                    • P
                      peter3443
                      Yes, wxSU has always been distributed under the BSD License which allows you to package wxSU with either free/open source or commercial works. The wxSU part of the package must still include the source code (unencrypted) and the original copyright notices, but you can handle the rest of your package however you want. See the full license (License.txt) for more details.
                      • B
                        BillW
                        I would just like to thank Peter for his work with WxSU. Personally, I would much rather use WxSU than Webdialogs, much more flexible and entirely in Ruby and cross platform. With auto sizing, any dialog will even change to match screen resolution. You can also set a minimum dialog size for resizing.
                        To give some idea of the rich capabilities, find enclosed a flash video of a set of dialogs (WIP) I have been working on and a jpeg showing the main dialog.
                        Sketchup WxSu.swf
                          Jim
                          Is it stable? If so, it's a go.
                          • T
                            tomasz
                            I have done some progress using WxSU. Thank you Peter!
                            Is there a way to hide a WxSU Frame when SU program is minimized?
                            I cannot achieve it (Vista). I thought it should work when SU frame is specified as a parent window (WxSU.app.sketchup_frame).
                            I have checked that even all examples always stay visible when SU is being minimized.
                            Tomasz
                            • T
                              tomasz
                              @billw said:
                              ... Personally, I would much rather use WxSU than Webdialogs, much more flexible and entirely in Ruby and cross platform.
                              Have you used the WxFormBuilder? It would be nice to have a straight output compatible with WxSU! There is a beta which works with Python.
                              Tomasz
                              • T
                                tomasz
                                I have found that WxSU won't close a Dialog on SU exit. It closes Frames without a problem.
                                I haven't figured it out how to fix it yet.
                                Tomasz
                                • T
                                  tomasz
                                  I would appreciate any help with solving this strange bugsplat which appears instead of a simple ruby error message in the console.
                                  It happens after triggering an 'evt_button'.
                                  require("wxSU/lib/Startup")
                                  module Test
                                  	class MainMenu < Wx;;Frame
                                  		def initialize()
                                  			super(WxSU.app.sketchup_frame, -1, "Test", Wx;;DEFAULT_POSITION, Wx;;Size.new(440,260), WxSU;;CHILD_FRAME_STYLE | Wx;;FRAME_FLOAT_ON_PARENT | Wx;;FRAME_NO_TASKBAR )
                                  			main_panel = Wx;;Panel.new(self, -1)
                                  			button = Wx;;Button.new(main_panel, -1, "Action!", Wx;;DEFAULT_POSITION, Wx;;DEFAULT_SIZE)
                                  			evt_button(button.get_id) {|event| button_click(event) }
                                  		def button_click(event)
                                  			xx44 ## HERE COMES INNOCENT RUBY ERROR
                                  	main_menu=MainMenu.new
                                  	main_menu.show
                                  event_bugsplat.rb
                                  • T
                                    tomasz
                                    Has someone succeed to run wxSU on MAC SnowLeopard? I have received a report that wxSU 3.0 failed to start on that system.
                                    It looks like it has to be compiled for SmowL in a special way.
                                    EDIT: PC version from the ZIP file doesn't run well on MAC 👊 😳
                                    I would love to see more people involved in moving this library into a decent stage of development, because I find that it is very easy to build even complicated interfaces and WxWidgets can be used when writing programs in C++, so the lessons learned in Ruby can be used in programming SU C++ extensions.
                                    Tomasz
                                    • T
                                      tomasz
                                      PROBLEM:
                                      Windows: The SketchUp main window is not recognised correctly when an SKP file is being opened by double-click.
                                      FIX:
                                      MsWindowsFrame.rb
                                      line 60 should read:
                                      model_name=File.basename(model_path,".skp")
                                      was model_name=File.basename(model_path) which was including extension of a SU file.
                                      BTW. Why Sketchup.active_model.name returns always an empty string. Shouldn't it refer to the file name??
                                      The rb file with the fix
                                        No - form the manual: http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/model.html#name
                                        The name method retrieves the string name of the model.
                                        Does not refer to filename. But I think it's similar to definition.name. When you import one model into another it comes in as a component - and I think this property refers to what the definition name will be.
                                        But you have model.path instead:
                                        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/model.html#path
                                        • Dan RathbunD
                                          Dan Rathbun
                                          The Model.title method returns the basename (ie filename,) minus the file extension.
                                          Note comparison:
                                          Sketchup.active_model.title == model_name
                                          # would return true
                                          I'm not here much anymore.
                                            Uh? is that something SU implements? don't see it in the manual...
                                            • 2 / 3
