    Printing for better presentation
    3 Posts 3 Posters 374 Views 3 Watching
      agold768
      Does anyone know how to print full page document or convert it to jpeg.
      Also, How do I use jpeg image to convert to sketchup, so that it is workable and possible to edit, stretch etc?
        mac1
        Convert to jpeg=> select file export 2 d graphic;
        Jpeg to SU =>Slecet import and file format jpeg. You can then use the scale tool to modify the image
        Print full page document=> 1) From tool bar do zoom extents; from tool bar camera make sure you are in parallel line mode, select print preveiw and then select fit to page. The set up dialog will them show the page size that will print on the paper size you have selected. Note it will more that likely be smaller than your page size you selected becasue the size is based on the pixel extents of your screen display and the print size calculator will select the dpi to fit one size to the printer and allow the other dimension to float. You can also deselect the fit to page and use scaling to use more of the page area but it is not a one to one scale either
          KXI System
          Mac got it dead on.
          Getting the perfect sig is hard...
          Google it!
