    Copy Catting
    36 Posts 21 Posters 4.7k Views 21 Watching
      bytor
      Pete,
      The "growies" in Vue are jsut outstanding! 👍
      Find the Cost of Freedom.....
      • RichardR Offline
        Richard
        @bytor said:
        Pete,
        ABSOLUTELY!!!!!
        BUILTBRAND.COM.AU
          dspace
          @solo said:
          A quick render with Vue (6m 34s), setup about 10 minutes, no post processing
          Outstanding! 👍
            Luis Esteves
            Good day everybody,
            Here is my render with VRAY.
            The "Size Multiplier" parameter (in GI (Skylight)) has been increased to 10 to get softer shadows.
              Crazy Eyes
              Wow! Everyone!
              I wasn't expecting such a response from all.
              Solo, you are my inspiratoin, and I was sincerly hoping you would give an example from Vue, truely outstanding.
              I thought I would try it myself too. Thing is though that I couldn't seem to get the ambient lighting working very well. Any suggestions? Today is the first day I've had a play with it, so unless it's simple to fix, don't bother even trying to explain to me :S
              Vue8
              Some people are lovers, some are fighters, if you love to fight, fight for love!
                Okay, here is my "quick and dirty" test (I can make "dirty" renderings only anyway). The choice of the sky was probably a bit of a mistake (too bright, too blue) and I have obviously screwed the shrub on the right.
                Otherwise (except for Majid's water and the warped thin glass which is "shipped" with Twilight) everything is the original in the model and I only used the pre-set templates to quickly adjust the materials.
                • soloS Offline
                  Go into atmosphere editor, in the 'Light' tab select 'GR' that will make the atmosphere Global radiosity (make sure both options below it is also checked)
                    OK, another try with some further tweaks (modified shadows for instance to get some more exciting variations of hard(er) and soft shadows - changed plants, added something behind the camera so that the window can reflect it...)
                    • RichardR Offline
                      Richard
                      Maxwell, noisy!! Only 40min on my crap top! All mats straight from crazy's file but grass, glass brick and gal steel. 5 min PP
                      BUILTBRAND.COM.AU
                        sepo
                        Nice ...Richard. How long would take Maxwell to clear that noise as it is quite noisy?
                        • RichardR Offline
                          Richard
                          Mate as mentioned it was rendered on a 2.4g dual thread, not dual core even! Plus I added a lot of geo in plants, about twenty clipped trees and an internal emitter. So it's probaly not a good example. Though 2-3 hours at that res would clean it up well, done with 1.7.1 - V2 by all accounts is much faster and if I had taken the time to open it in studio you have the option to save out your physical sky as HDRI. You can then just plug that straight back in and it would rip through again much quicker!!
                          I'd say if I had an i7 and used HDRI it would render clean and twice the res in an hour!
                          You have to say though that Maxwell's lighting is hard to beat!
                          BUILTBRAND.COM.AU
                            sepo
                            Yeah the lighting is nice but that noise is problem for me. It is like watching paint to dry. 😉
                            • RichardR Offline
                              Richard
                              I do know what you mean mate! Though one has to balance that up against the ease of setup! Leaving the puter running whilst I do other stuff is a fair trade off for me when I can just set the camera export and do something else!
                              BUILTBRAND.COM.AU
                                sepo
                                I supose we all develop liking for particular workflow. If it works for you than great, 👍 It could be me but I prefer biased render solution.
                                • E Offline
                                  Ecuadorian
                                  Sometimes I wonder what the Pixar guys think of this forum and about our renders... if they visit this place at all. After all, they're kinda the fathers of today's computer graphics.
                                  So far I'm really liking Pete's image. Vue totally rocks for vegetation.
                                  -Miguel Lescano
                                  • RichardR Offline
                                    Richard
                                    Yeah the veg is amazing though the weird artifacts on the walls are a bit disturbing!
                                    Question for Pete! Mate do those artifacts (the ones mostly evident on the right white wall) reduce with time or by alternative render settings!
                                    Like Ecu suggests veg can be a big killer in any render! And particularly if done inside SU with export to another app like vue, 3D max or even maxwell studio, the latter two allowing to bring in or utilise trees, shrubs and grasses created in xfrog or onyx!
                                    I've had onyx for a while and just got the hang of it recently but once you do the results can be stunning. The polycount for this baby would turn SU white, though studio can handle hundreds and I imagine vue thousands!
                                    BUILTBRAND.COM.AU
                                    • majidM Offline
                                      majid
                                      modified bushs to be more 3d and real, adding some 2d foliages, set up TWiR materials,environment and a warm sun( 20 -25 min), over night render (to use my sleep time 😉 ) and 10 min of post-pro
                                      twilight render
                                      • FrederikF Offline
                                        Frederik
                                        Here's my quick try using TWR...
                                        3 minutes to set up materials, replacing the bamboo and adjusting the sun light...
                                        This render was done using the "Path Tracing Progressive" render preset...
                                        60 passes took 1 h 7 min...
                                        NO post pro...
                                        Cheers
                                        Kim Frederik
                                        • david57D Offline
                                          david57
                                          Rendered with Blender 2.5. My tree material is messed up because Blender2.5 Builds
                                          are going through evolution.
                                          • AdamBA Offline
                                            AdamB
                                            LightUp. No changes to model. Render time: 43 seconds.
                                            http://i614.photobucket.com/albums/tt229/ElektraGlide/test_lightup.jpg
