    Right Click Edit
    12 Posts 4 Posters 895 Views 4 Watching
      scetchnscribble
      Can someone explain to me what bit of code in this following script gives the user the ability to right click a component and edit its input variables? I have been looking this over for days and still can't figure it out. ๐Ÿ˜ž
      # Copyright 2004-2005, @Last Software, Inc.
      # This software is provided as an example of using the Ruby interface
      # to SketchUp.
      # Permission to use, copy, modify, and distribute this software for
      # any purpose and without fee is hereby granted, provided that the above
      # copyright notice appear in all copies.
      # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
      # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
      # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      # Name        ;   Window Maker 1.0
      # Description ;   A tool to create parametric Double Hung and Slider windows.
      # Menu Item   ;   Tools->Windows
      # Context Menu;   Edit Window
      # Usage       ;   Select window type and then specify the size.
      #             ;   If the size needs to be changed after inserting into the model,
      #             ;   right click on the window and select "Edit Window".
      # Date        ;   9/10/2004
      # Type        ;   Dialog Box
      # Classes for creating and editing parametric windows
      require 'sketchup.rb'
      require 'parametric.rb'
      # Define the main parametric window class
      class Window < Parametric
      # Create windows as components rather than groups
      def class_of_object
          Sketchup;;ComponentInstance
      def create_entities(data, container)
          width = data["w"]
          height = data["h"]
          type = data["t"]
          Window.create_window(width, height, type, container)
      def create_entity(model)
          #TODO; try to find existing definition matching the parameters
          @entity = model.definitions.add self.compute_name
          # Set the behavior
          behavior = @entity.behavior
          behavior.is2d = true
          behavior.snapto = 0
          behavior.cuts_opening = true
          @entity
      @@defaults = {"w", 4.feet, "h", 5.feet, "t", 0}
      def default_parameters
          @@defaults.clone
      def translate_key(key)
          prompt = key
          case( key )
              when "w"
                  prompt = "Width"
              when "h"
                  prompt = "Height"
          prompt
      # Show a dialog and get the values from the user
      # The default implementation of this in the Parametric class doesn't support
      # having a popup list.  Maybe I should consider adding something that would
      # allow doing that in a more generic way.
      def prompt(operation)
          # get the parameters
          if( @entity )
              data = self.parameters
          else
              data = self.default_parameters
          if( not data )
              puts "No parameters attached to the entity"
              return nil
          title = operation + " " + self.class.name
          prompts = ["Width", "Height", "Type"]
          types = ["Double Hung", "Slider"]
          values = [data["w"], data["h"], types[data["t"]]]
          popups = [nil, nil, types.join("|")]
          results = inputbox( prompts, values, popups, title )
          return nil if not results
          # Store the results back into data
          data["w"] = results[0]
          data["h"] = results[1]
          t = types.index(results[2])
          data["t"] = t ? t ; 0
          # update the defaults values
          if( not @entity )
             data.each {|k, v| @@defaults[k] = v }
          data
      # Create a rectangular face at a given location
      def Window.rectangle(origin, width, height, container, close)
          v1 = Geom;;Vector3d.new(width,0,0)
          v2 = Geom;;Vector3d.new(0,height,0)
          p1 = origin;
          p2 = origin + v1
          p3 = p2 + v2
          p4 = origin + v2
          edges = []
          edges[0]=container.add_line p1, p2
          edges[1]=container.add_line p2, p3
          edges[2]=container.add_line p3, p4
          edges[3]=container.add_line p4, p1
          if( close )
              f = container.add_face edges
          else
              edges
      # Create a simple rectangluar frame
      def Window.simple_frame(p1, width, height, thickness, frameWidth, container)
          # create a group for the frame
          frame = container.add_group
          v = Geom;;Vector3d.new(frameWidth, frameWidth, 0)
          p2 = p1 + v
          holeWidth = width - (2.0 * frameWidth)
          holeHeight = height - (2.0 * frameWidth)
          # Create the outer frame and the hole
          outer = Window.rectangle(p1, width, height, frame.entities, true)
          hole = Window.rectangle(p2, holeWidth, holeHeight, frame.entities, true)
          hole.erase!
          # Extrude the window
          outer.pushpull(-thickness)
          frame
      # Create a basic window
      def Window.create_window(width, height, type, container)
          depth = 3
          outsideFrameWidth = 2.25
          insideFrameWidth = 1.25
          sliderThickness = 1.25
          bHorizontal = (type == 1)
          pt = Geom;;Point3d.new(0,0,0)
          Window.simple_frame(pt, width, height, depth, outsideFrameWidth, container)
          # For a component to cut an opening it must have real geometry in it - not
          # just groups, so create the cutting gometry
          Window.rectangle(pt, width, height, container, false)
          # Create the two sliding windows
          z = ((depth - (2.0 * sliderThickness)) / 2.0) + sliderThickness
          pt = pt + Geom;;Vector3d.new(outsideFrameWidth, outsideFrameWidth, z)
          if bHorizontal
              wh = (width - (2.0 * outsideFrameWidth)) / 2.0
              w = wh + + insideFrameWidth
              h = height - (2.0 * outsideFrameWidth)
          else
              w = width - (2.0 * outsideFrameWidth)
              wh = (height - (2.0 * outsideFrameWidth)) / 2.0
              h = wh + + insideFrameWidth
              pt.y = pt.y + wh
          Window.simple_frame(pt, w, h, sliderThickness, insideFrameWidth, container)
          if bHorizontal
              pt.x = pt.x + wh
          else
              pt.y = pt.y - wh
          pt.z = pt.z + sliderThickness
      # Prompt for parameters and then insert windows
      def Window.create
          window = Window.new
          definition= window.entity
          Sketchup.active_model.place_component definition, true
      # add a menu with the window types
      if( not $windows_menu_loaded )
          UI.menu("Tools").add_item("Windows") { Window.create }
          $windows_menu_loaded = true
      end # module Window
        For a simple example of context menu item: http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/ui.html#add_context_menu_handler
          scetchnscribble
          hey thanks I tried that and it worked... but when i look over this code I only see the context menu listed at the beginning as a comment. How does the script run it if it is only a comment? Is this script calling another external script that i am overlooking?
          Date ; 9/10/2004
          Type ; Dialog Box
          • Chris FullmerC Offline
            That code in the first post is the entire script?
              No - it include's @last's Parametric.rb - as TIG mentioned. And the Window class it works with extends a Parametric class which I can only assume is from parametric.rb - so I'm guessing the parametric.rb contains the context-menu code.
                calls that ruby, so look at that file too...
                  scetchnscribble
                  Thanks I did check that and there was no sign of anything, I still have no clue.
                  Yup thats the entire script. sure it requires sketchup.rb and parametric.rb, but a lot of scripts do.
                  I downloaded it right from the google website Window Maker http://sketchup.google.com/download/rubyscripts.html
                    Read to the end of the file parametric.rb and you will find...
                    # Add a context menu handler that will add a menu choice to a context menu
                    # for editing parametric objects
                    if( not $parametric_loaded )
                        UI.add_context_menu_handler do |menu|
                            klass = Parametric.selection_parametric?
                            if( klass )
                                menu.add_separator
                                menu.add_item("Edit #{klass}") { Parametric.edit_selection }
                        $parametric_loaded = true
                    which looks suspiciously like the code for a context-menu ? ๐Ÿ˜ฎ
                      scetchnscribble
                      yeah i did another test and some how its passing the class name to parametric.rb but how? is it through the following code?
                        scetchnscribble
                        so my question now is if I require another script, such as, parametric.rb does that mean it loads the script and allows me to pass methods and variables back and forth between the two scripts? ๐Ÿ˜•
                          means that Window 'extends' [builds upon OR uses] the Parametric class - i.e. it's like they are parts of the same code: so making a Window gives it certain properties through the Parametric code, later on the property found in a selected object can trigger the Parametric 'checker' and make the context-menu appear, adjusted to suit the exact type of 'parametric' object that it is...
                          Window needs Parametric to work - it can't stand alone - if you were to remove parametric.rb Window wouldn't work...
                          They work in tandem.
                          Parametric can be used by lots of different scripts for other objects requiring similar dialogs etc...
                            scetchnscribble
                            thanks, great explanation. I'm guessing nothing in parametric.rb is actually specifically changed to work with windows.rb and it is the windows.rb script that utilizes the methods and variables in the parametric.rb script. i'll keep working at it
