    WxWindows for SketchUp Dialogs
    45 Posts 17 Posters 7.8k Views 17 Watching
      tomasz
      Thanks Peter for the update. I give it a try. Is this extension also free to use in commercial scripts?
      Tomasz
      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
        peter3443
        Yes, wxSU has always been distributed under the BSD License which allows you to package wxSU with either free/open source or commercial works. The wxSU part of the package must still include the source code (unencrypted) and the original copyright notices, but you can handle the rest of your package however you want. See the full license (License.txt) for more details.
          BillW
          I would just like to thank Peter for his work with WxSU. Personally, I would much rather use WxSU than Webdialogs, much more flexible and entirely in Ruby and cross platform. With auto sizing, any dialog will even change to match screen resolution. You can also set a minimum dialog size for resizing.
          To give some idea of the rich capabilities, find enclosed a flash video of a set of dialogs (WIP) I have been working on and a jpeg showing the main dialog.
          Sketchup WxSu.swf
            Jim
            Is it stable? If so, it's a go.
              tomasz
              I have done some progress using WxSU. Thank you Peter!
              Is there a way to hide a WxSU Frame when SU program is minimized?
              I cannot achieve it (Vista). I thought it should work when SU frame is specified as a parent window (WxSU.app.sketchup_frame).
              I have checked that even all examples always stay visible when SU is being minimized.
              Tomasz
                tomasz
                @billw said:
                ... Personally, I would much rather use WxSU than Webdialogs, much more flexible and entirely in Ruby and cross platform.
                Have you used the WxFormBuilder? It would be nice to have a straight output compatible with WxSU! There is a beta which works with Python.
                Tomasz
                  tomasz
                  I have found that WxSU won't close a Dialog on SU exit. It closes Frames without a problem.
                  I haven't figured it out how to fix it yet.
                  Tomasz
                    tomasz
                    I would appreciate any help with solving this strange bugsplat which appears instead of a simple ruby error message in the console.
                    It happens after triggering an 'evt_button'.
                    require("wxSU/lib/Startup")
                    module Test
                    	class MainMenu < Wx;;Frame
                    		def initialize()
                    			super(WxSU.app.sketchup_frame, -1, "Test", Wx;;DEFAULT_POSITION, Wx;;Size.new(440,260), WxSU;;CHILD_FRAME_STYLE | Wx;;FRAME_FLOAT_ON_PARENT | Wx;;FRAME_NO_TASKBAR )
                    			main_panel = Wx;;Panel.new(self, -1)
                    			button = Wx;;Button.new(main_panel, -1, "Action!", Wx;;DEFAULT_POSITION, Wx;;DEFAULT_SIZE)
                    			evt_button(button.get_id) {|event| button_click(event) }
                    		def button_click(event)
                    			xx44 ## HERE COMES INNOCENT RUBY ERROR
                    	main_menu=MainMenu.new
                    	main_menu.show
                    event_bugsplat.rb
                      tomasz
                      Has someone succeed to run wxSU on MAC SnowLeopard? I have received a report that wxSU 3.0 failed to start on that system.
                      It looks like it has to be compiled for SmowL in a special way.
                      EDIT: PC version from the ZIP file doesn't run well on MAC 👊 😳
                      I would love to see more people involved in moving this library into a decent stage of development, because I find that it is very easy to build even complicated interfaces and WxWidgets can be used when writing programs in C++, so the lessons learned in Ruby can be used in programming SU C++ extensions.
                      Tomasz
                        tomasz
                        PROBLEM:
                        Windows: The SketchUp main window is not recognised correctly when an SKP file is being opened by double-click.
                        FIX:
                        MsWindowsFrame.rb
                        line 60 should read:
                        model_name=File.basename(model_path,".skp")
                        was model_name=File.basename(model_path) which was including extension of a SU file.
                        BTW. Why Sketchup.active_model.name returns always an empty string. Shouldn't it refer to the file name??
                        The rb file with the fix
                          No - form the manual: http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/model.html#name
                          The name method retrieves the string name of the model.
                          Does not refer to filename. But I think it's similar to definition.name. When you import one model into another it comes in as a component - and I think this property refers to what the definition name will be.
                          But you have model.path instead:
                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/model.html#path
                          • Dan RathbunD Offline
                            Dan Rathbun
                            The Model.title method returns the basename (ie filename,) minus the file extension.
                            Note comparison:
                            Sketchup.active_model.title == model_name
                            # would return true
                            I'm not here much anymore.
                              Uh? is that something SU implements? don't see it in the manual...
                                Dan Rathbun
                                Woops.. sorry omitted the link. Here is is:
                                http://code.google.com/apis/sketchup/docs/ourdoc/model.html#title
                                  I'm going crosseyed. didn't see that. think I looked at Sketchup class when I looked... 😳
                                    tomasz
                                    Thanks. I wasn't aware of the method.
                                      Dan Rathbun
                                      ANSWER: It doesn't ALWAYS return an empty String, it always returns the value of the name attribute (which is class String.)
                                      But IF you never set the value of the name attribute, then of course it will 'seem' to always be an empty value, because it is.
                                      The value can be set easily using the Model.name= method.
                                      Example Code:
                                      n = Sketchup.active_model.name
                                      n.inspect
                                      Sketchup.active_model.name="A newly set name for my model."
                                      n.inspect
                                      #>> "A newly set name for my model."
                                      IF you are writing plugins for other users, you should not expect the name attribute to always be empty, and should (in your code,) allow for those times when the model has been assigned a name value (by the user or another plugin.)
                                      ALSO, in the Outliner Window, the model will be listed by .title value, NOT by the .name attribute.
                                      P.S.: I can't find a edit control, anywhere in the UI that allows setting the .name (or the .tags) attribute. They SHOULD be on the 'File' page of the Model Info ToolDialog, but are not. (This forces us to use the Console to set the name or write a lil' script to make an inputbox.)
                                      Edited: meant to say ' .tags' attribute instead of '.note'; a note is just a Text class object, and not a attribute of the Model.
                                        Malkomitch
                                        Tomasz
                                        or you can export your design to a xrc file (xml style) and load it with xml methods from the Wx module.
                                        xml = Wx::XmlResource.get
                                        xml.load(your_file.xrc)
                                        (google for "xrcise", this utility write for you the code needed to load your xrc)
                                          Malkomitch
                                          It looks like WxSU doesn't handle errors communication between WxRuby and Sketchup.
                                          The best way to get rid of bugsplats is to handle exceptions by yourself, at the end of each method that uses WxSU:
                                          That way, you display the call stack, letting you know where the bug is.
                                          rescue => detail
                                             puts detail.message
                                             puts detail.backtrace.join("\n")
                                            tomasz
                                            Thanks a lot for your help.
                                            I get a bugsplat when closing SU, but it is definitely better this way.
                                            I though that begin ... rescue ... end is required, but I am glad to hear that rescue alone is sufficient.
                                            Writing about xml loading I must say that I prefer to write my own Ruby code based on 'initial' FormBuilder layout, as it helps me better understand WxRuby. Thanks for hint anyway!
                                            Tomasz
                                            • 2 / 3
