    Separating a plugin from others
    22 Posts 7 Posters 1.8k Views 7 Watching
      MyUniquePlug1 should not interfere with MyUniquePlug2 in any way. Got some specific examples of conflict?
        tomasz
        I don't have an example of a specific conflict. I have enclosed the plugin within a module, which name is unique enough and I am getting responses from users that the plugin won't start unless (almost) whole plugin folder is empty. Personally I don't have problem on my own computers, so I am confused and looking for a clue and a solution.
          Jim
          Emptying the Plugins folder is not the first thing to try. Have them open the Ruby Console window, and load the plugin manually to see what errors are being produced.
            tomasz
            It is ... not funny.
            Sketchup.load 'Plugin.rbs'
            returns 0 (!=true or false).
            There is no explanation in the API for such a case.
            Tomasz
            • daikuD Offline
              daiku
              When you create an object from the class, you have to specify which module it should come from. This code works fine for me:
              module Mod1
              	class Test
              		def id
              			puts "Mod1 Test"
              module Mod2
              	class Test
              		def id
              			puts "Mod2 Test"
              t1 = Mod1;;Test.new
              t2 = Mod2;;Test.new
              t1.id
              t2.id
              Result:
              Mod1 Test
              Mod2 Test
              Note that I create two objects (t1 and t2), one of each class. I get away with the classes having the same name because they live in different modules. CB.
              Clark Bremer
              http://www.northernlightstimberframing.com
                tomasz
                I see, so doing:
                t3 = Test.new
                Will get unexpected results!
                Thank you!
                  I see, so doing:
                  t3 = Test.new
                  Thank you!
                  Depends in what cope you are in.
                  module Mod1
                     class Test
                        def id
                           puts "Mod1 Test"
                     t1 = Test.new # Should refer to Mod1;;Test
                  module Mod2
                     class Test
                        def id
                           puts "Mod2 Test"
                     t2 = Test.new # Should refer to Mod2;;Test
                     t4 = Mod1;;Test.new
                  t3 = Test.new # I don't know if this will even work
                    tomasz
                    Is there someone from Google who can tell me what 0 means in this case?
                    It happens on Vista64 SU 7.1.
                    • Chris FullmerC Offline
                      What is Plugin.rbs ?
                        tomasz
                        I have used SDK Scrambler on Plugin.rb file >> Plugin.rbs.
                        It is 'a' plugin name. Not relevant in this case.
                          Once you scramble a file, there are problems with it loading. I think you have to hard code the path into the file.
                          I'm not sure if you use the FILE constant in your script, but I tihnk that might not work in a scrambled script. I'm sure others here know more about this. But I do know that scrambled scripts are a little trickier to load somehow....Perhaps that is why it seems to not be loading?
                            Does the plugin load? Might be the manual that's incorrect, and it returns 1 on success and on failure?
                              Jim
                              Sketchup.load acts like Sketchup.require which acts like require - which means it checks the $" special global variable before loading.
                              0 could mean it has already been loaded. Check the $" variable in the Ruby Console window to see if the file is already on the list.
                                tomasz
                                I just realized same thing. I do use FILE. I will hard code it. I am not sure if it will be unless file_loaded?('Plugin.rb') or unless file_loaded?('Plugin.rbs'). Will check it.
                                The plugin loads automatically on my machine (Vista32Home). When I Sketchup.load 'Plugin.rbs' it returns 0 .. which may mean that the plugin has been already loaded.
                                The thing is that an user on Vista64 gets olso 0, but there is no plugin whatsoever in his Plugins menu.
                                I have another tester with Vista64 and it works fine for him, so there must be some interaction with a different plugin I believe.
                                  Jim
                                  Not important - can be any string. It just adds the string to a global variable. It is something invented for Sketchup for the sole purpose of guarding the menus from adding multiple entries.
                                  Yeah - I think I'll call them "menu guards".
                                    I can confirm. Sketchup.load returns 0 (fixnum class) if it loaded and false (falseclass) if it did not load.
                                    Odd, that should go in as a bug fix, and an API fix?
                                      tomasz
                                      @jim said:
                                      Not important - can be any string...
                                      So FILE is not the issue. I think I have a problem with a different plugin, that stops mine to load into Plugins.
                                      Thanks for explanation.
                                        You say its a Vista user with problems? Nearly all the Vista problems I get are related to the "Compatibility Files" folder. Sometimes when a user downloads a file directly to the plugins folder, it will put it into a safe compatilibity folder, and it does not appear in the plugins folder.
                                        Have the user check their compatibility folder, delete any old versions of your plugin, reinstall, and try again. That might help.
                                          tomasz
                                          I have discovered something important for those who use rbs.
                                          If you check if your plugin has already been loaded with:
                                          file_loaded?(File.basename(__FILE__))
                                          from inside of a rbs file - the FILE value == '(eval)' !
                                          If there are two rbs plugins which use the same method, the first will block the second.
                                          That is why my rbs has been loaded, but didn't create a menu in Plugins.
                                          • Dan RathbunD Offline
                                            Dan Rathbun
                                            Sounds like File.basename(FILE) is getting set to part of an eval error string.
                                            I wonder if eval error strings are put to the $! message global?
                                            I'm not here much anymore.
