    How to display Tree structure
    8 Posts 5 Posters 622 Views 5 Watching
      Mcdull
      I have set attributes to all entities,then i want to generate a tree sturcture like this
      buliding
      |_____room1
      | |____wall
      | |____floor
      |room2
      and this tree can shrink as we can see as usual,such as explorer, is there any method to produce it in sketchup with ruby api?
        Mcdull
        the wall level and floor level should conect with room level, the previous stucture displayd not well in the page...
          Webdialog?
          Use the ruby markup - that will display the text in fixed-width text.
          ` |_____room1
          ____wall
          ____floor
          _____room2
          _____.....`
            Mcdull
            i have used a tree.rb to display the structure like this
            %(#FF0000)[* ROOT
            |---+ CHILD1
            | +---> GRANDCHILD1
            +---> CHILD2]
            but i can not hadle it ,suas click and shrink
            thomthom said webdialog,can u teach me detail? i have never used webdialog,and i knew little about web...thank u~
            • Chris FullmerC
              Then run for your life!
                To use webdialogs you need knowledge of HTML, CSS and JS. It's not something I can teach in a single post. Best would be to look up some tutorials on the net.
                "tree.rb"?
                • chrisglasierC
                  chrisglasier
                  Here's a little machine that I like to give an airing every now and again. The idea is similar to yours but I have used animation to handle cumbersome tree structures. But take note of the others' advice, it ain't easy to achieve.
                  • Al HartA
                    Al Hart
                    You can also use the SKP "Simple Extrension" API to put your tree structure into a C++ list box.
                    Here is a sample we use to display component categories and select components for placement.
                    (click on image to remove scroll bars)
                    Al Hart
                    IRender nXt from Render Plus
