    Creating a ramp on a curve
    22 Posts 9 Posters 9.0k Views 9 Watching
      jonathanb
      I am having difficulty resolving a ramp issue on a curve. Each time i try the follow me tool the ramp ends up at an angle.
      Is there a simple solution for this?
      Many thanks.
      • GaieusG
        Hi Jonathan,
        Could you upload the shape (preferably the model, not just an image) you are trying to start with?
          jonathanb
          Here is the model, i have shown the curve and the profile that i need. Thanks for the suggestion to get a plugin, is that a free one that i can find from google?
          Many thanks
          UPLOAD.skp
          • GaieusG
            Hi Jonathan,
            This is not the "fastest" method as there are excellent plugins to stitch edges together but you should also understand their way of working (as they mainly automate procedures like this).
            So basically what I was doing is that I quickly "hand-stitched" your edges from endpoint to endpoints of the segments (and even left them unsoften so that you can see what it is about). Use the Ctrl + tool to soften them.
            UPLOAD.skp
            Every plugin Pilou mentioned is freely available in our Ruby forum
            http://forums.sketchucation.com/viewforum.php?f=323
            except the 1001 tools.
              jonathanb
              Thanks Gaieus,
              i can see how you do that now, great. A lot simpler than i thought!
              And if i want to get a 100mm thickness to the ramp as opposed to a complete infill, how can i do this?
              Cheers for your time
              • GaieusG
                You move-copy (Ctrl + ) the top surface (with its edges) down by 100mm. Now it should auto-intersect with the vertical edges so you should be able to delete everything unneeded (the bottom part). The only "issue" is at the landing end of the ramp where you need to draw in some vertical edges (like I did) and PushPull the last, horizontal part to correspond with it. After deleting the face between this and the ramp and softening all necessary edges, it should look like this.
                UPLOAD.skp
                  jonathanb
                  I'm struggling to see now how you infilled the bottom of the ramp in the first place as i just have the flat plane. I can make the ramp 100mm from your model, but not from mine!
                  Sorry!
                  • W
                    wyatt
                    Another way to do this is by selecting the edges of the ramp and running the Sandbox From Contour command. Here's an image with hidden lines on.
                    • GaieusG
                      Sorry!
                      I did not really filled it - as I copy-moved the top surface,there was already the fill.
                      @Wyatt - yes, the sandbox tools > from contours is also great for this (I just wanted to demonstrate first what that plugin would do actually, too).
                      • W
                        wyatt
                        Gai,
                        Yes, it's good to understand the fundamentals. Nonetheless, thank goodness for plugins! πŸ˜„
                          jonathanb
                          Gai,
                          what i meant was when you first showed me how to build the ramp, the underneath of the ramp was all solid, yet i'm not sure how you did this. I understand how you get from there to the 100mm thick ramp but just not the initial making the ramp solid bit.
                          Thanks Wyatt i will look out for that plug in!
                          Jonathan
                          • GaieusG
                            Ehm...
                            Indeed, I didn't explain it. Funny is that I used the Drape tool to drape it on the flat surface - and the drape tool is also part of the Sandbox tools (which are essentially plugins for SU).
                            • Chris FullmerC
                              Here's a way you could do it using Shape Bender.
                              [flash=800,600:1epzlnee]http://www.youtube.com/v/tGHTIOMm_34&hd=1&fs=1[/flash:1epzlnee]
                              • Jean LemireJ
                                Jean Lemire
                                Hi Jonathanb, hi folks.
                                See this SU file for ideas.
                                Curved ramp.skp
                                • W
                                  wyatt
                                  Chris,
                                  Awesome script and tutorial. I somehow have missed downloading Shape Bender. Off to get it now...
                                  Wyatt
                                  • GaieusG
                                    Also, if you add the 100mm thickness to a flat plane, you can always move one end face up like this
                                    unfortunately, SU's autofold function is not always flawless so you still need a bit of cleanup for a nice, final result
                                      Some plugs can make that πŸ˜‰
                                      Follow and Keep, Extrusion along a path (1001bits)... Extrude Edges by Edges, Extrude Edges by Rails, Component Stringer, FredoScale etc..Shape Bender πŸ˜‰ ...
                                      Depending of what do you want exactly! πŸ’š
                                      • troyhomeT
                                        troyhome
                                        [flash=800,600:3fc6wrdl]http://www.youtube.com/v/tGHTIOMm_34&hd=1&fs=1[/flash:3fc6wrdl]
                                        Chris, as always- great scripts and great video tutorials!
                                        I had a DUHHHH moment when i saw you use the erase tool to UN-smooth geometry! Didn't know you could do that- i thought it could only smooth it πŸ˜„
                                        IOviz.com
                                        SU Pro 2024 PC
                                        • Chris FullmerC
                                          Hehe, glad I could provide you with a "DUH" moment of your own.
                                          I've always thought that watching how other people work in real time is an eye opening experience.
                                            d12dozr
                                            +1
                                            Love the tut, Chris πŸ˜„
                                            http://goo.gl/f7ooYh
