    SketchUp Command Calls
    4 Posts 3 Posters 554 Views 3 Watching
      SYD_UK
      How would I put the EDIT pull down item SelectNone onto the Context menu?
      Also where can I find a reference list of default SketchUp command calls for use in Ruby Script files?
        Jim
        Hi Syd,
        There is a list of "send_action" commands here, but I don't see a "select none".
        But, it's easy to manipulate the Selection using Ruby.
        Here's short example
        # select_none.rb - adds "select none" option to context menu.
        UI.add_context_menu_handler { |menu|
            menu.add_item("Select None") { Sketchup.active_model.selection.clear }
          To add Context Menus: http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/ui.html#add_context_menu_handler
          For Sketchup commands: http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/sketchup.html#send_action
          Here's the Class index of the Sketchup Ruby API: http://code.google.com/intl/nb/apis/sketchup/docs/classes.html
            SYD_UK
            Thanks guys - I've added the code:
            to the existing ContextMenuMenus.rb file TIG supplied
            Kind Regards
            Syd
