Pro exporters
7 Posts 5 Posters 272 Views
    chrisg
    I'm using the free version of SU7, I'd like to export to dxf and pdf, Is it possible to use this function without purchasing pro (which I can't afford at the moment)?
    Thanks in advance
      jim smith
      here is a link to a comparison chart of free/pro
      Error 404 (Not Found)!!1
      (sketchup.google.com)
      It shown jpeg/tiff/png/KMZ/Collada export but no dxf/dwg import or export
      "Out of clutter find simplicity,
      from discord find harmony,
      In the middle of difficulty lies opportunity"
      Albert Einstein
        chrisg
        Thanks Jim, that looks like a "no" then!
        Cheers
          johnsenior1973
          There is a PDF exporter available for free: http://forums.sketchucation.com/viewtopic.php?f=80&t=22821&st=0&sk=t&sd=a&hilit=simlab
          • H Offline
            honoluludesktop
            Go here for a dxf exporter, and search the internet for a pdf printer driver.
              Hi Chris,
              You can also use DoubleCAD (a free version is available, too) which can importskp files and then of course, you can output dxf/dwg from there.
              As for PDF - what honoluludesktop says - a good pdf printer would probably do it - I use PDFCreator for instance - but of course, there are lots out there.
                chrisg
                Thanks to everyone for your help, I think I've got it now!
                Chris 👍
