    I need major critiques
    9 Posts 9 Posters 1.9k Views 9 Watching
    • W Offline
      Will03
      Hey all,
      My latest render, straight from my brain to SU then to Kerkythea then to Photoshop.
      Please be extremely critical, every bit helps.
      Thank you,
      -Will
        Light on 715 is not very ecologic in the middle day πŸ’š
          ScottPara
          Materials are very flat and not realistic
          Glass is not realistic
          Camera angle and view is not complimentary to the structure. Try pulling the camera back and letting the environment play to the scene.
          Take some time to research GOOD architectural renderings and look at camera angles and the entourage the add. Research and reference photos are crucial when trying to put together a scene.
          Some good advice I was given is that still imagery can at times be harder than an animation. An animation and the movement of a camera can help sell a product/scene/structure, where a still shot has to sell this in one or two views.
          Scott
          Love the fact that some HATE my avatar.....
            Aidus
            Hi!
            Everything is too dark. Materials indead need some adjustments. Maybe try to change bump map of red wall. It looks more like a carpet to me or maybe colour is too dark - experiment is the key. I think backround image is too blurry because it is too close or maybe not.
            Overall this is a good start now you just need to take Your materials one by one and make them look better.
            PS. Maybe try to desaturate colour of green leaves at front plant. Otherwise they look too unnatural to me.
            PPS. Waiting for improvements! Sorry for my english πŸ˜„
            CPU: Intel Core i7 Extreme Edition 965
            RAM: OCZ Gold DDR3 1600MHz 12Gb
            Video: Asus Radeon HD4870 X2 2Gb
            Mobo: Asus P6T Deluxe 1366 Intel X58
            • FrederikF Offline
              Frederik
              I agree with all the points already mentioned above...
              I wonder what material you've used for the windows... πŸ˜•
              It seem as if you've applied the sky and background in post pro, since the background is missing behind the windows in the livingroom...
              Do you know that in KT you can easily apply a sperical sky...??
              There's a number of sperical backgrounds you can download from KT's website...
              Check page 26 - 28 in the Getting Started tutorial... πŸ˜‰
              But overall - a nice start... πŸ˜„
              Cheers
              Kim Frederik
                sketchup_fan
                I don't know about you guys, but i like the render, the only thing i want ot tell you is to inscrease your render quality settings. Overall, the design and the render are pretty good. πŸ˜‰
                  dacad
                  Pretty good?with that plants and glass?
                  It's a good start but materials really need more work
                  • F Offline
                    flyashy
                    Uh..Sorry to inform you that Major Critiques is right now vacationing in Bahamas. I suggest you talk to Capt. Feed Bach instead.
                    Regards.
                    lol..just a little joke...sorry couldn't resist that! πŸ˜„
                    • U Offline
                      Ultimatez 32
                      here's my crit:
                      all the textures are a bit.. flat. a little more obvious bump map maybe, or better textures. There's a lot of free ones over at cg-textures or there are some low-res (sort of) free textures at arroway. Just go to the products section, and then go to the product that interests you. After that you'll be able to see a list of textures on the side view. There's a maps section at the bottom part of the texture description. Choose the diffuse map and you got yourself a free low-res arroway texture. see att.
                      Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
