    Great forum, need help already!
    3 Posts 4 Posters 269 Views 4 Watching
      jkristoph
      I am having some trouble with the push-pull feature. Is it possible to push an internal surface in line with a external surface? If this makes absolutely no sense please see the attached e.g. I have a planter with angled sides. Can I push "hollow out the planter" in relation to those angles?
      Planter.skp
      • soloS Offline
        here.
        Planter[1].skp
          MartinRinehart
          I think there's an easier way. Rectangle the bottom. oFFset in the width of the sides. PushPull up a hollow, rectangular planter. Double-click to Select the top face and edges. Use the Scale tool on a corner, Ctrl held down to scale about center, and pull the top out a bit.
          If your modeling seems like work you're working too hard.
