    Model this: Enrico bamboo cheese grater
    37 Posts 20 Posters 4.6k Views 20 Watching
    • dermotcollD Offline
      dermotcoll
      🀣 Sweet aussie humour !!!
      When you burn your arse - you gotta sit on the blisters!!
      • jeff hammondJ Offline
        rotated the knives 45deg for more practical cutting, added a logo, roughed out the box, pseudo clay render.. i think that's about as far as ima take this one..
        click for larger
        close up renders with the metal are going to show the problem of keeping the poly count down so i do think if i'm ever faced with a similar situation again, i'm going for high poly and instancing (which i very recently found out is possible with indigo πŸ˜„ )
          @rev3rse said:
          Texture extracted from posted picture πŸ˜„
          nice thinking.. it looks good.
            MIke Ravenwolf
            lol wow... I only wish i could get a render as good as Reverse or Jeff's (or anyone's for that matter lol) but i don't think that'll be happening anytime soon.
            I'd have posted it last night if i wasn't being sucha perfectionist (bottom face of the grater plate...lol something no- one will likely ever see....), but when you have a 4 week old that is refusing to fall asleep and keeping you up with her crying...lol what else are you going to do. πŸ˜„ ahhh the joys of new parenthood,lol
            what did you use to get the 'psuedo-clay' render, Jeff?
            Carpe Diem, Foveo Noctim
              hey Mike.
              congrats on the new family member!
              i used indigo renderer which works out especially well for this because it will render backfaces.. there's no way i would want to attempt adding a thickness to the metal just so i could have all front faces showing πŸ˜„
                rev3rse
                Can I post a new type of grater?
                It has 4 different sides..
                Modeling time: 2 minutes πŸ’š πŸ’š
                • EscapeArtistE Offline
                  EscapeArtist
                  Whazzat? 2 minutes you say? Bump and transparency mapping + modeled top and bottom?
                    rev3rse
                    It's a very simple model with 4 simple textures, no bump, no transp.
                    A truncated piramid with a simple follow-me element...
                    Sometimes a real texture is the best option!! πŸ’š
                      Solidseal
                      o0
                      I dont even know where to start πŸ˜„ .. I can make the box (no real challenge) but the grater is another story πŸ˜„
                      Some nice (read=all) work here πŸ˜„
                      • spenceS Offline
                        spence
                        I really struggled with this at first and now have done it, but the model is a bit heavy.
                        Sandbox tool and then tools on surface for the cutout
                        Up Close
                        So, I will probably not have time to model the rest of the box but for me this part was the challenge. I really had fun.
                        Spence
                          MIke Ravenwolf
                          after more hours than i should have spent (though i learned alot on how to increase my efficiency) here is my rendition
                          there are only two things i dont like about it.
                          1. i wasnt able to finish the bottom side of the grater,
                          2. I wasn't able to blend the blades to the top surface of the grater (may try again later)
                          the rest of it though, I added a bit of detail, that you may not see unless you take the model apart or look really close at the wireframe model. so... here are my image shots and file
                          I welcome (and encourage) any and all comments and critiques
                            MIke Ravenwolf
                            and here is the .skp for any who are interested.
                            again, any and all comments are welcome πŸ˜„
                            I'm going to try and render this overnight, though I don't expect it to turn out...lol
                            modelthischeesegrater.zip
                              Slimdog
                              Well better late than never. I just hacked together the wooden frame. Not to concerned about any help with that.I basically used the same technique as Dale with the follow me and then intersect with model. I used no plugins. I am just looking for some help with my poly count. And would like some advice with the follow me tool. When I use the follow me tool it seems to leave the rotated solid in pieces and not a circle any more. Is there any way to get around that?
                              http://i60.photobucket.com/albums/h30/slimdog72/Grater.jpg
                              http://i60.photobucket.com/albums/h30/slimdog72/tang.jpg
                              Thanks to Solo for starting the model this threads.
                              And thanks to all who posted it was interesting how many different ways one could tackle this model.
                              • 2 / 2
