    Best Strategy for Clean Geometry
    7 Posts 3 Posters 538 Views 3 Watching
      MartinRinehart
      I have a box method that Rectangles from one corner to a second corner, then PushPulls the rectangle to create a box. It works well if it doesn't mingle with other geometry. I want a nice, clean box not touching other geometry so I can group or component it, then let it go play with the other geometry. So far I've thought of
      a) Push the current model onto a stack. File/New. Draw box. Save. Pop model. Import. (Can you File/Import in Ruby?)
      b) Same as a) but use fresh layer, not model. Group/Component before moving to existing layer.
      c) Code my own PushPull so I can keep references to rectangle's face and edges and all eight new edges and 5 new faces.
        Why not group it first ?
        group=model.active.entities.add_group()
        group.entities.add_edges(...)
        ### etc
        ### Why wait till afterwards to group it ?
        ### You can always explode at at the end !
        This also lets you find faces, edges etc more easily...
          MartinRinehart
          The implication is abandoning face.pushpull in favor of writing my own pushpull?
          Be careful how you advise me, TIG. I have enough respect for you to actually take your advice.
            Separating your new geometry inside a new group's entities [or component definitions entities] and then pushpulling it [or whatever you want to do to it] inside the group quite safely, and away from other geometry clashes is a good [English understatement for 'the correct'] way to make new stuff like this.
            When you are done then you can explode the group and the geometry can intermingle with other stuff, if desired...
            Personally I prefer to leave my new geometry grouped for the user to decide on the explode - see ExtrudeEdgesByRails et al... ❓
              MartinRinehart
              # /r/t.rb
              # Work in progress. Do not put into service.
              # Finished version will be in my tutorial, Chapter 14.
              def pp_add( pt, vec )
                  return [ pt[0]+vec[0], pt[1]+vec[1], pt[2]+vec[2] ]
              def pp( face, distance )
                  # the full vector is the face's normal times the pushpull distance
                  norm = face.normal.to_a()
                  vec = [ norm[0]*distance, norm[1]*distance, norm[2]*distance ]
                  # create a new set of vertices 'vec' away from the original
                  vs = face.vertices()
                  new_vs = []
                  for i in 0..vs.length-1
                      new_vs[i] = pp_add( vs[i].position, vec )
                  # TIG's idea;
                  ents1 = Sketchup.active_model.entities
                  grp = ents1.add_group()
                  inst = grp.to_component()
                  defi = inst.definition()
                  ents2 = defi.entities()
                  a = []
                  for v in face.vertices
                      a.push( v.position )
                  old_face = ents2.add_face( a )
                  ents1.erase_entities( face )
                  # add a face with the new vertices
                  new_face = ents2.add_face( new_vs )
                  # draw faces around the outside
                  for i in 0..(vs.length-1)
                      f = ents2.add_face(
                          new_vs[ i%vs.length ],
                          new_vs[ (i+1)%vs.length ],
                          vs[ i % vs.length ]
                      f.reverse! if distance < 0
                  end # loop over vertices
                  # flip a face so they all face outside
                  new_face.reverse! if distance < 0
                  old_face.reverse! if distance > 0
                  return inst
              end # of pp()
                Jim
                I'm not understanding. This draws a box within the context of a Group.
                pts = [ [0, 0], [0, 10], [10, 10], [10, 0] ]
                group = Sketchup.active_model.entities.add_group()
                face = group.entities.add_face(pts)
                face.pushpull(10)
                  Martin is/was making it far too complex... it even converted the group to a pointless component ?
                  KISS... πŸ˜‰
                  Jim's example is the better way to do it... Explode the group at the end if desired...
