    Different line weights in sections ?
    layout
    4 Posts 2 Posters 1.0k Views 2 Watching
      Jorgensen
      I'm trying to figure out how to have different line weights in sections, so that walls that are cut gets a think line, and all other lines are thin.
      It looks fine in SU (section cut width), but it seems to disappear in LO 😞
      Am I doing something wrong ?
        Jorgensen
        No it seems to work. I selected a other style, and then seleced the first one again. Hmmmm LO a lot of (bugs ?) figure it out by trying a lot of things, and not all of them are logical.
        But not it seems to work. I would like to trim my workflow, so I'm trying cut off indesign and use SU / LO instead.
        Shame that LO does't import PDF.
          bjanzen
          Macs insert PDF's because it's an OS thing. There are a number of things that we have to work a bit harder to make work on PC, and this is one. If you can't get your hands on a Mac, then get ghostscript, or buy Illustrator... search previous posts on how to do this.
          b
            bjanzen
            Oh, I should point out that on Mac, it's not importing PDF's as vector; for that, you'll need Illustrator, output to dxf, into SketchUp, etc...
