    Quit Current Tool
    6 Posts 4 Posters 515 Views 4 Watching
    • daikuD
      daiku
      I'm creating a tool, and there are certain situations where it's inappropriate to use the tool (the user does not have the correct type of component selected). I can display an error message easily enough, but how do I then quit the tool? CB.
      Clark Bremer
      http://www.northernlightstimberframing.com
        hm... I've not used it - but maybe Tools.pop_tool?
        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/tools.html#pop_tool
          Jim
          You could use a validation_proc to enable/disable the Tool button and/or menu. There would not be an opportunity to open a message box - the tool would simple not be available.
          • daikuD
            daiku
            Yes, validation_proc is the correct solution for me. Don't even start the tool if we're not in the correct state. Thanks, Jim. CB.
            Clark Bremer
              Best to stop the tool running if the circumstances are wrong.
              Assuming that you can select the 'wrong thing' within the tool later...
              After your error message...
              Sketchup.send_action("SelectSelectTool;")
              return nil
              should do it ?
              Appropriate if you error message says to select something better / different ??
              • daikuD
                daiku
                Thanks Tig. My tools are specific to a very specialized group of users (timber framers), so they'll know what should be selected. I think having the tool grayed out on the menu is all I need to do. CB.
                Clark Bremer
