    A virtual PC: Windows XP mode in Windows 7
    13 Posts 9 Posters 922 Views 9 Watching
    • N
      notareal
      It's similar to vmware. Welcome to a great world of virtualization.
      • olisheaO
        olishea
        Dude, my windows 7 says windows vista mode!
        So I've got windows vista within windows 7 within a mac 😆
        oli
        • soloS
          Microsoft version of Turducken.
          http://www.minnesotaorchestra.org/insidetheclassics/blog/uploaded_images/Turducken-thumb-750398.jpg
          • honoluludesktopH
            honoluludesktop
            Hi Olishea, Not sure I get it. You have a mac, with OSX in one partition, and Win7 in another partition, that has VPC with Vista? Or, is it VMWare running Win7, then VPC, and Vista? The VWinXp that comes with Win7 is a special VM that will not run outside Win7. The other VMs do. Or, do you have three partitions (can that be done?), each with its own OS?
            Sounds like my Ruby coding, to much redundancy:-) Or are you looking at a applications compatibility menu that gives you the option to run Vista apps in Win7, or cause the display to look like Vista. In those cases, you don't have Vista, but a switch that tries to make Win7, Vista compatible. I currently run WinXp with a "classic" desktop that resembles Win98SE:-) Haven't jumped to Win7 yet, am waiting for SR1, and a affordable 3 Ghz. multi-core processor. Hope I can keep my "classic" display mode.
            • T
              tomot
              Last year when I had more time on my hands, I was running an XP window within Ubuntu and I had figured out how to cut and paste between the 2 VM's, not a trivial task. I don't know if all of this VM stuff is getting any easier yet.
              Whats more interesting, as far as I'm concerned, is to see how with VM, one is able to create Portable applications that can run on any computer, regardless of which OS the computer is running.
              my plugins
              tomot
                Aerilius
                As far as I know there is a portable version of VirtualBox, but I haven't tested yet.
                I don't believe that a nearly complete XP in Windows7 is the most efficient way of compatibility regarding performance, but it is the most reliable. And with virtualisation, you can do great things: you do not need to boot the virtual XP all the time, you can just turn it off and on and this works by far faster than hibernate (althouh I think it's the same principle).
                • E
                  Ecuadorian
                  I tried to run Motiva SOAP in the virtual XP machine, but with no success. The virtual machine uses a generic display driver instead of having direct access to my graphics card, and SOAP is GPU-heavy.
                  According to Microsoft, this "XP mode" is aimed at businesses with very old accounting software that won't run in Windows 7. It's not meant to run graphics-heavy software. Grrr... XP mode was the reason why I bought Windows 7 Professional. I guess the "Home Premium" version would have been enough for me, if only there was a 64-bit variation in the local market.
                  -Miguel Lescano
                  • K
                    Khai
                    Home Premium is supplied with 32 and 64 bit DVD's in the case. (I know 😄 we bought the Family Pack.. a great deal - 3 seats for 199... 😍 )
                    • E
                      Ecuadorian
                      Khai:
                      Such a deal! I'm jealous, I bought XP Pro 64 OEM version (I assemble my own PCs and have an account with a parts importer) for $167.75+tax = $187.88. The Home Premium version was not available in 64-bits flavor at the time of purchase. OEM versions contain only one DVD in the case. Here's a picture of my package:
                      -Miguel Lescano
                      • honoluludesktopH
                        honoluludesktop
                        I could be wrong but I am under the impression that as long as your app. can be run from a networked hyper terminal (not sure of the name), that the virtual graphic adapter is not a problem. Currently, a memory stick containing a VPC compatible virtual drive loaded with its own OS and app, will run on any machine that has a VM that can access that virtual drive. Not bad for a first step. With multi core hardware, even overhead will be less of a problem with speed. In any case, running a Win98 app. on a new machine will be faster then then it originally ran.
