    How to draw a Dome in Sketchup... Not Bowl
    24 Posts 5 Posters 9.6k Views 5 Watching
    • N
      Nstocks
      @solo said:
      Nathan, are you trying to learn two apps at one time?
      Yes, ArchiCAD is going to be used for a different model as I've seen someone model it for me and I like it. Sketchup is for something else which will take less time than it would in ArchiCAD.
      • N
        Nstocks
        ok, i completely emptied my plugin folder and found that the 'Plugins' menu will not appear if i do that.. I then dropped only the 'Geodesic_SketchUp.rb' file in there and the menu appear upon relaunching SU and the tool worked fine.
        i'm concluding that you're not placing the ruby in the proper location.. here's a visual of the path: (click on the image to see it larger)
        [attachment=0:1blvdqs8]<!-- ia0 -->screen 3.jpg<!-- ia0 -->[/attachment:1blvdqs8]
        there's also a plugin folder located inside the actual app (right clicking on the SU icon then navigating it's contents) but this is the wrong location to place ruby plugins.. that's where all the exporters go and for the most part, stay away from there.. Also, make sure you're not going into the user library instead of the root MacHD library.. if you've done that and added a plugin folder there, remove it. there should not be a plugin folder in the ~user library
        so again,
        -go to the link solo provided earlier
        -scroll down to Geodesic_SketchUp
        -right click on the title and choose 'download linked file' (if you're using safari.. if you're in firefox, use the 'Save Link As...' dialogue)
        -locate the file named 'Geodesic_SketchUp.rb' which should be in your download folder or on the desktop (or where_ever you have your downloads assigned to)
        -follow the path i've shown above and place the .rb file inside the plugin folder
        -Launch or relaunch sketchup after the file has been moved and the plugin menu option should appear.
        report back πŸ˜„
        Worked ! I downloaded it and chose Append from the Safari pop-up which made it into a txt file, now it's a .rb it works.
        Can I size and scale the object? I need to make it more tent like with a door on it. The project is " Portable Temporary shelters for one person "
        Thank You !
        • jeff hammondJ
          yeah, after you draw the original shape, you can do what ever you want to it.. delete the bottom half if you choose then scale it, stretch it,squish it, etc.. (all using the scale tool )
          i'm not familiar with the ruby but apparently, all of the original dimensions have to be in inches (if you want the original to be 20' diameter, you'll have to enter 120 inches as the radius)
          the more subdivisions you enter, the more divided up the shape will be and you can delete individual lines or faces from the shape in order to create your door openings.
          • N
            Nstocks
            Yep, all is correct. I've not taken it into Hypershot to render ! Very fast. Now I'm wondering wether to try and draw my other model in SU πŸ˜•
            EDIT: How can I add dimension lines to the model ( if possible ) and do I change the layout unit in preferences ?
            Thank You
            • GaieusG
              I see there is not much to add here - except maybe the works of TaffGoch. Have a look at his geodesic collection in the 3D Warehouse - there are a good bunch of tutorials there as well.
              • N
                Nstocks
                There's some really good ones in there !
                How would I go about creating my own ? I want each part and face to be to precise dimensions, and the amount of faces are specific as I will be creating a model too.
                How did the creator of this model I downloaded, get this background in sketchup ? I've downloaded Hypershot, trial but it doesn't really look realistic so far.
                Thank You
                • GaieusG
                  Taff is a regular member here although doesn't visit SCF too often. He runs a Google Group where he supports anything about geodesic things if you are interested (I am also subscribed there although not being active). This is his "obsession" if you want to put this way πŸ˜† (and hope he won't get offended by this) and is very good at it.
                  • N
                    Nstocks
                    There are quite a few posts that all seem related, I should be able to find on the shows you how to construct it from scratch right?
                    Thank You
                    • TaffGochT
                      TaffGoch
                      Guilty as charged -- Although I prefer "enamoured" πŸ˜‰
                      Google Groups profile: TaffGoch
                      (Nstocks has now posted at the Geodesic Help Group, but that shouldn't exclude you all from continuing to reply with your help and experience.)
                      Taff
                      "Information is not knowledge." -- Albert Einstein
                      • GaieusG
                        Well, "enamoured" is also a good word. I will use it then.
                        πŸ˜‰
                        • 2 / 2
