Dental Moulding Problem
Guys
DOing a very big model of a high end kitchen and want to do a dental moulding just below the cornice and was wondering is there a quick way of doing a push pull on it to speed it up - Its taking ages and I know there is a quick way round it.
Cheers
Dermot
Hi Dermot,
For dentil molding, you could do it quickly without Push/Pull. Draw a single tooth and then copy it along the line of the molding with the desired spacing. Make a linear array of it and it's done. So if the tooth is 12mm wide and there's an 8mm gap, copy the tooth 20mm down the line using Ctrl+Move. then hit*n where n is the number of copies of the tooth you want.
Dave
p.s. I sent you an example of the beadboard thing to see if I understood what you're after.
Could you not copy multiple using the Control+ Move and type in x30 or whatever, and make it a group or component that can be later edited as needed? Do it in large enough sections like store bought trim.
EDIT
Whoops, Dave R got here first. -
Cheers guys - i went ahead and did the array method on my own - but only copied the face as i didnt want the line showing at the back of the tooth. It took a while but not as long as I thought to push pull all the teeth. I will post the model when I feel it is up to the required standard for you all to have a critique at it!
Here's another option. Draw a unit of the molding and make it a component and copy that component as an array. Then make the end units unique and modify them as needed to deal with the ends of the run.
Why not have face as component before array. In that way one push-pull will do all of them.
Cheers Guys
As always "there is more than one way to skin a cat" and i am grateful for all you budding taxidermy experts for showing me the ways!!
I would think that something like this is crying to be a dynamic component. Just scale it to length and it auto-calculates the actual width. But I am a complete newbie and someone might have objections to dynamic component creation.
Rick
