    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 548.5k Views 153 Watching
    • X
      xrok1
      worked for me in 7.1 pro?
      BTW, i just used this script for first time for an actual purpose instead of just playing! 😍 awsome thanks again. there was no other way i could think of to achieve the same result. i'm sure i could have tweaked and tweaked manually until i gave up. πŸ˜• put its not my style. πŸ˜†
      • C
        chango70
        Doesn't appear to work anymore... (The May Version works fine)
        • X
          xrok1
          yeah, i think i made have the older version.
          • B
            BlueScreen
            Hello my name paan,
            can you find or make sketchup plugin that can detect the edge of the texture and turn into that shape . It's more like make the rectangle turn into the shape of the texture that have transparent background .
            sorry for my bad English and i hope you understand what i meant
            and if you find it don't forgate to send an email to me at:
            fan_mustar@yahoo.com.my
            • plot-parisP
              plot-paris
              hi paan,
              I think that is quite difficult, because SketchUp isn't ment to do such operations with textures. I am not a ruby coder though.
              if you have got Adobe Illustrator there may be a workaround by importing the image, tracing it and then exporting as dwg. file. then you can import the dwg into SketchUp... haven't done it myself though.
              oh, and in future it might be better to open up a new thread for such enquiries. that is a completely different topic after all. having it as a separate discussion would help others too, when they are looking to solve similar problems πŸ˜‰
                @bluescreen said:
                Hello my name paan,
                404 Not Found
                (forums.sketchucation.com)
                • majidM
                  majid
                  I am confusing...FFD works for me occasionally!!!
                  • plot-parisP
                    plot-paris
                    same for me. sometimes it works with 3x3 control points. sometimes it doesn't. sometimes it just needs a restart. sometimes it needs a whole new file. and sometimes it doesn't work at all, no matter what I do (custom control point numbers don't seem to work at all anymore).
                    so I am afraid this script needs to be rewritten for SU 7.1
                    what a pity 😞
                    • C
                      CPhillips
                      Sorry, I wasnt keeping up on this thread.
                      There is a problem with the script under 7.1 or just 7.0? Can you give me some idea how to reproduce the bug? If it starts misbehaving open up the ruby console and see if it is printing any errors.
                      • majidM
                        majid
                        now I have only 7.1, and no idea , how it works/or not!!!!
                        • K
                          krash88
                          Here's what I get in the console on 7.1 running on XP Home...
                          WARNING: make_unique is a deprecated method of Sketchup:Group
                          Error: #<NoMethodError: undefined method `*' for nil:NilClass>
                          • starshipS
                            starship
                            I registered just to say thank you for this BRILLIANT plugin!
                            As a side note, I have Windows Vista and SU 7. No problems at all. The plugin is working fine for me. πŸ˜‰
                            • mariochaM
                              mariocha
                              Well, here, under 7.1 Mac, it still works but not as well as before. No matter where the group is located, the FFD dot matrix appears at the origin.
                              The console does provide a warning:
                              %(#0000BF)[onSelectionBulkChange1
                              Webdialog set to#Sketchup::Group:0x1ce30424
                              onSelectionCleared
                              Hope this helps.
                              %(#008000)[Mario C.
                              • mariochaM
                                mariocha
                                Good news, I guess the last update of SU corrected something related cause FDD now works just fine again.
                                No matrix offset anymore 😍 πŸ‘
                                %(#008000)[Mario C.
                                • B
                                  bmscmoreira
                                  First, thanks to the author for this great plugin! Unfortunately Im not getting it to work right with the latest sketchup release (SketchUp 7 (7.1.5803) and OSX.
                                  The live update does not work, and only the 3x3 FFD works (with no live update).
                                  My console reports this:
                                  When creating the 3x3 FFD control points:
                                  "WARNING: make_unique is a deprecated method of Sketchup:Group"
                                  When creating the NxN FFD control points:
                                  Error: #<NoMethodError: undefined method *' for nil:NilClass> /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyFFD.rb:453:in calcBernstein'
                                  /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyFFD.rb:210:in initFFD' /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyFFD.rb:209:in upto'
                                  /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyFFD.rb:209:in initFFD' /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyFFD.rb:200:in each'
                                  /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyFFD.rb:200:in initFFD' /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyFFD.rb:151:in startFFD'
                                  /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyFFD.rb:20"
                                  Hope to fix this soon... the plugin is a really must-have 😒
                                  http://www.brunomoreira.net
                                    Agisen
                                    thank you
                                    • V
                                      voodyneo
                                      thankyou
                                      • L
                                        lepiredesochs
                                        Hi All,
                                        I just installed this ruby, everything is fine except that I cant update the FFD ( I actually have no "update FFD" choice in the menu).
                                        Anybody can help?
                                        Cheers,
                                        Ben
                                          sus4
                                          mmm ..me to
                                          wheres UpdateFFD ?
                                          • BurkhardB
                                            Burkhard
                                            First page!
                                            http://www.ia-plus.de
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 20
                                            • 21
                                            • 12 / 21
