    Mathematics related problem
    23 Posts 4 Posters 3.1k Views 4 Watching
      @tig said:
      An input box always takes the 'type' of its input as that set by the initial default value:
      This is something that should be on the manual. I'll add it to the list.
        meeta
        yes i can see what you mean.. this is confusing for me.. I will do some experiments and figure it out! thank you fellows πŸ˜„
        Meet A
          All you need to do is not pass on the default value as a Length class. Use Float, Integer or String.
            Gruff
            Perhaps I am just a raw beginner myself but it appears that in his original snippet meeta is setting @M = bending.
            Shouldn't that be @M = result?
            Inputbox does not alter the input default value that I can see.
            therefore bending will still be 0.0 after the input.
            Resistance is .... Character Forming. Grin
              meeta
              yes your absolutely true.. i corrected that in my code and yet its showing the same results.. and besides if it were to be 0 then @M / 'anything ' = NaN? there is some problem there.. but I got a newer problem after sorting that out.. this is more interesting i reckon.. please have a look at this
              @b = 300
                    @h = 280
                    weight =((25.0*@b*@h) / 10**6)
                    prompts = ["Variable Load(kN/m) ", "Permanent Load(kN/m) ", "Max Moment known(Nmm)"]
                    loads = [0.0, 0.0, 0.0] #At this point enter 21, 50.1 and 0
                    results = inputbox prompts, loads, "Loads apart from Self-weight/ Or if moment is known, Please enter"
                    variable_load, permanent_load, moment = results
              		if (moment != 0)
              			@M = moment
              		else
              			uls = (1.35*variable_load + 1.5*permanent_load + 1.5*weight)*@length
              			UI.messagebox(@M)
              			UI.messagebox(weight)
              			UI.messagebox(results)
              			@M = 0.11*uls*@length
              			@shear = 0.60 * uls
              			UI.messagebox(uls)
              			UI.messagebox(@M)
              I don't know why, the weight that it should be showing is 2.1, but its showing 0.0032 something at the very beginning of the code.. its really taking a toll on me now! I know that many UI boxes is absolutely silly but that's my way of debugging because I know no other way! pls recommend any other method for debugging!
              Meet A
                Output the values to the Ruby Console, use the puts method. puts "Hello World"
                  meeta
                  yes i tried doing that,, but strangely the answer in ruby is always right but not in sketchup! so i figured something must be wrong in the code or in sketchup! hopefully its my code because that'll be easier to fix
                  Meet A
                    You are aware of the Ruby Console window in Sketchup, right? That's the one I'm referring to. That will let you see the values you get from the script running in SU's Ruby.
                      meeta
                      oh you mean that ruby console,, i thought you were talking of the interactive ruby console.. sorry about them.. let me try it out now!
                      Meet A
                        There are people that have worked out how to hook up debuggers to SU's ruby. But I've so far managed by using the Sketchup Ruby Console to output data throughout the script when I need to debug errors and abnormalities. It's the Sketchup Ruby Console that most people here on this forum will be referring to when they mention the Console.
                          meeta
                          ohh really? thanks i am newb with sketchup programming have been using sketchup for a few years though.. anyways now i wont look like a fool if anyone says console and i think of the irb! thanks
                          Meet A
                            For most people here, the Sketchup Ruby Console is the debugging tool. Some are also using Jim's custom console which has some extended features.
                              FYI, I'd never used Ruby before I started making plugins for SU. And I only recently installed a normal Ruby installation on my computer - never touched a full Ruby installation before.
                              So there's no wonder we're getting confused here. πŸ˜„
                                meeta
                                haha i see what you mean.. i ought to not touch the irb as well! i just downloaded and installed jim's web console.. its really good.. i dinno i could write and test the code in sketchup! i used to restart and edit it in msft notepad! not anymore.. always love increasing productivity : πŸ’š
                                Meet A
                                  I write in Notepad++ and use the regular Console to debug. Reload the changes by typing load "rubyfile.rb" into the Console. Crude - but it works. Though there are cases where I really wish I could step through the code...
                                    meeta
                                    ahh notepad++ old friend.. i used to do my c++ programming on it and then take it to university to test it! haha
                                    i think i am gonna take the night off and start over with this tomorrow might crack something.. πŸ˜„ good night world!
                                    Meet A
