Similar Group Finder - Script beginning needs testing
The Revit import only contains Components. Not blocks. And the axis fit the object.
That's fascinating. They are already components. Do they come in as components and instances where possible then?
I know autocad brings in blocks as components and instances. So if CAD and Revit do this already, what is the main sue for this script? Groups makers who realize later they want all their groups to be a single component and instance?
Yea, some come in as instances of each other. But there seem to be some time when they don't. Like when a window is mirrored in Revit, those windows doesn't come in mirrored in SU - but as a component type of their own. Small changes like that.
That's if you go Revit->DWG->SUIf you go Revit->FBX->3DS->SU I think all objects comes in a unique objects - all with origin in the model origin.
Ahh, I see. I'll poke around at the .3ds format and see if it is supporting import of components and instances at all. I kind of doubt that it is.
It does.
Though, it has had issues - not sure if they have been fixed. http://forums.sketchucation.com/viewtopic.php?f=11&t=12272
This is a very cool idea for a plug-in! I've thought of it myself, of course (most people who've worked with SU for very long probably have) but then thought of how hard it would be to write (and how slow it would probably run on my ancient PC
).But, I'm very glad to see the gauntlet has been taken up - especially by someone as talented at plug-in writing as Chris F.
I have been studying the transformations of Groups and the geometry inside for a plug-in I'm making, so I may have something to add to this in later stages (though I'm terrible at math).
Thom:
Not to criticize your coding style or Ruby skills (or those of "jeff99"), but I thought I'd point out that, in Ruby, both the "return" statement and the trinary conditional are technically superfluous, in this case.
Since the condition itself evaluates to either 'true' or 'false', and since Ruby returns the value of the last statement as the method's value, the entire contents of the method could be simply:
# Compare two floats with some tolerance. (Thanks jeff99 and thomthom) def self.floats_equal?(float1, float2, epsilon = 0.00000001) ((float1 - float2).abs < epsilon) end(One could also make it easier to use by overriding the === [triple equals] method for floats, but I don't know what the consequences of this would be. Maybe a '====' method, instead?)
I don't know what impact, if any, this would have on the speed of a plug-in, but one like Chris' would be doing a lot of these...
Also, is that a loose enough tolerance for this usage? I suppose it would depend on the scale and level-of-detail of each model.
Well, I'll stop wasting everyone's time now
hm.. good point about the trinary - not sure why it's even there.
As for the return keyword - I prefer to use them as I read my code better when I see an explicit return statement. All though for such a short method it could be skipped, but you know old habits and all.
But thanks for mentioning it. Since I picked up Ruby I've changed my coding style a few times as I've learned more about the language. -
Seeing how there's so many that develop plugin for Sketchup, I'm avoiding extending base classes to avoid potential conflicts. Had it been in a isolated environment where only I coded I'd extend them. (I often want to, but I play it safe.)
I use...
class Float def =~(num2,tol=10000) num1=(self*tol).to_i num2=(num2*tol).to_i return true if num1==num2 return nil end end #class Float
