    Night shot
    23 Posts 16 Posters 8.1k Views 16 Watching
    • olisheaO
      olishea
      this is just beautiful.
      oli
      • FrederikF
        Frederik
        I like this one A LOT...!! πŸ‘
        Would definitely sell for me... πŸ˜‰
        Cheers
        Kim Frederik
          davidh
          this is a cropped part of a revision to the original image.I have played with colour saturation using layer overlays and screening.this is probably closer to what I am trying to achieve.I know the image can look "blown out" but there is something about the blues and yellows/orange that really appeals to me.
            dylan
            A really excellent render and use of post pro.
            It has a great feel about it, the sky and trees work so well and not to mention I love the architecture.
            David, where did you get the timber siding material from? I'm about to start modeling a design of mine that I was planning a similar style timber.
            http://dmdarchitecture.co.uk/
              davidh
              Dylan,
              its actually a very low res image.I have attached it here ,if you can find a use for it.
                davidh
                The final image with the original render from vray.In post processing I decided I didn't like the small lights at the front and cloned them out.The planting at the very front was originally very green when I placed them in photoshop but by adding a red tint in "VARIATIONS" in photoshop,they tie in better.
                  Ross_K
                  Great stuff! I like that you blurred the vegetation in the foreground now, that's what was bugging me in the first one. just a personal preference - as this is looking like a pro-photo, it would add to it if you keep all the verticals vertical IMHO.
                  oh and for that photoshop brush, looks great, thanks for sharing! a dummy question - how do i get it to work? which folder do i drop it into in ps?
                  cheers
                  RK
                  http://www.rk-studios.ca
                  • olisheaO
                    olishea
                    open your brush options and click load brush set....something like that...and then find the file....append your new brush sets when it gives you the option. There are loads of cool grunge styles too for borders/adding cracks/scratches etc. google them.
                    stunning images david....how did you originaly get the blue hue to the raw render? what type of sky setup? u like convertibles don't you?!
                    oli
                      Ross_K
                      got it, awesome trees!
                      cheers oli!
                      RK
                      • N
                        nomo81
                        excellent comp, congrats!
                          avya
                          nice info
                          thanks 4 the link πŸ‘
                            davidh
                            oli is right regarding the brushes,just drop them into the brush folder for photoshop and you can then access them from the brush presets.
                            I have attached the visopt for the night shot.because you cant upload visopts directly i have renamed it with a .rb suffix.simply rename it with a .visopt once you have downloaded and it will work fine.
                            I have also uploaded the environment image which goes in both GI and background slots.Dont worry that the image background renders out somewhat pixalated,just render out an alpha channel and place the original sky image back in and you have a building with the same blue colour cast as the background.
                            In photoshop what I always do is increase the colour saturation and play with curves/gamma to darken the image.then i copy the image to a second layer and blend it using overlay or softlight.this really brings out the colour and changes the image dramatically.
                            evening blue hue.rb
                            • B
                              benwheels
                              really great image πŸ‘
                              It just gave me inspiration to do a similar image which I will post. Thanks for the link to the photoshop brushes, they are great!
                              • kaluK
                                kalu
                                Hi:
                                What kind of lights you use in this render?...Rectangulat lights?, Spotlight? or IES lights?...how many and the intense?..
                                Thanks...
                                THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                                • Bryan KB
                                  Wow. Just... wow.
                                  • kaluK
                                    kalu
                                    Hi, excellent work, can you upload the cloudy shot for the original shot in your image or wher did you get that night clouds, Thanks.
                                    Excellent work..AWESOME!!!!!!!!!! 😍
                                    • F
                                      FilipAGuy
                                      All render is great, but water is awesome for me !!! πŸ˜„ Realy good work. Thanks for sharing πŸ˜‰
                                      ASUS G73JH-A1 (ASUS G73JH-TZ002Z) i7-720 QM, RAM 8GB DDR3 1333 MHz, HDD 1TB (2x 500GB 7200 rpm), Blu-ray Combo, ATI Radeon HD 5870 1GB
                                      • C
                                        ccs1987
                                        i was looking for this for long time thanks for the HDRI. may i know the setting in vray for this night/dawn scene?
                                        Sketchup 8 pro
                                        Vray
                                        Intel Xeon W3520 2.67Ghz
                                        12Gb Ram
                                        Nvdia Quadro FX 1800
                                        • mitraniulianM
                                          mitraniulian
                                          Very good model , i love its clear minimalist lines and it is in perfect harmony with the landscape.
                                          [floatl:6bgg5g3o]I come from the land of the easter sun[/floatl:6bgg5g3o]
