    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
    • Chris FullmerC
      I think something like that is what you would end up having to do, but I was imagining you could cut out a lot of groups by first testing them with whay I was suggesting. If for example, you have 100 groups. And you don't know if they are possibly same components or not, you could test them based on their entity number.
      All groups with the same amount of entities, then get tested together for the same amount of edges, same amount of faces. Those that still have matching numbers move on to the next round of comparisons. Maybe we are down to 10 that have the same amount of entities, same number of edges and faces.
      Then compare those 10 based on all edge lengths. If their edge lengths don't match up, maybe try adjusting the scale using them method I outlined. Then if by chance you end up with any components that match entity.length, and edge amounts, and face amounts, and their edge lengths all match, then maybe you have a good chance of them being the same component.
      Then at that point, I was thinking you could look for any edge length that only has 1 identical edge length match in the other group. Then you have a starting point for aligning axes, using the identical edges. Just take one component and transform it to its one edge would be aligned to the other edge. Then you could compare all their point3d positions and see if they all are the same.
      Of course, that would all be done with temporary groups or proxy Point3d objects or something.. The original group would need to remain unaffected. But I think you could identify groups that appeared to be identical based on entity counts, edge lengths, etc. Then take those and try to aligned them, you could then just test their points against eachother. And if their points are identical, you've got a match!
      That is how I would forsee it happening. What I like about this method is that there is no looping through the model looking for angles. Just compare point positions.
      Just a thought,
      • Chris FullmerC
        wanna connect to my notepadd++ and work on it? ๐Ÿ˜„ PM me
          That's be cool - to make some real use of that Np++ feature! But I'm off to bed. Should have been there least an hour ago.
          How many hours behind GMT are you?
          • Chris FullmerC
            +8 I think. I am still at work - 16:50 here.
              You mean -8 . ๐Ÿ˜‰
              A full workday in difference. Could be tricky to try this outside the weekends...
              • Chris FullmerC
                Ahh yes, -8. Yeah, I normally catch you when you wake up and I'ts like midnight here. Or in the middle of the day for me and its the middle of the night for you. So maybe this weekend we'll try it.
                Actualyl though, I already most ofthe code. I got the part that sorts all entities and makes an arrayof all the groups to compare. Now you can just finish up everything after that ๐Ÿ˜†
                  I'll connect it to my magic 8-ball.
                  • ely862meE
                    ely862me
                    Kind of very useful this plugin ; i ve tried it on version 6 and it s pretty good (if u re setting well the variable debug).
                    So,thank you!
                    Take care!
                    Elisei
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                    • plot-parisP
                      plot-paris
                      guys, that new idea of the 'convert groups to components' plugin sounds exciting. I wanted such a script ever since i first importet my first model from 3Ds...
                      can't wait to see some first results ๐ŸŽ‰
                        So,thank you!
                        Take care!
                        Elisei
                        Regardless of the variable, you will run into a Sketchup bug where it's impossible to delete some edges, even if they are 100% planar.
                        • pep75P
                          pep75
                          Brilliant Plugin ThomThom!!! Perfect!!!
                            remus
                            You can download this plugin from the first post in this thread, there should be a link somewhere in the post or sometimes towards the bottom of the post. You dont need to have a pro license to use plugins.
                              Yes - download link is in the first post. In this, and most others on this forum, it's at the bottom of the first post.
                              • L
                                loolytoo
                                Thankyou! i got it and got it working
                                • T
                                  tomot
                                  this cleanup routine is simply outrageous! ๐ŸŽ‰
                                  Yesterday I ran the intersect with modelroutine, hoping to get rid of 3 redundant duplicate planes that each face of an imported model had been blessed with ๐Ÿ˜ข I finally stopped SU after 4 hours of trying to due that job. the SU file had grown to 600,000k in the task manager window. Your Cleanup routine on the other hand was almost instant.
                                  Well Done!
                                  my plugins
                                  tomot
                                  • plot-parisP
                                    plot-paris
                                    just cleaned up an imported model (from 3Ds Max).
                                    cleaned up edges: 62.700
                                    remaining edges: 84.300
                                    your plugin rocks, thomthom
                                    • FletchF
                                      Fletch
                                      ThomThom, ran this plugin on a file today - it actually took it a surprising long time to clean the file! ๐Ÿ˜ฒ
                                      So I opened Outliner and find that there are 920 uniquecomponents in the file. It was obviously imported from OBJ file into SketchUp because each component is called "OBJ_29" etc.
                                      So, if your Cleanup routine had an option "Convert All Unique Components to Groups" that would be great.
                                      It's a fairly simple model, shouldn't really be more than a 1 or 2Mb file if it was build properly in SketchUp... but it's a 29Mb file! ๐Ÿ˜ฎ
                                      I have tried selecting all the unique components and exploding them but SU appears to be chugging along quite some time on it, and I am unsure if it's completely frozen, or just working hard and ignoring me. ๐Ÿ˜’
                                      The absolute best for AutoCAD files would be one that said "Convert Identical Groups to be Identical Components"... wished for that many times when you have 50 columns that are all the same, but each is a unique "group" from ACAD.
                                      Fletch
                                        Converting the components to groups won't make the file any smaller. Internally, Groups and Components are pretty much the same.
                                        Yea, exploding large amount of geometry makes SU crawl to a halt. ๐Ÿ˜•
                                        Why is the blocks unique in AutoCAD in the first place? Blocks are imported fine into SU as components. This is really more a matter how the ACAD drawing is made.
                                        Mind you - I've also wanted a function to merge similar groups/components. When importing from Revit you often get windows that should be the same component as different components, but with different axis orientation.
                                        This could in theory be done easily. Except that there seem to be a bug in the SU API that makes the creating of groups some times crash SU.
                                        • GaieusG
                                          Hi Fletch,
                                          In case you have zillions of similar but unique components in your model, would a solution like in this topic (replace them with only one) work?
                                          http://forums.sketchucation.com/viewtopic.php?f=79&t=23777#p202554
                                          • soloS
                                            Bloody awesome, this script just saved me hours of work, a client sent me an Archicad model for me to get ready for presentation, It converted and opened up in SU looking like a total disaster, weighing in at 12MB. I ran cleanup with all options selected and Viola! it was perfect SU ready and saved at 3.5MB.
                                            This plugin needs to be on everyones machine.
                                            • 48
                                            • 49
                                            • 4 / 49
