    Vertical garden texture needed
    18 Posts 7 Posters 6.7k Views 7 Watching
    • N
      notareal
      This is more a inspirational source
      http://www.verticalgardenpatrickblanc.com/mainen.php
      • EdsonE
        Edson
        thanks, notareal. great source of inspiration. right now what i need is the means to show the idea of such a wall in a competition due shortly.
        http://www.mahfuz.arq.br
        • N
          notareal
          You could take some garden textures or even low poly plants and patch them to a large surface using pinwheel tiling and SU components.
          PinwheelAperiodicTiling.zip
          • EdsonE
            Edson
            this is very interesting! do you know of any plugin that does it? how did you manage to do it in the skippie you sent me?
            • soloS
              Edson, for a full wall it will be very hard to use actual geometry, so maybe an alpha plane .png image can be used slightly project away from wall surface.
              If you are planning to use close ups then I'd suggest a combination of .png images for mid to backgrounds and real ivy for close ups.
              Here is an image of how the close up mesh could possibly look.
              • soloS
                Notareal, that hurt my brain. 👊
                • N
                  notareal
                  Did made it by hand, some years ago. Original paper http://www.ma.utexas.edu/users/radin/papers/pinwheel.pdf
                  Easy to understand explanation http://local.wasp.uwa.edu.au/~pbourke/texture_colour/nonperiodic/
                  • soloS
                    Edson I used Vue to create a billboard of the 3D mesh, it's large size so if you use it feel free to reduce it in PS.
                    • N
                      notareal
                      Perhaps some ruby guru will get a inspiration of this. Pinwheel tiling has been used in the architecture.
                      http://local.wasp.uwa.edu.au/~pbourke/texture_colour/nonperiodic/fed1.jpg
                      http://local.wasp.uwa.edu.au/~pbourke/texture_colour/nonperiodic/fed2.jpg
                      Federation Square, Melbourne, Australia (image by Paul Bourke)
                      • EdsonE
                        Edson
                        thanks, pete. this will really help me. i shall be working on it during the weekend. i'll let you know how it goes.
                        cheers.
                        • GaieusG
                          If you don't mind, Pete, I have also put my hands on that image.
                          There are a bunch of excellent ivy textures here, too:
                          http://grannyart.blogspot.com/search/label/ivy
                          • bazB
                            baz
                            I've done some work for Fytogreen who make vertical gardens here in Australia.
                            I did these two a couple of years ago, I could probly do better now.
                            As mentioned the poly count gets unmanageable, wall.jpg shows native su with component plants rotated, not very realistic. And almost too much for my puter.
                            For the second job I built each group of plants separately, exported them at hi-res with transparency and used them as textures on the bald model.
                            It was a pain but the final result was acceptable. (these first two subsequently had a bit of work done on them to remove seams etc, these pics are straight su output)
                            If you think you could use any of these to save you some time, pm me.
                            baz
                            SU plants as materialswith texture and 'real' plants.native suone of the plant sections converted to a material
                            pictures of real green walls here: http://www.fytogreen.com.au/fytowall/default.htm
                            • E
                              Ecuadorian
                              Wow, did you apply these plants with the Component Spray while in an horizontal position? Hey, Edson, you could do the same! rotate your project, spray some plants, and then rotate the project again.
                              -Miguel Lescano
                              • bazB
                                baz
                                Unfortunately not, I'm not sure that the ruby was around when I did these.
                                So each planted was scaled a few times and dotted around, I should have put more effort into the ferns to stop them appearing so uniform but deadlines, etc...
                                  andre51
                                  Rendered in Vue
                                  Here's my try at a vertical garden..
                                  I think it is a wonderful idea and can't wait to use it in a project.
