    How do you set up a decent viewpoint for a render
    23 Posts 7 Posters 2.2k Views 7 Watching
    • Al HartA Offline
      Al Hart
      @honoluludesktop said:
      Here is a good place to start.
      This was good to read - and to remind myself that composition is not just looking at the SketchUp images and choosing the best one.
      However, I noticed that the author of this article had almost no interiors. It is often easier to position people in nature (except for some chopping or merging problems he mentions), then to find a good position for an interior. (Because the people contrast to the rest of nature - so it is often obvious was the focus is and what the background is. In a Kitchen, it is not always obvious what we are trying to highlight)
      SketchUp tends to make us lazy, because it moves both the eye and the target point as we adjust the image. I was tempted to write a second orbit tool for SketchUp which just moved to eye, or the target point, but not both, so we could see some other perspectives easier.
      Al Hart
      IRender nXt from Render Plus
      • Al HartA Offline
        Al Hart
        @edson said:
        if you look at the pictures taken by the best architectural photographers, you will never find converging verticals (unless, of course, the viewer is in front of a tall building looking up).
        (In camera class we learn how they used to use a special camera to keep the lines vertical even when photographing a building from the ground)
        http://www.bhphotovideo.com/images/images345x345/246991.jpg
        We were discussing this earlier today. Next weeks Rendering Tip will about using more 2 pt perspectives to keep those vertical line vertical. (As long as the camera and eye have the same height, they stay vertical, but sometimes you want to look up or look down and not have the vertical lines converge.)
        http://wiki.renderplus.com/images/thumb/4/4e/2-pt-sketchup.jpg/350px-2-pt-sketchup.jpg
        (Here we are looking down on the framing, but keeping the lines vertical)
        Al Hart
        • dermotcollD Offline
          dermotcoll
          This is what I got after my first attempt and I've shown the view I set up for render - I have absolutely no idea what went wrong - help!!!!
          When you burn your arse - you gotta sit on the blisters!!
            alpro
            To me it likes like either your camera is stuck inside a wall, try to move it forward a little, or if the renderer you're using has camera controls, your zoom is set to high and you're getting a closeup of the oppisite wall.
            Mike
              dermotcoll
              Thanks for the comments alpro. The view I am trying to render is shown in the attached picture and the output was as you can see - a green rectangular square of nothingness. I know my models are very basic but I thought i could get some sort of decent output after spending time trying to get the materials set up in Twilight. Is there someone out there who has a step by step guide to rendering a simple interior shot that I can follow?
              • Al HartA Offline
                Al Hart
                Click Zoom Out in SketchUp and render again.
                If what you see in the rendering is a wall, surrounded by the background, then you renderer may not support section planes.
                Al Hart
                • honoluludesktopH Offline
                  honoluludesktop
                  Dermotcoll, Not working with Twilight so can't help you there, and I don't think you understand alpo's comment. Hide the wall faces on a off layer, or move the camera (that makes the view). It looks like you placed the camera inside a wall.
                  Here is something that took about 45 minuets to do. The render needs a lot more work, but its a start. You got to have a good model to begin with. See the diagonal line with the chair, sun light and figure, the rule of thirds, the triangle with the vase, the asymmetrical composition, (like the photo tut. suggest?), etc. Because your floor is a photo image, it will not render much.
                  I use some lights (this is a interior render), several objects, reflected and bumped some surfaces, Another hour or two would make it for me. Of course there are others who could do much better in that time:-)
                    dermotcoll
                    Hi Honolulu and Al,
                    The view i have set up is shown in the above post - there is no wall!! My question is this - why does the renderer not render the view you see in SU?
                    I have tried others and they are showing wide angled views of the whole model - it is very frustrating - my screen can consider itself very lucky it hasnt got my shoe through it 10 times tonght!!!!
                    I am really showing my lack of experience here and I know I have to crawl before I walk but boy is it frustrating. IS there a really dumb user help desk I can seek advice from as you guys are really at a much higher level than me?
                      honoluludesktop
                      Hmm......, Can you upload the model exactly with the scene that fails, The original model had no ceiling, and presents a view looking down. I no longer have the model I rendered, otherwise I would upload it to you.
                        dermotcoll
                        Hi Honolulu
                        I have binned it! I am going to start from first principles again and remodel the building so that I can layer the walls etc. I need to try and accept my limits at the minute and get good models produced first and then work towards decent renders.
                        I appreciate all the community efforts to help but I must "pull my horns" in as they say here and calm down and work slowly to ensure I understand all aspects of this brilliant design medium.
                        • X Offline
                          xrok1
                          have you checked out the Twilight forum? there are some excellent tips and discussions over there and if you post your problems they can advise you or find out if its a bug or not. may be helpful for you and them. 😉
                          • X Offline
                            xrok1
                            whoa! i downloaded your file and wow you got alot going on there.
                            first of all i notice you have everything textured in Twilight but not in SU. i always texture everything with SU textures first then use those textures in Twilight or whatever renderer (otherwise its a nightmare to see one thing in SU and another thing in the render.. very confusing and hard to keep track of?????). example: put tiles on the floor in SU then open twilight material editor and add template of maybe ceramic gloss or something, then check the linked for bump texture.
                            also, change your camera to planar (you had it on spherical), render things small (500x500) till you get it right then increase settings and resolution. make small changes then test this way you know which change made the difference; there's nothing worse than getting something right and not knowing how you did it.
                            notice how the SU image and the Twilight image look similar thus avoiding confusion.
                            anyways chew on that for a while and see how it goes. keep us posted. hope that helps a bit
                            • X Offline
                              xrok1
                              check the field of view for wider shots:
                                dermotcoll
                                Cheers Xrok1
                                Appreciate the time you have taken over this. I will take everything on board and the help which you guys and the Twilight forum guys are giving will surely result n some half decent images in a few weeks.
                                Thanks alot
