    Sketchyphysics vehicles rendered with Twilight (UPDATE)
    41 Posts 30 Posters 9.0k Views 30 Watching
    • MarianM
      Marian
      😮 😲 ....(call my doctor, my jaw won't close)
      • E
        edmund
        wow. the way the shocks work in the jeep... great job. I love the way the tires and the tracks hug the terrain.
        • FletchF
          Fletch
          awesome work, Shareck!
          having problems with camera
          Twilight has no camera 😕 so not sure where the problem is, it just uses SketchUp scenes as the camera...
          then you can set your focal point for that cam with Twilight...
          but I can give a "Sneak Preview" - Twilight's got a great new view set-up tool that will make setting up DOF in Twilight so simple you may just 😢 and it makes setting up exactly what will be rendered pretty-much fool-proof. 😄
          Fletch
            shareck
            Hi All. Thanks for the comments. To Fletch - the problem with camera i Twilight is the same problem that i pointed on twilight forum a while ago. What it is is the fact that when i have my scenes set up in sketchup and when i play sketchup animation (scenes) the camera transitions are smooth. But when twilight renders the SP animation camera bahaves weird sometime. I don't know why. I thought i figured it out already as i didn't have this problem with other SP renders (for example the Pajero) but it happened again with the Stug. At the beginning at about 6th second the camera moves to the left for about 2 frames. And at the end, at the last SU scene there is no smooth transition, the camera just jumps into position in 1 frame. I didn't setup SP to follow any SP object, nor i set the DOF. I just don't know what i did wrong. I'll render it again, set up the scenes again and see if this happen again. It must be me doing something wrong as i havent heard of anyone else having this type of problems.
              shareck
              @newone said:
              How long the render toke?
              It took 23 hrs on a 2ghz core2duo.
              • N
                NewOne
                Not much at all... mine is core2duo @ 3.2, but overclocked to 3.8... and planning to beat 4GHz 😄
                We will more than grateful if you will find some time to make some kind of tutorial, starting with the begining -maybe this could help me (and others) to use SketchyPhysics better; since now I was able just to do pure basic things.
                • E
                  Ecuadorian
                  Shareck, I'm under the impression that this might be the missing piece to make your animations perfect...
                  http://www.smustard.com/script/FlightPath2
                  Although in your second video the camera seems to be pretty much under control. 👍
                  -Miguel Lescano
                    dylan
                    Im amazed with this. Both look fantastic, but the tank scene is awesome.
                    http://dmdarchitecture.co.uk/
                    • boofredlayB
                      boofredlay
                      http://twilightrender.com/phpBB3/images/smilies/Respect.gif
                      • EarthMoverE
                        EarthMover
                        Just saw these for the first time. WOW!!!! Never ever knew that kind of realism was possible with SU. Really great work!!!
                        Only critique is the materials. If the Truck had better reflection on the metal surfaces and the glass was improved with an HDRI as the background...the animation would really come to life...although the render time would certainly go up.
                        Content Creator at Skapeup
                        • C
                          Cyberdactyl
                          Most excellent shareck.
                          The subtle flapping and jerkiness of the tank's track where it re-engages the guide wheels is awesome.
                            Andrija Posarić
                            This is outstanding work Shareck, I like them both, and am impressed with your result 😄 Could you explain your workflow to us? I tried skphisics a while ago, but I wasn't aware of it's potential and capabilities 😮
                            Amazing 👍
                            Cheers, Andrija
                            • E
                              Eulgrand
                              I couldn't imagine one could achieve this result with SP. Outstanding 👍
                              • numbthumbN
                                numbthumb
                                OMG...Is this what they call assisted suicide?
                                Seriously, that Sturmgeschütz is absolutely unbelievable. 👍
                                Keep up the good work!
                                Comfortably numb...
                                  shareck
                                  It's been a while and i'm back with an update. the stug video is now on youtube and the camera is almost ok. would be perfect but i messed up with timing so the tank is moving out of the picture at times. the fire and smoke from the gun i added in photoshop.
                                  [flash=560,340:89bgdggd]http://www.youtube.com/v/ipY8kgCbA94&hl=en_GB&fs=1&[/flash:89bgdggd]
                                  • EscapeArtistE
                                    EscapeArtist
                                    Absolutely amazing.
                                    • simon le bonS
                                      simon le bon
                                      Incredible work!
                                      Never thought something like that could be done with SU & SketchyPhysics!!!
                                      I'm waiting for long to have time to study SketchyPhysics. Now I can't pass over. I just have downloaded the last version.
                                      Thank you shareck for the tasks ahead you're bringing to me 👊
                                      😉 simon
                                      • david_hD
                                        david_h
                                        2 words. . .
                                        IN CREDIBLE!!!
                                        • ken28875K
                                          ken28875
                                          Awesome!!! wonderful animation! 👍 👍
                                          Follow Your Dreams.
                                            stevebo
                                            Fantastic! It looks like it could be the graphics from a game!
                                            How did you do the material for the ground?
                                            I'm very impressed! Every once in a while, people amaze me by expanding on the capabilities of Sketchup!
                                            • 2 / 3
