    Rendering Challenge - Bathroom sink
    62 Posts 21 Posters 17.1k Views 21 Watching
    • david57D Offline
      david57
      Looks very nice, Gaieus. I like the lighting. I dont remember ever doing an interior render and
      should start one of this days.
        Well, this was my first of this genre, too. 😳
          OK, maybe a close-up - now with marble sinks to make it even more extreme 😳 (now only used Low+ preset).
          • Al HartA Offline
            Al Hart
            Marble works pretty well
            Al Hart
            IRender nXt from Render Plus
              Imagine I wanted marble sinks at home. My a*ss would be kicked. 😒
                bytor
                Nice Challenge Al - thanks!
                Here is my go - npr composite using multiple line exports from su and 3 different Twilight Render images. 1 = #9 preset @ 97 passes, 2 = #9 preset @ 1 pass, 3 = clay @ interior fine. I would probably try something to emphasize the lighting a little - same trick for the cans as Gaieus.
                Gaieus - really like your images! 👍
                Find the Cost of Freedom.....
                  tallbridgeguy
                  There is no way I can compete with the last two renders so I cheated and added a diversion....and tried to add a story. I used Kerky with no clue about what I am doing....it seemed so simple in the brochure. (ha)
                  Trying to make a decent render shows how hard it actually is (well for me.)
                  Thanks for the challenge!
                  Nielsen
                  http://www.tallbridgeguy.com/
                  • Al HartA Offline
                    Al Hart
                    If this is your first rendering - Good Work! 😄
                    What did you use for the human figure?
                    Al Hart
                      tallbridgeguy
                      This is my first interior and I really don't know how to get the lighting right. (and the walls and the)
                      I found the young lady on the google warehouse. I can't take any credit for her.
                      thanks again for the challenge!
                      Nielsen
                      • Al HartA Offline
                        Al Hart
                        This is a "clay rendering" with the addition of lights, highlighting, reflection, and sketchy edge lines.
                        (Click on image to remove scroll bars)
                        [Edit: New image with vanity moved up, and better lighting]
                        http://wiki.renderplus.com/images/a/a7/Bathroom-clay2.jpg
                        (Clay Rendering is created by treating all the materials as white, and ignoring textures.
                        It highlights the quality of the actual model, rather than colors and textures)
                        (Rendered with IRender nXt using the Clay Rendering option and the Edge Line overlay option. 6 indirect lighting passes - 13 minutes rendering time)
                        Al Hart
                        • Al HartA Offline
                          Al Hart
                          @eulgrand said:
                          Al, your sketchy edges say your ground is too high (maybe on purpose ?). But the charcoal effect is fine.
                          Oops - I need to learn better how to put a room around an existing object.
                          I'll lower the floor if I try any more renders.
                          [Edit: I replaced the image in the original post, with the vanity moved up]
                          Al Hart
                          • E Offline
                            Eulgrand
                            Kerkythea - MLT (BPT) approx. 70 passes (6 hours - my machine is sooo slow 😢 )
                            A bit of post-pro (heavy noise reduction + warm filter)
                            Bytor, definitely like your walls 👍
                            • Al HartA Offline
                              Al Hart
                              Hopefully someone will offer some good advice.
                              My "first" advice is to add more lights - probably a ceiling light or 2.
                              Then,, when you get good lighting you should try adding some more reflection. I think you made the bowls reflective - but you should make the countertop reflective as well, and of course, the faucets. It may be that you have already made these reflective,and the highlighting will show up better when you add more lights.
                              I guess I don't like the word challenge. I implies that only the best designers should participate. I think I'll call the next one a "Rendering Workshop". This should be a good place for renderers (people) of all levels to show their work and get advice and learn from others.
                              Al Hart
                              • Al HartA Offline
                                Al Hart
                                For this one, I turned off the lights and lit the candles. (I also used the post-rendering brightness slider to adjust the brightness of the final image. Otherwise auto-exposure compensates for the low lighting level.)
                                However, with this little light, my camera could not get good focus. 😉 (I set focal distance to 7' and the depth of field to 1.0 to blur the image. You can see the faucets are slightly out of focus.)
                                (IRender nXt - 16 rendering passes - 43 minutes - to let the candle light bounce off of the other surfaces.)
                                Al Hart
                                • EarthMoverE Offline
                                  EarthMover
                                  Here's a go using Fryrender...I only let it cook for 3 hours on my laptop, then did some post work in photoshop. I'll probably let it go overnight and update tomorrow.
                                  Content Creator at Skapeup
                                  • Al HartA Offline
                                    Al Hart
                                    It's hard for me to evaluate this view.
                                    It may be just me, but the only feature I can really see and evaluate from this view is the daylight effect on the far wall. And of course, the excellent plant. But I would to see more of the shadows to the right of the plant to see how well the daylight effects are working.
                                    If you decide to change the model, pehaps you can put the window on a different wall so it illuminates the sink more directly, and raise the camera above the sink so we can see it better.
                                    Al Hart
                                      alpro
                                      Here's my Vray try, 12 mins at 1024x768. Only sunlight, coming through skylight. Some post pro, brightness/contrast adjustment, vignette, and resize.
                                        tallbridgeguy
                                        Darn everybody is still doing better than me! Oh well I am learning a lot.
                                        KT - MLT for an 1.5 hours....
                                        Nielsen
                                        • Al HartA Offline
                                          Al Hart
                                          Some people are adding lights above the mirror.
                                          Unfortunately the ones I grabbed from the 3D Warehouse added about 300,000 faces to my drawing.
                                          But Ms. SketchUp could see better if there was some light up front.
                                          Al Hart
                                          • N Offline
                                            notareal
                                            I assume you have already read getting started tutorial and tutorials master list.
                                            Add more light and use some nice materials from file repository or Documentation and Sharing > materials and turn on soft shadows. Perhaps you could use some IES lights, easy to set, but you need to get definition files from manufacturers website. Bevel all edges... or use DOF to soften sharp edges.
                                            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                            • 1 / 4
