    Sketchyphysics vehicles rendered with Twilight (UPDATE)
    41 Posts 30 Posters 9.0k Views 30 Watching
    • david_hD
      david_h
      โ˜€ ๐Ÿ˜ฎ ๐Ÿ˜Ž Blown away. You know. . .I bought SkPhys Years ago and have never used it. and now with TW in the mix. .. I am just amazed. I guess I oughta give that a try. ๐Ÿ‘
      You know what is really cool . .. that 4 x 4 does really well considering there's no one behind the wheel! ๐Ÿ’š
        shareck
        SP is free. most recent version http://forums.sketchucation.com/viewtopic.php?f=61&t=17877
        • david_hD
          david_h
          @shareck said:
          SP is free.
          either I have totally lost my memory or I got ripped off. Thanks. ๐Ÿ’š
          Ah! Memory comes back! โ˜€ It was SUAnimate I bought. Got SPhys for free.
          Whew. . .thought I was going brain numb there for a minute! Please don't tell me SUAnimate is free too, cuz Then I did get ripped off. ๐Ÿ˜ณ
          • marked001M
            marked001
            wow! never ever imagined this was possible with su... these are ridiculously awesome!
            http://www.revision21vis.com
            instagram: revi21on
            • K
              kwistenbiebel
              I wanted to have some cars driving in my architectural scenes but it I find Sketchyphysics way too complex to use it for that purpose.
              Someone should create a 'for dummies' version that automates the process.
              Dropping in moving objects in a scene should become easier.
              Great animations by the way! ๐Ÿ‘
              • GaieusG
                Wow, these really rock! (I like the first one better though - maybe there I cannot see that there is no driver in the car ๐Ÿ˜‰ )
                • P
                  pav_3j
                  wow.
                  just dl'd SP on that example alone.
                  fantastic
                  pav
                  Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                  • N
                    NewOne
                    This is f***in' AWESOME !!! ๐Ÿ‘ ๐Ÿ‘
                    How long the render toke?
                    • olisheaO
                      olishea
                      amazing!! the way the tank rocks back and forth when it stops is very realistic!! well done. ๐Ÿ‘
                      the car needs new shocks!!
                      oli
                      • E
                        Ecuadorian
                        Hats off to you, Shareck. Vehicles look very "alive".
                        And if you can write or record a "for dummies" tutorial on car animation... ๐Ÿ’š
                        -Miguel Lescano
                        • MarianM
                          Marian
                          ๐Ÿ˜ฎ ๐Ÿ˜ฒ ....(call my doctor, my jaw won't close)
                          • E
                            edmund
                            wow. the way the shocks work in the jeep... great job. I love the way the tires and the tracks hug the terrain.
                            • FletchF
                              Fletch
                              awesome work, Shareck!
                              having problems with camera
                              Twilight has no camera ๐Ÿ˜• so not sure where the problem is, it just uses SketchUp scenes as the camera...
                              then you can set your focal point for that cam with Twilight...
                              but I can give a "Sneak Preview" - Twilight's got a great new view set-up tool that will make setting up DOF in Twilight so simple you may just ๐Ÿ˜ข and it makes setting up exactly what will be rendered pretty-much fool-proof. ๐Ÿ˜„
                              Fletch
                                shareck
                                Hi All. Thanks for the comments. To Fletch - the problem with camera i Twilight is the same problem that i pointed on twilight forum a while ago. What it is is the fact that when i have my scenes set up in sketchup and when i play sketchup animation (scenes) the camera transitions are smooth. But when twilight renders the SP animation camera bahaves weird sometime. I don't know why. I thought i figured it out already as i didn't have this problem with other SP renders (for example the Pajero) but it happened again with the Stug. At the beginning at about 6th second the camera moves to the left for about 2 frames. And at the end, at the last SU scene there is no smooth transition, the camera just jumps into position in 1 frame. I didn't setup SP to follow any SP object, nor i set the DOF. I just don't know what i did wrong. I'll render it again, set up the scenes again and see if this happen again. It must be me doing something wrong as i havent heard of anyone else having this type of problems.
                                  shareck
                                  It took 23 hrs on a 2ghz core2duo.
                                  • N
                                    NewOne
                                    Not much at all... mine is core2duo @ 3.2, but overclocked to 3.8... and planning to beat 4GHz ๐Ÿ˜„
                                    We will more than grateful if you will find some time to make some kind of tutorial, starting with the begining -maybe this could help me (and others) to use SketchyPhysics better; since now I was able just to do pure basic things.
                                    • E
                                      Ecuadorian
                                      Shareck, I'm under the impression that this might be the missing piece to make your animations perfect...
                                      http://www.smustard.com/script/FlightPath2
                                      Although in your second video the camera seems to be pretty much under control. ๐Ÿ‘
                                      -Miguel Lescano
                                        dylan
                                        Im amazed with this. Both look fantastic, but the tank scene is awesome.
                                        http://dmdarchitecture.co.uk/
                                        • boofredlayB
                                          boofredlay
                                          http://twilightrender.com/phpBB3/images/smilies/Respect.gif
                                          • EarthMoverE
                                            EarthMover
                                            Just saw these for the first time. WOW!!!! Never ever knew that kind of realism was possible with SU. Really great work!!!
                                            Only critique is the materials. If the Truck had better reflection on the metal surfaces and the glass was improved with an HDRI as the background...the animation would really come to life...although the render time would certainly go up.
                                            Content Creator at Skapeup
                                            • 1 / 3
