    How to add entities inside a group?
    6 Posts 3 Posters 510 Views 3 Watching
    • N
      NewOne
      Well, title says all... I can't figure out how to add entities (component instances) inside a group that I already have created. It contains some entities, but I want to be able to add more things inside it, using a ruby script.
      And one more thing that bothers me: when I initially made the group I did it like this:
      group = model.active_entities.add_group entities_array
      group.name = name
      But, the problem is that I gave a name just to the group entity and since group.definition.name is not a valid method, I'm stuck. Why I need to give same name to the definition as the entity? Because when/if I use right-click -> Make Component, the new created component instance will take definition's name.
      Thank you.
        You get a groups definition by group.entities.parent
        But, there's a bug in SU where that reference some times get mixed up with the wrong definition.
        I use this snippet to get groups definitions:
        def self.get_real_group_parent(group)
          if group.entities.parent.instances.include?(group)
            return group.entities.parent
          else
            Sketchup.active_model.definitions.each { |definition|
              return definition if definition.instances.include?(group)
          return nil # error
          To add entities to a group:
          group.entities.add_face(...)
            > group.name = name
            Thank you.
            Last things first...
            name=group.name
            inst=group.to_component
            defn=inst.definition
            defn.name=name
            ### done !
            To add to ANY entities - including those of a group or definition...
            ents=group.entities
            tr=Geom;;Transformation.new(point)
            ents.add_instance(defn,tr)
            • N
              NewOne
              thanks thomthom, can I borrow your snippet for what I need? πŸ˜„ It shows very useful!
                Go ahead!
