    WebDialog help - hide scrollbars
    31 Posts 7 Posters 8.2k Views 7 Watching
      I use STRICT doctype and <body scroll="no">. Since this is for an application I don't care that it's not standard.
      • chrisglasierC
        chrisglasier
        Don't you think in good time such application may well need web connectivity, say, to get or set remote data? Making things comply with today's standards could save future hassles for following generations.
          I'm a strong proponent of webstandards. But I'm also pragmatic - this is to work around an SU bug where the scrollbar argument in SU's Webdialog class doesn't take effect.
          It's not something that will cause problems for future plugins - if future SU corrects the bug, then this little attribute don't do much.
          • chrisglasierC
            chrisglasier
            Ok no big deal except I am working on the API webdialog (which will include snippets). It seems there is a conflict between this:
            body{
            border;0px;
            margin;0px;
            overflow;hidden   }
            and STRICT doctype, so shouldn't the solution be within HTML compliance and standards and not within Sketchup webdialogs?
            It would be useful for me to understand.
              I don't know why the overflow with STRICT doctype within a Webdialog doesn't work - it's how you do it with websites.
              Seeing that the Webdialog has a scroll property for it's creating of the ruby class I'd expect that the scrollbars should be set from ruby. I think that the embedded IE control has a scroll property which developers who wish to embed HTML content can set to a fixed override. Why this argument isn't adhered to, I don't know.
              I wonder if the SU dev team has been made aware of the scrollnar bug.
              Was it so that this is PC only - that it works as expected on Mac?
              • chrisglasierC
                chrisglasier
                Thanks Thomas. BTW I think it therapeutic to use a STRICT doctype then abuse it by doing something non-standard - appeals to cynical Brits like me!
                  It's make the standard conformant me twitch. x_X
                    Ah!
                    There is a standard conformant way!
                    html
                      overflow; hidden;
                    When removing scoll="no" and adding that to the CSS the scrollbars disappeared in STRICT mode.
                    Armed with that, you could sub-class the Webdialog class and tap into it's .new method and pass on the scroll argument to the webdialog when it's ready. Unless you're fine with just having it defined in the CSS and ignore the Ruby argument.
                    I was going to make a wrapper for myself, that took care of the matter where the size is only being read the first time it's created. At the moment, if you try to change the size arguments for a non-resizable webdialog they won't take effect unless you purge the saved settings.
                    • chrisglasierC
                      chrisglasier
                      Good and noted! And used here.
                        I don't know why I didn't try that before. I know that when switching between STRICT and quicks the behaviour of HTML and BODY changes.
                        Glad we finally worked it out.
                          @newone said:
                          One more thing: JS statement element.selected = true; did not worked on my native SU instalation. After I updated my Internet Explorer from 6 to 7, it did worked... how is this possible, because in SU I still have IE4 ?
                          You don't have IE4 in SU. You have whatever is installed on the system.
                          That's one of the reason I would prefer is SU used a standalone web-frame that isn't linked to the system.
                          • N
                            NewOne
                            Please run this.
                            @my_dialog = UI;;WebDialog.new('Check Version', false,"",400, 100, 300, 300, true)
                            html = '<html>
                            <body>
                            <script type="text/javascript">
                            var browser=navigator.appName;
                            var b_version=navigator.appVersion;
                            var version=parseFloat(b_version);
                            document.write("Browser name; "+ browser);
                            document.write("<br />");
                            document.write("Browser version; "+ version);
                            </script>
                            </body>
                            </html>'
                            @my_dialog.set_html(html)
                            @my_dialog.show{}
                            @my_dialog.bring_to_front
                              You can't rely on navigator.appVersion. Since IE4 and up it has always reported 4 for legacy support reasons. You must parse the navigator.userAgent string.
                              http://javascript.gakaa.com/navigator-appversion.aspx
                              404 Not Found
                              (www.quirksmode.org)
                              • N
                                NewOne
                                If so, why does it renders buttons so old-way? 😞
                                  IE is quick to do weird stuff to form control. In general - form controls in any browser is unpredictable.
                                  If it'd been rendering like IE4 it would be permanently stuck in Quicks mode. Standard mode in IE wasn't introduced until IE6.
                                  • Dan RathbunD
                                    Dan Rathbun
                                    Sometimes Standards Compliant mode on MSIE turns MS Common Controls back to the old 'unthemed' set (they look like old Win 3.x ugly controls.)
                                    See my post in the other WebDialog thread for a META tag that goes in the HEAD section.
                                    Sometimes it can turn the 'XP themed' ver 6 controls back on.
                                    I don't know if they work in Strict mode, but the tag should work for Tranistional mode.
                                    http://forums.sketchucation.com/viewtopic.php?f=180&t=22698#p196706
                                    I'm not here much anymore.
                                    • 2 / 2
