    Roman basilica - WIP
    54 Posts 18 Posters 8.9k Views 18 Watching
      Hi Alan (and thanks for the compliment - all I know about SU, have learnt from you guys... 😉 )
      Yes, you are totally right - this is only something I put in to get an initial "feel" for the lattice work - more exactly to indicate that no glass window but something like that will be there.
      Certainly yours would be much more authentic and "stylish" but I am at the beginning of texturing only so I still have time to tweak these details. I am definitely planning to use some kind of material there however (probably would work in plain SU as well but in a render I can always assign some kind of a subtle bump and shininess so the "2D feeling" wont be so obtrusive from a distance) but that's not a big deal to create.
      And another interior (now without internal lights) again, just to test the bumps on the terrazzo floor (I couldn't resist this beautiful marble material for the stairs but certainly won't use it in the final version as we haven't found any such, magnificent material here and even when something like that comes to light, it was definitely not used as building material as there is no marble in the region and it was imported from Noricum/Austria at that time).
        Definitely not. This is a remote, half barbarian, military province on the frontiers, in the 4th century. Not even one piece of such (mainly earlier) "clascic" column has been found here so far.
          pichuneke
          I have something to ask you, Gaieus: Weren't Chorintian, Jonic... columns? Those squared columns doesn't fit with my view of a roman basilica...
          I mean, something like this video: http://www.youtube.com/watch?v=zNHR4Q8kpGU (As always, I don't know how to insert a youtube video in this forum) 😄
          (I believe that I may have commited a mistake in the question, please correct me if it's wrong, to improve my english).
          Forgive my spanglish...
            pichuneke
            Ok, it's curious and interesting, for me. I am wondering which textures are you going to use... I supose that the walls were painted.
            (YES, I know that texturing roman walls is a nightmare, that's why I ask you that 😆 )
              Aerilius
              Also in my region, the barbarians abused the roman remains, mainly as stone quarries. From one villa rustica, there are still 2 out of ~35 columns left - used as grindstone by a blacksmith.
              By the way, how did you make the fire basins (is that the english term?)? When I place a KT light in a png image of a flame, the image turns out too bright.
                Pure, whitish ("eggshell") colour of stucco/plaster with mixed stone and brick bumpmap underneath. Just like in my regular corner bar ("bodega")
                @aerilius said:
                By the way, how did you make the fire basins (is that the English term?)? When I place a KT light in a png image of a flame, the image turns out too bright.
                The original name would be tripous (this is what the English distort as tripod - from the stem of the Genitive case "tripodos") but I am not sure how they would call it as they use the term for photographic and other "three legs" (which it means in Greek).
                Anyway, place the point light in front of the flame image as per Miguel's (Ecquadorian's) method here. Actually, you can even re-use the flame/fire component - just change the Twilight spotlight to a KT spotlight and ready to go.
                Going on with texturing (now it looks like a little scale model placed on the grass 😄 )
                  pichuneke
                  I believe that you are modeling the new ampliaton for your corner bar... (the words that all tourists learn in spain are fiesta, paella, vino and bodega) 😆 😉
                  Well, It's really curious for me the way the roman empire style ended in your country. Here, visigoths evolved using a style (columns and arcs) that is believed they took from some regions at the north of spain in later roman period (not remains of it except in tombstones). After it, moorishes copied it:
                  http://img169.imageshack.us/img169/6085/arcodeherradura28lascla.jpg
                  (Source: http://es.wikipedia.org/wiki/Archivo:Arco_de_herradura_%28Las_Claras%29.jpg )
                  It hapened in all the roman empire. In Spain too. In fact the famous mosque of Córdoba (now is catholic Cathedral) has one of the best collection of roman capitals of spain. In their columns.
                  http://farm4.static.flickr.com/3111/3445848872_4686e3bd87.jpg
                  Source (with more resolution): http://www.flickr.com/photos/javier1949/3445848872/in/set-72157616634272377/
                    Ah yes, but as you say, those Goths learned to build in Hispania, not in Pannonia (where they had also been). Just like their "brothers", the Ostrogoths, who went to Italy from Pannonia and lerned to build only there.
                    Here, there wasn't much to learn.
                    And wow, look at this wood texture! (It's untouched/unchanged Olda's wooden material pack from the KT Forums). And yes, before somebody mentions, I know that the timber/beam ends should be painted with something different. 😒 I will, promise (although "from below", no-one would spot it out).
                    • MALAISEM Offline
                      MALAISE
                      Hi Gaius, great work you're doing !
                      Could you explain how you extract a "plan" of the first picture leading you to the drawing of building. Do you use PhotoMatch ?
                      Please let's see other W.I.P 😍
                      MALAISE 👍
                        I'd love to use PhotoMatch (although not for constructing but for later "matching" the perspective 3D model with the photo) however, as you can see there, there are no vertical edges of the building as it is just the ruins - say the "plan".
                        So that's it basically; as meticulously mmeasuring everything on site and drawing the remains (to scale) by hand is part of the documentation process of an archaeological excavation, I have the plan exactly measured and drawn already, when I start with such a project.
                        • Alan FraserA Offline
                          Alan Fraser
                          I thought you might like a headsup on this, Gai. http://www.procedural.com/cityengine/import-export/export-samples.html
                          There are links to some exported City Engine buildings. They are pretty high-poly, but can be got into SketchUp. They contain some fairly useful textures too...variations of typical Roman brick and some very decent roof tiles.
                          3D Figures
                            Thanks Aalan, already trying to import. Unfortunately the images are generally rather low res but will see what I can use.
                              pichuneke
                              With my free version of sketchup I can't import the roman houses with textures.
                              Collada gives me problems with sketchup. I have problems too when importing/exporting to Blender.
                                Alan Fraser
                                Even the Pro version crashes when trying to import the Collada 2009 file. I had to use the second, triangulated version. It still took several minutes to import.
                                3D Figures
                                  pichuneke
                                  By the way, you have to visit this guy. I am his number one fan. 😄
                                  Error 404 (Not Found)!!1
                                  (sketchup.google.com)
                                  He does a model in just one week. I enjoy rendering for fun his models with kerkythea, this is my last one based on his Trajan's Forum.
                                  http://img94.imageshack.us/img94/8312/trajano.th.jpg
                                    Aerilius
                                    Me too.
                                    The collada version does not contain components. And as the roof + all balustrades are modeled, they make up 3/2 of the file.
                                    I think in large models, especially generated models, its initial set up makes are huge difference (i.e. png images for balustrades...). Recently I reworked the roof tiles of a model and reduced the poly count to less than the half.
                                    Has someone found the roman man? He would be useful for my me. I dream of something like this:
                                    [flash=425,344:31lc30xb]http://www.youtube.com/v/ZA3gzqG94JQ&hl=de&fs=1&[/flash:31lc30xb]
                                      Alan Fraser
                                      It will cost you a few cisterces. 😉 http://www.formfonts.com/viewModel.php?id=8465&config=1&action=&sub_action=&type=&active=
                                      Of course you could always make a 2D Face Me from the thumbnail...for your own use, of course.
                                      3D Figures
                                        I have a couple of photos taken in a Roman reenactment camp this summer. Some of them are actually not bad for 2D Face me's (sigh... planning to make some for quite a while now...)
                                        http://picasaweb.google.com/csaba.pozsarko/Lugio2009FirstDayAndOpeningCeremony#
                                        There are more images - I would just need to organise them and upload. Anyone feel free to use them for face me's or such however.
                                        Update; this one is particularly tasty:
                                        http://lh6.ggpht.com/_zcvsIuYiVbo/Sm61nMRrRJI/AAAAAAAABhE/lAOP01kL6zg/s720/Lugio_2009_0188.jpg
                                          Alan Fraser
                                          Some more here. http://www.erminestreetguard.co.uk/cov/index.htm
                                          Plebeians, obviously....terrible hairstyles. 😄
                                          3D Figures
                                          • michaliszissiouM Offline
                                            michaliszissiou
                                            It happens every were. It happens in greek orthodox churches too. Ancient marbles and columns from greek temples as walls of beautiful byzantine churches. This is the truth. Lets not talk about "barbarians", lets talk about what is civilization.
                                            • 1 / 3
