    Solid objects?
    42 Posts 12 Posters 7.8k Views 12 Watching
      @chopper greg said:
      ...always end up pushing an object through another or one object sticks to the other.
      Now thatpart could be overcome by using groups/components.
      • X Offline
        xrok1
        excuse my opinion but if you need to place all studs then drywall ... in SU before you build it you have no business building anything! if you need to build machined parts and put them together for something like a pump for example, then use Solidworks or something similiar. besides inferencing and careful design work should be totally capable of keeping you out of trouble. IMHO 😳
          Chopper Greg
          With due respect, that is not very nice.
          No one starts off as a Norm Abram, nor can everyone afford the likes of solidworks or do they have the skill to use it.
          Pre-building, even basic items, will point out any problems and allow people to properly plan. As such the ability to cut and test fit everything beforehand would be of great use to make sure that the design they hand in mind is valid, but to do that, your objects need to act as solids. We have heard from another poster, that even professionals do not always get their designs so that it will work in real life, until after the cutting has begun.
          Such pre-building would allow, all the cutting and fitting to be done long before anyone putts their hand on a saw, thus would be of use to anyone including non-professionals, allowing any object that could be made with SketchUp's simple push-pull system to be test built, with inexpensive electrons and not expensive real world materials.
            Chopper Greg
            I would think that a little more than a warning dialog would be of greater use - like highlighting the area ( or area's ) that has intersection occurring, even then that might be less functional than allowing full contact but no penetration of an object on another object - like a 5mm OD peg not quite fitting into a 5mm ID hole.
            • jeff hammondJ Offline
              thing is, everything you're asking for (well, except for the solids thing) is possible in sketchup.. i do it often with some weird stuff so i know it works.. it might just be a simple change of mindset to accomplish what you want.. don't fight the software.. realize what it can do for you and go with that..
              preview WIP
                more of that bowl..
                [fwiw, i've built a lot of stuff like this in the past and this drawing is the first time i'm actually drawing the entire frame.. i usually only get this detailed on very specific complex sections and the rest is done out of the head.. i'm only drawing this for a big promo print... if you're new to carpentry, welcome!.. pre-visualization is a great thing for successful projects and i suggest practicing it mentally as well as electronically]
                  Gruff
                  I do not think you realize what a complex thing it is you ask Greg.
                  I have many years of Solidmodeling under my belt with most of the popular true solid modelers (Solidworks, Inventor, Intergraph, Unigraphics, Etc...) I can tell you that none of them implement what you describe in any usable way.
                  Solidworks can do motion. You can add 'Mates' between solid parts. This allows them to pivot, slide, hinge and quite a bit more. They even added virtual motors both radial and linear. With some fancy footwork they can simulate belts and gears, in the latter case it doesn't work by virtual friction or surfaces impacting other surfaces. The point I'm getting at is that with all this parts can still intersect and pass through each other.
                  There once was a third party product ... I think it was called Solidmotion that we bought. It did motion studies and could do what you talk about but not in real time. You setup the parameters and let it run overnight. It built a slide show that you could animate and see the results. (Wasn't terribly useful)
                  This sort of thing requires a lot of horsepower.
                  Perhaps Simple alignment mates could be added to Sketch up. I can see that working. You would select a face on each of two parts then apply a coincident mate. The loose part moves to that position.
                  Three Mates and your parts are locked where you want them to be.
                  I am getting Solidworks 2010 end of this month. I'll let you know what new stuff they added.
                  Resistance is .... Character Forming. Grin
                  • X Offline
                    xrok1
                    you could try booltools and just build with dimensional lumber and then use the difference tool to trim away anything that laps or intersects. that way when you measure the resulting parts they can't possibly not fit together properly. 😉
                      Chopper Greg
                      That's just it, I am trying, but because the object are not acting as solid individual pieces, they end up shoved through another piece or worse - they stick to each other and when I test fit I end up pulling the parts totally out of shape.
                      I have heard that making each part a group, would help in this regard, but the tutorial about groups is less than crystal clear and I find my self getting more and more frustrated with it.
                      Yes, I'm fairly new to carpentry - and as such, while I know what I would like to accomplish, I do not know how to do it, and as such I tend to end up wasting a fair amount of material. 😠 😠 😠 Thus the reason I would like to be able to cut and fit with electrons rather than the real stuff.
                      I think that there is some misunderstanding - I don't have allot of need for automation within the program - I can move a part myself were I want it to go, I just need to know when one part will not fit another, without being pushed into or through the surface and I have not been able to achieve that with SU..
                      If I am understanding it correctly - this might work from my purposes.
                      booltools?
                      I have not heard of it - I tried looking it up and I'm finding allot of references ( about 4,600 hits ), but not hard data about what it actually does, it could be that I'm just missing it among all the references.
                        @chopper greg said:
                        booltools?
                        Here it is:
                        http://www.smustard.com/script/BoolTools
                        video also added there.
                          d12dozr
                          Greg, sounds like youu need to get the basics down...here is an excellent video about groups, how, when, and why to use them. http://sketchuptraining.blogspot.com/2009/02/using-groups.html
                          There are other posts on the blog that may benefit you as well, take a quick look: http://sketchuptraining.blogspot.com/
                          Oh, and have you seen Aidan Chopra's website? http://www.aidanchopra.com/tableofcontents There are many excellent videos here, and he's got a great sense of humor 😄
                          http://goo.gl/f7ooYh
                            Chopper Greg
                            I wonder if there is anyway to download the video's to go over while offline.......
                            Anyway, I just ordered the book - I think at least part of the problem was that I was getting components and groups mixed up.
                              d12dozr
                              Yes if you have Real Player you can right click and download, or a little tab appears at the top of the video that you can click on to download it.
                                Chopper Greg
                                I must be stupid - all I can find is the option to watch it on YouTube. 😞
                                  I am not agree 💚
                                  "the object are not acting as solid individual pieces"
                                  Of course yes if you use Sketchyphysics as said soon the first page! 😒
                                  (all must be groups or components)
                                  You have automatic "collision" replace!
                                  But please show a simple image example of what you do you want: Before / After 😉
                                    Chopper Greg
                                    Here is what I have so far:
                                    http://i58.photobucket.com/albums/g240/Greg__H/AVCenterbuild.jpg
                                    I'm looking to mate the slots, without shoving one part into or through another.
                                    I have been expramenting with sketchyphysics, but have no idea what I'm doing with it. 😞
                                    • Alan FraserA Offline
                                      Alan Fraser
                                      This seems to be a straightforward job for the Move tool. You need to be aware that it's important where you pick up an object with the Move tool, as the cursor will snap to the nearest node at the target. This can be used for precise positioning.
                                      3D Figures
                                        Chopper Greg
                                        There is no doubt that it can be done with the move tool - the problem is being able to tell if it will fit in real life rather than just being imposed on the objects in SU.
                                        An extream example of one object being imposed on the other:
                                        http://i58.photobucket.com/albums/g240/Greg__H/AV2-alt.jpg
                                          Switch to X-ray and you'll be able to look inside to see if anything is overlapping.
                                            Alan Fraser
                                            Sorry, but I just don’t see what the problem is. As Jeff says, switch to X-Ray; if the edges on the two components exactly overlap or extend each other…when zoomed right in…then the parts are an exact fit. If they don’t, they’re not.
                                            3D Figures
                                            • 2 / 3
