    [Plugin] 2D Tools
    791 Posts 178 Posters 807.4k Views 177 Watching
      DIEGO-RODRIGUEZ
      Hello TIG.
      I tried 2dtool and found the following errors.
      The lines do not extend to circles and arcs
      The arches, extend one end. the other end is not extended.
      The line of destiny, color cyan, turns off in areas where it is intersected by another line
      [flash=425,344:x5dl6kqm]http://www.youtube.com/v/mI37VX17nqk[/flash:x5dl6kqm]
      • JClementsJ
        JClements
        Hi TIG:
        Thank you for looking at the file. I did further test and similar things happened with 7.0 and 6.0.
        I opened previous revision levels (backups) of the file and when I changed the units to Engineering, the error popped up. I thinking it could be a rounding error, but not so sure now.
        I will send the file to SU folks.
        • mitcorbM
          mitcorb
          TIG:
          Here are the results on the double slash input:
          (eval):149
          folder="C:\Program Files\Google\Google Sketchup 6\Plugins\2Dtools\Hatching\"
          UI.openpanel("Choose HATCHING...",folder,file1)
          Error: #<NameError: (eval):149: undefined local variable or method `file1' for main:Object>
          (eval):149
          ---I had to insert a " in front of the word Choose, because I got a syntax error comment, and noticed that you may have copy/pasted my mistake in your new instructions.---
          Second results: since first did not work:
          folder="C:/Program Files/Google/Google Sketchup 6/Plugins/2Dtools/Hatching/"
          (eval):149
          ---Again corrected for the missing "---
          Lemme know,
          mitcorb
            mitcorb
            Another slant... Copy/Paste these 3 lines of red text into the Ruby Console and see what happens...
            folder="C:\\Program Files\\Google\\Google Sketchup 6\\Plugins\\2Dtools\\Hatching\\" file1="*.jpg" UI.openpanel("Choose HATCHING...",folder,file1)
            If nothing works then change them to these 3 and try again:
            folder="C:/Program Files/Google/Google Sketchup 6/Plugins/2Dtools/Hatching/" file1="*.jpg" UI.openpanel("Choose HATCHING...",folder,file1)
            I think it's something to do with SUp v Ruby syntax changed in the updates of Versions... We will sort this 🤓
              @jclements said:
              Hi TIG:
              It's not the file as it happens with all models with -ve Z in Engineering Units... Seems as far back as v6 ! It's not the tools, as you can reproduce the effect by trying to get set the -ve Z to_s in the Console and you'll get a rounded -- version !!!
                We have both messed up... I copied the text from yours - hence the missing "...
                You failed to set file1= - you only pasted line 1 and 3 - you missed line 2 !
                Please try again with the " and all three lines.
                One defines the folder, two the file and three is the UI.openpanel command...
                • mitcorbM
                  mitcorb
                  OK, TIG:
                  I am at a different machine right now.
                  I will retry in about 3-4 hours at the one with the problem.
                  Interesting! I loaded 2dtools at my office on SU6pro. Still cannot get hatching to proceed. Is there something I might be doing wrong? Or is there possibly some other plugin or extension interrupting this one?
                  Oh well, let's get the issue resolved at the first location.
                  mitcorb
                  • honoluludesktopH
                    honoluludesktop
                    Hi TIG, On my system, I am still having problems with flashing shadows under SU's pull down menus while 2DFreehand is the active selection. SU hangs if I try to close SU while this command is active, but if I change the selection, I am able to exit SU. The problem persist even I removed every other plugin, except SU.rb, and 2D#.rb.
                    I do not have this problem at home, so its not the ruby that is at fault. Any ideas, anyone, as to where on my system I can look for a solution? I have tried disabling WinXP's menu shadow, and unchecking SU's OpenGL preferences with no effect.
                    • mitcorbM
                      mitcorb
                      Ok, TIG:
                      I am at the machine on which I first had the problem.
                      The double backslash method pulled up the HATCHING folder this time, with contents. But see the results:
                      file1="*.jpg"
                      nil
                      -----I did not change anything in the console display.
                      I will now run the second set with the forward slashes just to be thorough:
                      file1="*.jpg"
                      nil
                      ---- and running it in this form did NOT call up the HATCHING folder, or anything else.
                        @mitcorb said:
                        Ok, TIG:
                        file1="*.jpg"
                        nil
                        file1="*.jpg"
                        nil
                        We will find what's up...
                        Do I understand that the \ method worked ? If not then please try these 3 lines [they have the end \ or / removed from the folder path...]
                        folder="C:\\Program Files\\Google\\Google Sketchup 6\\Plugins\\2Dtools\\Hatching" file1="*.jpg" UI.openpanel("Choose HATCHING...",folder,file1)
                        and this alternative...
                        folder="C:/Program Files\/Google/Google Sketchup 6/Plugins/2Dtools/Hatching" file1="*.jpg" UI.openpanel("Choose HATCHING...",folder,file1)
                        We will prevail !
                        When you get the folder open what do you get if you select afile and then press OK, then do it another time and press Cancel...
                        • mitcorbM
                          mitcorb
                          Hi, TIG:
                          Here are the contents of the console using the double backslash input, and selection of ANGLE PATTERN. The Hatching folder comes up with the patterns displayed in list form rather than thumbnail form, in this case.
                          file1="*.jpg"
                          C:\Program Files\Google\Google SketchUp 6\Plugins\2DTools\Hatching\PATT_ANGLE.jpg
                          ----HERE IS THE SAME CALL UP, EXCEPT CANCEL THE SELECTION:
                          file1="*.jpg"
                          nil
                          When I cancelled, the window closed, no other activity, and the "nil" was displayed.
                          Since this was successful, do you still want me to run the second suggestion and the alternative?
                            mitcord - I have the answer ! [I thnk ☀ ]
                            Watch for an update very soon... We will give you hatching... 😄
                            • mitcorbM
                              mitcorb
                              Ok, TIG:
                              Say, what do you do--take power naps?
                                Here's v3.5 http://forums.sketchucation.com/viewtopic.php?p=185760#p1857605
                                Hatching Tool made v6/XP friendly.
                                Adjust to Arcs changed to individual Segments.
                                2D Text now has a Snap setting for Z-plane or All-Faces.
                                Feedback please...
                                • mitcorbM
                                  mitcorb
                                  TIG:
                                  SUCCESS!!!!!!!
                                  Made a 2d rectangle on default 0 zplane, gave it a 2d face, selected hatching tool, folder popped up, selected angle patt and it was applied. Incidentally, I did this procedure with the Ruby Console open, and there was no data on any of the actions.
                                  Comments: the angle pattern does not display boldly, you must zoom in. Have not tried any other patterns. I assume they are scalable.
                                  Buncha Questions:
                                  What is so special about the double backslash method?
                                  Why did your original code work for so many other users and not for my case, and maybe others?
                                  Is this something that all plugin authors should be considering, or is it unique to SU6?, or XP?
                                  Does this fix also address the linestyle question?
                                  Thank you very much for all that you do!
                                  mitcorb
                                    @mitcorb said:
                                    TIG:
                                    SUCCESS!!!!!!!
                                    Buncha Questions:
                                    mitcorb
                                    \ works for Sketchup UI.openpanel etc in all PC versions.
                                    \ doesn't work for Ruby classes like Dir - those need / !
                                    / works for Mac and newer versions of Sketchup and PC OS's - with UI.openpanel etc.
                                    I have now trapped it to use / for Ruby and Mac and \ for PC always...
                                    I 'inherited' most of the PATT files if you want to adjust them by editing the JPGs feel free - re-publish them here if they are good... You can also scale the image in the Material Editor etc...
                                    Solved at last ! 😄
                                    • JClementsJ
                                      JClements
                                      OOPs
                                      2Dtexttool.png missing a "T".
                                      Use this if you like.
                                      John
                                      Oh, thanks TIG for a great tool set!
                                        😳 v3.6 uploaded with corrected 2D Text toolbar icon - now with 'T'...
                                        • C
                                          CAAD2
                                          Yes, Solved at last! 😄
                                          many x many, thankSSS 👍
                                          CCCAAAAAAAADDD222
                                            Bingo
                                            I'm not up to speed on the Mac, so perhaps a PM to Edson might help.
                                            The one file that goes into Plugins ' 2D#.rb' simply runs load '2Dtools/2D#loader.rb', that in turns loads all of the scripts in the 2Dtools folder that should be in the Plugins folder.
                                            I assume you have all of these... The zip file is NOT needed once the files are extracted...
                                            There should be one 2D file of any sort [ 2D#.rb] in Plugins, but lots inside the 2Dtools folder.
                                            Try typing/pasting this text into the Ruby Console and report what happens...
                                            You shouldget the toolbar available in View > Toolbars...
                                            • 39
                                            • 40
                                            • 8 / 40
