    Ends of lines
    5 Posts 3 Posters 538 Views 3 Watching
    • E
      elgin
      Hello everyone and thanks for any help. I am new to SketchUp.
      When I began using SketchUp the lines were clean with nothing marking the ends. Now I have little points on the ends of each line. Not sure what I did to cause this, but would like to know how to go back to the clean lines with no end markers or dots.
      Again, thanks so much. . .
      elgin
      • P
        Panga
        Hi and welcome here,
        It's easy, just go to the View menu > Edge Style > and uncheck Extension.
        Good work.
        • GaieusG
          Hi Elgin,
          (yes, Panga "beat me" but I still push the button...) 😉
          This is a style setting in some of the templates. Open your Style dialog (Window menu), navigate to "In model" > Edit tab > Edge settings and uncheck endpoints and extensions.
          Now (maybe together with some other settings) save this as a template (under the File menu) and go to Preferences > Te4mplates to choose your newly created, custom template for SU to start with any time you open a new file.
          • E
            elgin
            merci beaucoup, Panga and köszönöm, Gaieus
            Your replies solved my problem. ☀
            • P
              Panga
              Hi Gaieus,
              I just finished to install my rss reader when elgin wrote his post... I wanted to be more present and reactfull on this forum which help me so much.
