    Transformations
    23 Posts 10 Posters 17.2k Views 10 Watching
      Chris_at_Twilight
      According to the documentation, yes, they should all be identical. Though the 3rd form isn't in the docs...(I'm looking at the old ones, not the latest).
      http://www.TwilightRender.com
        Jim
        Well thanks guys - I wanted to start at the beginning.
          MartinRinehart
          If one of you who has figured on transformations could write a little article for those of us who haven't, it would be a GOOD THING!
          • TIGT Online
            This is the basic transformation stuff... πŸ˜‰TransformationMatrix.pdf
              MartinRinehart
              @tig said:
              This is the basic transformation stuff... πŸ˜‰[attachment=0:3e59iit0]<!-- ia0 -->TransformationMatrix.pdf<!-- ia0 -->[/attachment:3e59iit0]
              That confirms my worst fears.
              • TIGT Online
                There are several good methods for getting and changing transformations - relatively easy when you've done it a few thousand times... However, some simple ones are missing - for example if would be nice to be able to get just the angle of rotation out of an existing transformation and then reuse use it in Geom::Transformation.rotation(point,vector, angle)... As it is you can 'clone' the transformation of one thing and apply it to another but that could scale or move it too...
                  MSP_Greg
                  TIG,
                  I think the below might help. I haven't tested it that much, and never with 'stretched' trans...
                  suATan just returns the arctan of the two numbers (x,y), x=0 => +/- 90
                  aT = e.transformation.to_a
                    # aT[12], aT[13], aT[14]           x, y, z offsets from component origin
                    # suATan(aT[0], aT[1])             xy plane angle
                    # xy = (aT[8]**2 + aT[9]**2)**0.5
                    # suATan(xy, aT[10]) - 90          rise angle, check this one
                  HTH,
                  Greg
                  • chrisglasierC Offline
                    chrisglasier
                    Can I add this topic and particularly this post, to make this topic more complete, even if duplicated in parts.
                      MSP_Greg
                      Jim,
                      Can you post the file that you used for import shown?
                      Thanks,
                      greg
                        Jim
                        Here it is.
                        LDraw part No 3001
                          CPhillips
                          Jim, what is the problem with the brick? The axis look ok to me. Is it that the brick isn't upright?
                            Jim
                            Yes that is all. One option would be to flip the SKetchUp axes to match the LDraw axes before inporting. But I just want the bricks to be imported using the SU axes instead of the LDraw axes - including the sub-components.
                            I thought it would simply be a matter of performing an axes transformation on import - but so far the solution has been evasive.
                              CPhillips
                              Looks like LDraw uses Y is up instead of Z. You could just swap the Y and Z elements when you build the points for the faces. And also swap Y and Z in the translate part of the transform. That will change the axis.
                                CPhillips
                                I tried out what I suggested and it totally didnt work. I think it is because of the way scaling is being used. Flip Y and Z and you also need to flip ScaleY and ScaleZ. That is surely possible, but I dont know how to do it.
                                  avariant
                                  Have you tried the Transformation.axes method? It sounds like you should be able to "remap" the standard axes using this transform. Something like Transformation.axes(ORIGIN, X_AXES, Z_AXES, Y_AXES). Just a thought, I have no idea if it will work.
                                    Jim
                                    That is what I tried to use, but got some crazy results. My initial reaction is to assume I am not understanding how to use them. But if Chris had a problem, I might be inclined to think it's not just me.
                                      jessejames
                                      What do you mean exactly Martin?
                                      1. How do Transformations work on a mathematical level and all the boring details that go along with it?
                                      2. How do i use the Geom::Transformtion class to trans, rotate, and scale stuff in SU?
                                      A huge part of understanding Transformations in a mathematical sense is getting past the cryptic syntax. The good thing about a Transformation class is that you don't need to know crap about advanced math and even some basic college math principals to use the Transformation class quite easily.
                                      Thats one thing i love about programming, code up a class that abstracts away all the details and forget about it! I'll leave the asinine number crunching to my processor!
                                      Always sleep with a loaded gun under your pillow!
                                        MartinRinehart
                                        I love those very smart people who can do #1, so the rest of us don't have to.
                                          cjthompson
                                          The transformation.axes method just transforms the object so that it's axes match the internal ones.
                                          try using transformation.axes on the grouponent (I believe you used that one πŸ˜‰)
                                          then use
                                          grouponent.entities.transform_entities(grouponent.transformation.inverse,grouponent.entities.to_a)
                                          EDIT: Just tried it and it should work.
                                            cjthompson
                                            I just looked at the picture you posted again. Do you want flip the axes, instead of rotating them? If so, I don't know if that is possible. It's has to do with the fact that sketchup uses a right hand orientation, instead of left-hand orientation that I'm guessing LDraw uses (http://en.wikipedia.org/wiki/Right-hand_rule).
                                            Is there a way to change the orientation of axes in LDraw? (I haven't used it myself, so I have no idea)
