    [WIP] Interiors -will be my first PR renderings
    64 Posts 16 Posters 9.3k Views 16 Watching
    • soloS
      Tina, it did render on my side, but it took a while to process geometry and warm up, I tested it on default (I have not got the other presets loaded besides the standards on my new rig).
      I guess it may be overloading your machine as the scene has 821 lights, 2593 reflective surfaces.
      I then reset the model, and it rendered in 1m 40s, however when I tried to add lights (omnis) SU crashed and kept crashing after that, so it looks like it may indeed be a combination of model and Podium.
      • olisheaO
        olishea
        sounds like a geometry or texture issue to me, more likely geometry.
        sometimes just one dodgy texture or component can cause the crashing. I would delete components one by one and reset all materials and keep testing til it stops playing up (oh and purge all if you haven't already). 2593 reflective faces isn't too excessive for podium, just one car has that amount and normally its very stable. Why so many lights?
        oli
        • E
          Eulgrand
          • soloS
            The lights are LEM's, so it could be a sphere that's lit up.
            • david57D
              david57
              That looks beautiful, I like it. I dont know what PR or NPR is.
              • E
                Eulgrand
                Thanks for the explanation 😉
                • FrederikF
                  Frederik
                  Looking forward to see the progress of this...
                  The scene has a good potential... 😉
                  Cheers
                  Kim Frederik
                  • E
                    Ecuadorian
                    Try using the Metropolis Light Transport render method. In MLT, the number of light emitters is totally irrelevant. You can have 8 or 2048 emitter faces and the render time will stay the same.
                    http://en.wikipedia.org/wiki/Metropolis_light_transport
                    -Miguel Lescano
                    • tinanneT
                      tinanne
                      Pete, thank you so much! I also took out the omnis and reset the model and got the same results. So.... problem with omnis... What do I do about that? What are my options for lighting the model? Why would I be having trouble with omnis?
                      Executive Director : American Society of Architectural Illustrators
                      AIP 30 Competition opens soon. ASAI.org
                      Architectural Rendering
                      • tinanneT
                        tinanne
                        Thank you. Now that we are getting to what the problems are I'm having more hope for it's outcome. 😄
                        • tinanneT
                          tinanne
                          @olishea said:
                          Why so many lights?
                          I've probably not set the model up correctly for podium is my guess. I'm just trying to get some light into the room. I placed two omnis that seem to be misbehaving.
                          Thank You. NPR is Non-Photo Realistic (which is what the format I generally work in) PR=Photo Realistic
                          You can go a long way down the wrong road if you are not watching.
                          I suggest you start over....trying to disect that scene is going to take too long and I can't see you learning much as it will be hard to isolate what it is that is effecting the render. There are too many variables....and it is just too big to start....to much going on.
                          Start with a very simple scene with very little reflection or lighting....work it up from there and you will see how the changes you make (the additional adjustments) effect the rendering each time. It is very frustrating to continue to preview settings and find that you don't understand how you have effected the change.
                          I took your advice and took out the omnis and scene rendering very quickly and SU did not crash. Thanks for the tip!
                          Wow, I'm new to the PR stuff and that article flew right over my head.
                          @frederik said:
                          Sure is going to be difficult using Podium, since unbiased methods are not supported by the engine... 😉
                          Again, {SHOOO} and you messed up my hair!
                          • tinanneT
                            tinanne
                            My "successful" attempts...
                            Default Settings
                            Fab Interiors Setting
                            Clay Render - Just for fun
Sepos Smooth Setting
                            • FrederikF
                              Frederik
                              Sure is going to be difficult using Podium, since unbiased methods are not supported by the engine used in Podium... 😉
                              Cheers
                              Kim Frederik
                              • tinanneT
                                tinanne
                                Bruce, yes, very pleased! Like you said just getting it not to crash was a huge accomplishment. Now I just have to figure out how to get the room lit. Hmmmmm?
                                  sepo
                                  If you want to send the scene please do. I am quite keen to see if I can do it slightly differently.
                                  • FrederikF
                                    Frederik
                                    Great idea...!
                                    http://www.kerkythea.net/users/Frederik/Anim-Icons/thumbup.gif
                                    Really - I mean it... If possible, "Honey Dear", then you should make it available for all of us and make it a render challenge... 😉
                                    Previous render challenges have proved to be very interesting, where scenes have been rendered by many different users and the outcome have been really interesting...
                                    Cheers
                                    Kim Frederik
                                      sepo
                                      Did not have it in mind as a render contest....more like offering help as Tina is using Podium. 😉 But hey.... maybe Tina would like to see what could be done with different render engines.
                                      • tinanneT
                                        tinanne
                                        Wow, that would be a great idea. You will all put me to shame, I'm sure. The problem is I have quite a few FF models in the scenes. I could replace them?
                                        • david57D
                                          david57
                                          You could use light groups, but no one uses this programs. Was thinking of this yesterday.
                                          http://www.vimeo.com/5109661
                                          • tinanneT
                                            tinanne
                                            Baked another one today.... I think I've figured out what I was doing wrong before. I was setting the light on the face of the omni not the group. Could that cause the problems?
                                            Bedroom
                                            Looks like it's time to start working on textures and yuck! the tree in the corner is NOT going to work. I need some Cherry Blossoms. Anybody have any?
                                            • 2 / 4
